Old 09-26-2010, 06:00 AM   #16
R3B
Lazy Motorcyclist
R3B's Avatar
Oddometer: 1,279
What i ment was like this, so that the cables have a free movement at full throttle (although it would not be verry sensible to let the CC stand full throttle...)
Sorry for the dirty pictures but its old thrash, on which one can experiment freely :-)
So open up the loop, make it flat sideways, put it at the closed side, then push the original gascable end home in its place, and lay the original cable at the "bottom" in the rocker rut
Every Adventure big or small
................*is* an Adventure all in all.
.........................So every day: Give in to the call
Riding tips: . -----www.LazyMotorbike.eu-----
R3B is offline   Reply With Quote
Old 09-26-2010, 03:11 PM   #17
mobyfubar
cd /;rm -rf *
mobyfubar's Avatar
Oddometer: 253
Originally Posted by SuperCruise
Unfortunately, I am going to have to put this project on hold for the next two weeks as shortly I am going away for a holiday to WA.
Oh, that's OK. I don't need to know how to do this until May.
I'm very interested in this, so thanks for posting it. Have a great holiday!
==BD
'08 Street Triple, '12 Super Ténéré
AMA, MSTA, CMH-MOTO
mobyfubar is offline   Reply With Quote
Old 11-01-2010, 01:31 PM   #18
Gandalf17
Oddometer: 8
Hey SuperCruise,
Any update on your CC project?
Gandalf17 is offline   Reply With Quote
Old 11-01-2010, 03:12 PM   #19
SuperCruise OP
SuperCruise's Avatar
Oddometer: 329
Originally Posted by Gandalf17
Hey SuperCruise,
Been busy with work for the last few weeks and likely the next few more。 I am still keen on getting this project working. Stay tuned.
XT1200Z Super Ténéré 2010
Around Australia, Super Tenere Style
SuperCruise is offline   Reply With Quote
Old 11-01-2010, 06:42 PM   #20
The Jerk
Bring us some fresh wine!
The Jerk's Avatar
Oddometer: 2,662
Hmm this is interesting. I wonder, just for the sake of wondering, if this will work. If this is a throttle-by-wire bike, one would like to think there is some sort of software/firmware whereby if the actual position of the throttle plate is different than the "requested" position (via the throttle grip), the ECU shuts the fun down and puts the bike into limp-home mode because it thinks there's a big problem with the TBW system.
Meaning, if the cruise control cable were holding the throttle open and you let go of the grip and it sprung back close, would the bike go apeshit?
2000 Kawasaki W650
The Jerk is offline   Reply With Quote
Old 11-02-2010, 03:13 AM   #21
R3B
Lazy Motorcyclist
R3B's Avatar
Oddometer: 1,279
Nope, logic (angle-sensors) is all concentrated at throttle body.
Old 12-02-2010, 12:07 AM   #22
Bargenator
Bargenator
Oddometer: 168
Supercruise, I'm looking for the speedo signal wire from the ECU to fit a speedo healer, do you know which one it is, it would be much appreciated.
Cheers
YAMAHA XT1200Z
IT'S NOT THE BIKE YOU ARE RIDING, AS LONG AS YOU'RE RIDING A BIKE.
Bargenator is offline   Reply With Quote
Old 12-02-2010, 10:39 PM   #23
Bargenator
Bargenator
Oddometer: 168
Found it, stop looking.
YAMAHA XT1200Z
Old 12-03-2010, 04:51 AM   #24
llamapacker
Mr. Conservative
llamapacker's Avatar
Oddometer: 1,401
I would be interested where/what it is? Blue?
14 KTM 1190 Adventure
llamapacker is offline   Reply With Quote
Old 12-03-2010, 06:16 AM   #25
Bargenator
Bargenator
Oddometer: 168
Your right, it is blue and it runs from the ABS to the ECU, if your fitting a speedo healer this is the signal wire you splice into, pick up power from any ignition activated power source, and run the ground wire, well, to ground.
You do not disrupt the ABS or the TC using this wire as it is up stream from the ABS module.
YAMAHA XT1200Z
Old 12-03-2010, 02:49 PM   #26
llamapacker
Mr. Conservative
Oddometer: 1,401
Good job, thanks.
Old 12-03-2010, 02:59 PM   #27
Bargenator
Bargenator
Oddometer: 168
This is cut from the email I received from Healtech about wiring up the speedo healer and the gear indicator. Norbet in Hungary is awesome, only to willing to help and fast response to boot.
SH = Speedo Healer
- Cut the Blue wire that runs from the ABS to the ECU.
- The SH White wire goes to the Blue wire end (ABS computer side)
- The SH Green wire goes to the Blue wire end (ECU computer side)
- The SH Red to a switched power lead e.g. to the Red/White ECU wire.
- The SH Black to chassis ground or battery negative terminal
- Perform the SH input/output tests as per the instructions.
To fit the Gear Position indicator: GPX = Gear Indicator.
A few XT1200Z owners have successfully installed the GIpro X-type display with the GPX-U01 harness kit.
Install is very easy especially if you do this after the SH install:
- Connect the GPX White wire to the SH White wire.
- Connect the GPX Red wire to the SH Red wire.
- Connect the GPX Black wire to the SH Black wire.
- Connect the GPX Green wire to the Gray wire at the ECU connector.
- Perform the tests as per the GPX-U01 install guide.
YAMAHA XT1200Z
Old 12-05-2010, 08:06 AM   #28
llamapacker
Mr. Conservative
Oddometer: 1,401
Yep, done them both only on the Tiger 1050. I have the same challenge on the MTS1200, but although it has the wheel speed sensors, I do not have ABS, so it has me stumped on where the blue wire goes back to from the dash.
Anywho, I am going to keep it and install on the S10 instead plus gear indicator which does have some lag but I have become addicted to it ever since the K12GT days.
Old 12-05-2010, 02:45 PM   #29
SuperCruise OP
Oddometer: 329
Just letting everyone know I haven't fallen off the perch. The CC project is still alive but I haven't made any progress for ages. Hopefully I'll get into it sometime during the Christmas break that I'll be having off work.
Old 12-05-2010, 04:24 PM   #30
llamapacker
Mr. Conservative
Oddometer: 1,401
I have an audiovox, made an adaptor for the Versys throttle, so will be watching how you solve this problem on the S10.
No rush, I have . . . . . err . . . about 5 months.
Times are GMT -7.   It's 05:26 AM.
