Old 10-29-2010, 11:24 AM   #46
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,467
Originally Posted by Gadget Boy
I'm surprised the wire wheels are centrally laced and not cross laced like on the GS which takes tubeless tires. So, this means it's got tubes, I suppose?
And they're still using the old intuitive switch gear..
Yeah, tubes!
Glad they kept the old style switch gear.
For peak hp, you need a different bike.. the DOHC has a flatter torque curve than the engine it replaces, so your torque range is extended, service intervals are doubled for valve checks, and it's certainly capable of cruising at 140 km/h with ease, if you like to ride that fast.. more hp gets you to go to higher speeds but for a roadster, that's plenty fast (~85mph)
Having spent a little tim on an 11 R1200GS I can honestly say that redline being 1000 higher, and the flatter torque curve, makes a world of difference. It is MUCH quicker than even my R1200ST, and smooth! I never felt like I was kitting the redline too fast, and wheelies in 3 gears was nothing but a twist of the wrist away!
Maintenance in a snap too. I've done a full 36K service, and it was just as easier, easier, than the old R1200.
Jim
JimVonBaden is online now   Reply With Quote
Old 10-29-2010, 11:38 AM   #47
mantan
Oddometer: 482
The red bike looks awesome! I may be going back to the RR. Had an 01 1150R, non-ABS. I like the fact that the RR is no longer a low-end boxer with no options except ABS.
mantan is offline   Reply With Quote
Old 10-29-2010, 12:25 PM   #48
Papermaker
Infrequent Poster
Oddometer: 31
Originally Posted by JimVonBaden
Yeah, tubes!
Jim
Jim,
How much of an issue is the valve adjustment? It would seem like you would need a whole set of the shim doohickies to set the clearances properly.
Papermaker is offline   Reply With Quote
Old 10-29-2010, 12:29 PM   #49
ThePikeman
German n00b
Oddometer: 4,735
Motorrad writes that there will be 5 seats to choose from, from 760mm to 830mm height (2 4/5 inch difference).
Seems like they got a blinged up classic version and the normal version.
I like it.
ThePikeman is offline   Reply With Quote
Old 10-29-2010, 12:35 PM   #50
Deans BMW
Granpa Hoon
Oddometer: 3,575
The first valve CHECK is at 6,000 miles and every 12,000 miles after. The check is very easy as is the adjustment. there are reports of going over 24,000 miles with out any need of adjustment.
Dean O
BMW nut and Happy Camper
Copperhill, Tn.
www.Motorcyclistcafe.com
Founder San Jose BMW
Deans BMW is online now   Reply With Quote
Old 10-29-2010, 01:17 PM   #51
Maineroads
Ridgerunner
Maineroads's Avatar
Oddometer: 832
Wish they'd go back to that on all bikes.
Steve
Maineroads is offline   Reply With Quote
Old 10-29-2010, 02:28 PM   #52
Mobiker
Mobiker's Avatar
Oddometer: 1,824
I like screw and locknut valve adjustment - probably because I'm comfortable with it, but I'd buy the new one just to avoid the vertical stacked clocks. I always thought they looked tacked on and kind of cheesy. The new ones look much better. I'll take the black one with the stripe and cast wheels please.
'88 R100GS
'76 xl350
"Don't Panic"
"If I was in a hurry, I'd left earlier."
Mobiker is offline   Reply With Quote
Old 10-29-2010, 02:33 PM   #53
fixinbones
Tarmac Adventurer
fixinbones's Avatar
Oddometer: 2,012
Originally Posted by hyena
Those are some funky looking cast wheels on the new one. And even though I'm a cast wheel fan, I like they're offering spokes. One thing I don't like is the deeply dished seat. I must have a peculiar ass - it likes the stock seats on my air head and scrambler. Flat seats you can move around on without being locked into one place.
I like the R. I haven't ridden one, but I sat on an 09 when I traded by 05 GS for an 09 GS early this summer, and it felt good.
Congrrats on your new ride.
I would put money on it that thats the low seat option
I love the black and white one!!!!!
'13 Ducati Diavel AMG #163
'09 KTM 65XC (son's ride)
Gone: '10 Ducati Multistrada 1200S, '11 BMW R1200GS, '10 BMW S1000RR, '08 BMW HP2 Megamoto, '07 KTM 950SMR, '05 BMW R1200GS, '94 BMW R1100R
fixinbones is offline   Reply With Quote
Old 10-29-2010, 04:01 PM   #54
Papermaker
Infrequent Poster
Oddometer: 31
Dean,
I understand that the checks and adjustments are at longer intervals, but that still begs the questions of what happens when you need to make an adjustment. I'd hate to have to take it into the shop, just because I can't figure out which shim I need when the time comes and I expect buying a full set would be an expensive proposition.
Old 10-29-2010, 04:09 PM   #55
Deans BMW
Granpa Hoon
Oddometer: 3,575
Here is a link to a pictorial of the adjustment procedure. Chris at San Jose BMW put it together.
http://sanjosebmw.smugmug.com/Other/...10976964_bHf66
It is very easy to do.
Dean O
Copperhill, Tn.
Old 10-29-2010, 05:57 PM   #56
JimVonBaden
"Cool" Aid!
Oddometer: 54,467
Originally Posted by Papermaker
Jim,
IF you need one, you can order them individually. They run about $4.50. You can also swap them around to keep them all in range, or just put it back together and order what you need. Changing them is so easy you could swap one out in 15 minutes.
However, from all accounts, they very rarely go out of adjustment.
Jim
Old 10-29-2010, 06:32 PM   #57
Mobiker
Mobiker's Avatar
Oddometer: 1,824
Thanks for the link. That certainly looks doable and lot easier than pulling the cams.
'88 R100GS
'76 xl350
"Don't Panic"
Old 10-29-2010, 07:09 PM   #58
Donster
No trick too cheap
Donster's Avatar
Oddometer: 557
[QUOTE=vander]In fact, they did released the 2011 model yesterday
Wow. Just wow...
Donster is offline   Reply With Quote
Old 10-29-2010, 10:41 PM   #59
mtwillyman
Lost and Cornfuzed
mtwillyman's Avatar
Oddometer: 623
I really like this one!
I may come back to BMW with this new R1200R. This is one sweet bike. I really like the matte gray color. The valve adjustments look to be a snap also. 2011 could be an expensive year for me. Ha!
mtwillyman is offline   Reply With Quote
Old 10-30-2010, 04:29 AM   #60
BigEasy
BigEasy's Avatar
Oddometer: 1,789
I'm liking it. I have frequently said I'll not sell my '07 R12R, and I still will not. However, I think when I get my HD paid off in a couple years I may be looking for a used '11 RR. I really like the black motor.
I do have a stupid question though: what the hell are you talking about old intuiitive switch gear???
All who wander are not lost
"Play hard and FLOOR IT" Stevie Ray Vaughan
just remember: the only difference between genius and stupidity is genius has limits
BigEasy is offline   Reply With Quote
Times are GMT -7.   It's 05:48 AM.
