09-18-2010, 10:13 PM
#1 |
Oddometer: 153
KTM Cush Hub, Yes/No for KTM 530?
So I've talked to several folks of the last couple of years and have tried to sort through the BS. Here's what I've got:
1. Cush hub protects the transmission from torque during hard acceleration and hard downshifting on tarmac. 2. Some say not necessary for knobbies or supermoto applications some say it is essential for street riding. What's the inmate advice? I ride 20 road/80 off-road and have Dunlop 908RR tires f/r. Opinions, upsides/downsides, supermoto or knobbies, etc. Thanks for comments! |
09-19-2010, 01:04 AM
#2 |
wannabe bike builder
Oddometer: 214
yes to cush
Cush drives dont really have any down sides except for maintenance on the rubbers and one extra bearing but the positives far out weigh the negatives . If you want to keep the bike long term definatly cush her up heavy sand riding also is very hard on gear box the constant loading and unloading causes heavy wear
If you turn them over quickly mabey not if you want to keep it long term cush cush cush |
09-19-2010, 01:46 AM
#3 |
Oddometer: 4,911
The cush wheel is a lot heavier, and it might not be necessary on the 530 as it has a damper built into the clutch unlike the previous generation bikes. On the RFS bikes I run a cush hub on both my motard and dual sport wheel sets. Besides the 525s often cracking the solid hubs in high traction conditions, it also helps with wear on the countershaft splines, which can be problematic.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
09-19-2010, 11:18 AM
#4 |
lost in the 690 mega
Oddometer: 316
Have you considered a dampened counter shaft sprocket as a cheaper (slightly less effective?
) alternative? The splines on your counter shaft are the same as those on a 690e/r/smc which use a rubber dampened sprocket. The difference being that the 690 sprocket is slightly thicker which could be easily cut down to fit the exc. Sprockets are available in 15/16/17 tooth for around $30.I have not personally tried this but I have put a non-dampened exc sprocket on my 690 using a small spacer behind it, so it would make sense that it could be done the other way by removing material from the inside of the sprocket. |
09-19-2010, 11:52 AM
#5 |
Needs to STFU
Oddometer: 7,778
Varying opinions. Some swear by it, and others dismiss it as not needed. There was a rental company out West that runs all EXCs and their bikes get flogged mercilessly, all with 10k+ miles and they don't run em.
Were I doing a lot of SM riding I might consider it, but linking trails together and the occasional jaunt to town like I do? (80/20) Nahh..
Wedding = $25,000 Divorce = $500 Brazilian 2nd wife = Priceless 2007 Triumph Tiger 1050 ABS
09-19-2010, 12:12 PM
#6 | |
Ride you must.
Oddometer: 1,675
Dave Hopkins claims to be doing one output shaft a week due to ruined slines from DS bikes.
I eat my candy with the pork and beans- |
09-19-2010, 12:19 PM
#7 | |
Oddometer: 837
09-19-2010, 12:29 PM
#8 |
Oddometer: 27
If you only ride dirt it's not necessary. I would recommended for street use.
09-19-2010, 01:28 PM
#9 | |
Oddometer: 316
09-19-2010, 05:11 PM
#10 |
Ride you must.
Oddometer: 1,675
There is a company making a damped rear sprocket. Forget the particulars. Non US currently.
09-19-2010, 05:31 PM
#11 | |
CDI REPAIR
Oddometer: 3,317
B
01 XR650L,102mm JE 11.25:1 ..NX650 second gear,FMX650 fifth gear,ported CW head,KW valve train,MegaCycle 173X25.Cycra probend CRM,Scott`s sharkfin,Xr`s Only casesaver.FMF "Q2",Sutton Oil Cooler,Clarke 4.0,Red XR`s Only skidplate,Doubletake mirrors,Manracks Rotopax rack..one Minature Schnauzer
09-19-2010, 05:37 PM
#12 |
Ride you must.
Oddometer: 1,675
I was waiting for others to experiment before i'd consider it. I had my doubts looking at the photos.
09-19-2010, 07:31 PM
#13 | |
Oddometer: 5,050
09-20-2010, 01:21 PM
#14 |
Gleasons Drift
Oddometer: 191
Have a Cush Hub on my 2010 530.
2000+ miles on it now (street/dirt 30/70) I'm still on the fence if it was a good investment or not. When going on a pure dirt type ride I run the stock rim. For aggressive street riding I do like having the cush hub wheel on. But if I were riding mostly dirt and not too aggressive on the street, I'd spend my money on something else. street/dirt 80/20 yes 50/50 maybe 20/80 no
If you love your motorcycle, set it free. If it comes back to you, you've probably highsided. Flyer screwed with this post 09-20-2010 at 01:31 PM |
09-20-2010, 04:50 PM
#15 |
Oddometer: 153
Thanks - Great info
The winter mods may include this. I have a lot of sand in my area and some day may slap a paddle on her so it may be a good investment. I don't plan to swap out the bike anytime soon and would like to do some longer distance riding, like the Continental divide. Sounds like it can hurt. The GS does most of distance stuff now but the capability of the 530 is in the back of my mind when hairy stuff pops up. Thanks folks!
