Old 09-24-2010, 12:47 AM   #1
Caddy82rats OP
Caddy82rats's Avatar
Oddometer: 1,181
BMW reliability... Duck Off !!!!
yesterday at 1 km from home : nada niet niecht, nothing
no ignition, starter idiot lights etc OK
No kill switch at handlebar
Agrandir cette imageRéduire cette image Cliquez ici pour la voir à sa taille originale.
I havent worked now on the problem. But I suspect coils positive connector or points as all the rest is OK
You can notice the old scool acces to the bed truck...
Caddy82rats is offline   Reply With Quote
Old 09-24-2010, 04:09 AM   #2
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 975
Sudden stop with no warning?
Check the battery
Check for a short
A bad coil won't affect the other systems
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 09-24-2010, 05:20 AM   #3
matman1972
Lost in the woods.
matman1972's Avatar
Oddometer: 711
I experienced this event on two of my airheads in the past. Funny thing was, the same wire caused it both times. Luckily I found it on the road the first time, wrapped some plastic casing and tape around it and got home. next bike it happened to, I checked the same wire just for giggles, and sure enough.....
Not saying that is your issue, but positive wire coming from diode board out the top of the timing/charging area was what did it both times for me. casing had melted, and when the wire jimmied itself against the aluminum, no power whatsoever.
Matt
2005 vw trike
Estamos copados
Confusion to our enemies.Zaphod for president!!
matman1972 is offline   Reply With Quote
Old 09-24-2010, 05:45 AM   #4
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 4,530
Caddy82rats,
"You can notice the old scool acces to the bed truck...
Looks like someone is missing part of a door.
Bar None is offline   Reply With Quote
Old 09-24-2010, 06:32 AM   #5
Naed Nekkod
Naed Nekkod's Avatar
Oddometer: 853
Hey,...That bike is or probably almost 30 years old, things like that do happen.
Hope you get it ironed out...:)
Naed Nekkod is offline   Reply With Quote
Old 09-24-2010, 07:27 AM   #6
Caddy82rats OP
Oddometer: 1,181
there is no spark, but starter is OK, it make engine turn.
All electrics is OK but no spark
PS the door is an old one, I haven't stolen it to a house
Old 09-24-2010, 07:52 AM   #7
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,417
Sounds like a condensor. Repalce it with a new one and see what happens. There is no other way to check it. I am betting it has the original. I also think this will solve your problem. That is, if you still have points which you seem to indicate you do.
Go far or stay home.
durtwurm is offline   Reply With Quote
Old 09-24-2010, 08:55 AM   #8
coastranger
Oddometer: 429
do you have voltage to the coils,
no spark to either plug I will go with condesnor, or no power to the coils
coastranger is offline   Reply With Quote
Old 09-24-2010, 10:41 AM   #9
Caddy82rats OP
Oddometer: 1,181
so
Voltage to the coils OK
condenser brand new
points OK
Some hot wire batterie earth to coil earth, batterie positive to coil positive, doing on off, on off with the wire :
no spark
HT leads OK (I've tried some "racing" red ones, with Loge racing spark plug)...
And at this moment, real real smal spark
at this time I've tried a set of coils running on my RS and Bingo, the spark is here, not so big but here !
Batterie is now going to ??? "feed" and after that i'll try to start up
PS : sorry for my poor English
Old 09-24-2010, 11:55 AM   #10
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,799
Your English is better than our French, I can assure you...
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 09-24-2010, 12:13 PM   #11
Caddy82rats OP
Oddometer: 1,181
thanks mate
Old 09-24-2010, 12:17 PM   #12
mykill
odd
mykill's Avatar
Oddometer: 1,166
Grounded point wire?
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 09-24-2010, 12:35 PM   #13
Caddy82rats OP
Oddometer: 1,181
I don't think
Now that's night here so I'm going to check that tomorow
The think is that I've had this issue twice : one time no ignition when driving, maybe 2 seconds and ignition goes on by itself.
An other day, same story, put the bike on sidewalk, unscrew a plug, check it and vroom, engine OK
the last one is yesterday and no restart. I'll hope I've found the problem
Fingers crossed !!!
Caddy82rats screwed with this post 09-24-2010 at 02:11 PM
Old 09-24-2010, 01:25 PM   #14
mykill
odd
mykill's Avatar
Oddometer: 1,166
I don't think
Fingers crossed !!!
Weird. I would suspect the ignition switch if you have intermittant power to the coils and grounded points if you always have good power to the coils.
Old 09-24-2010, 01:44 PM   #15
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
Your original post said that the bike lost spark and idiot lights so I would think that Beemerguru and matman1972 are on the right track. Check either the main supply wires from the battery, starter relay to the ignition switch or the main grounding points. Best of luck.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Times are GMT -7.   It's 02:08 AM.
