Old 09-24-2010, 01:56 PM   #16
Caddy82rats OP
Caddy82rats's Avatar
Oddometer: 1,180
sorry, I would say that starter idiot lights etc are OK, but no spark on plugs
To resume :
All electrics Ok except ignition
Caddy82rats is online now   Reply With Quote
Old 09-24-2010, 02:05 PM   #17
Caddy82rats OP
Oddometer: 1,180
Originally Posted by Beemerguru
Sudden stop with no warning?
Yes no warning at all except 2 seconds ignition on highway, and after all return normal
One other day no ignition when driving, park on sidwalks clean a spark plug, and after that, the bike start again, this was maybe one month before.
Check the battery
Battery is a 6 month Bosch with 13V, so OK
Check for a short
Yes... That's what I try to find !
A bad coil won't affect the other systems
I think also, but with the 1979 coils fom my RS I've got small spark but spark
I think there is a short cut somewhere
Old 09-24-2010, 02:09 PM   #18
Caddy82rats OP
Oddometer: 1,180
Originally Posted by matman1972
Not saying that is your issue, but positive wire coming from diode board out the top of the timing/charging area was what did it both times for me. casing had melted, and when the wire jimmied itself against the aluminum, no power whatsoever.
An other interesting check to do ! Thanks
Old 09-24-2010, 07:47 PM   #19
OldAndBusted
Needs a little work...
OldAndBusted's Avatar
Oddometer: 385
you got the wrong bmw! those fancy new fangled things like you have with all their electronic wizardry and fuel injection and ABS and traction control always break down. get a /2
OldAndBusted is online now   Reply With Quote
Old 09-24-2010, 08:07 PM   #20
red bud
alky w/motorcycle problem
red bud's Avatar
Oddometer: 5,575
if it's got tits or wheels you'll have trouble with it
"if your not outta gas, your not lost" BDXMPL
"red bud has anyone ever told u you're bit of an ass" bmwblake
http://www.advrider.com/forums/showthread.php?t=706516
red bud is offline   Reply With Quote
Old 09-25-2010, 12:30 AM   #21
Caddy82rats OP
Oddometer: 1,180
I was knowing for tits...
For wheels I was thinking "wen she anoy me I can switch off ignition"... But she had understand that she can anoy me at switching of ignition by herself...
I'm going to call her Christine
http://en.wikipedia.org/wiki/Christine_%28novel%29
Old 09-25-2010, 01:08 AM   #22
fishkens
Further...
Oddometer: 5,147
Oh yeah, they both know how to turn their own ignitions off all by themsleves. No fiddling on our part needed. Just shows to go you who's really in charge.
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 09-25-2010, 01:22 AM   #23
Caddy82rats OP
Oddometer: 1,180
Are you sure ?
For the bike, I'm sure but for some whomen, I've newer hear she sound of silence, those litel moments of calm...
Old 09-25-2010, 03:11 PM   #24
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,417
Uh, he's go an R90S. No fuel injetion, no ABS none of the stuff you list. Not much different from your slash two really.
Go far or stay home.
durtwurm is offline   Reply With Quote
Old 09-25-2010, 05:51 PM   #25
man on the mule
MAN ON THE MULE
man on the mule's Avatar
Oddometer: 40
Laugh r90s lonely syndrome
Little known but deadly. The bike is just lonely . I talked to my old g/s and my /6 and they both offered to help. I will even chip in and pay the freight. Just let me know and I will be glad to help by clearing a space for that poor old ragged r90s in my garage..:)
Man on the mule ,STOCK = no imagination
man on the mule is offline   Reply With Quote
Old 09-26-2010, 02:17 PM   #26
Caddy82rats OP
Oddometer: 1,180
I really apreciate your help offer
But my G/S and my RS have also to learn sharing
Old 09-28-2010, 11:42 AM   #27
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,417
Hey Caddy! Keep us posted. Let us know when you get 'er goin'!
Old 09-28-2010, 01:30 PM   #28
kbasa
Colnago!
kbasa's Avatar
Oddometer: 68,355
There's a short jumper that connects the coils. Check to make sure you have continuity across that jumper or you won't be going anywhere.
I had this issue with my R100 and it was a pain to troubleshoot. I found it by measuring voltage at the incoming primary on each coil. I had it on one, but not on the other, which made me test the jumper.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 09-28-2010, 02:24 PM   #29
Caddy82rats OP
Oddometer: 1,180
Some work done...
I've changes the 2 coils
Checked the jumper between the 2 coils
Added a ground wire between diode board and betterie.
Checked all conexion
So to be honest I haven't really found where was the problem but now this works.
Today after maybe 5 hours of battery charging, the engin crank verry slow (12.57V on battery terminals)..., 2 hours charging after with a car charger the engine start. I suspect a battery problem (Thats a 1 year Bosch).
Old 09-28-2010, 04:21 PM   #30
shreds
Oddometer: 61
Battery
It's always the battery...
shreds is offline   Reply With Quote
Times are GMT -7.   It's 09:50 AM.
