Old 04-08-2011, 07:56 AM   #151
Chris K
Chris K's Avatar
Oddometer: 775
Bon Voyage Dawg!
Chris K is offline   Reply With Quote
Old 04-08-2011, 04:47 PM   #152
snoopy OP
Oddometer: 265
Well I'm back!
Reached Wetherby and the rear engine bracket fractured all the way across. Had to trundle back up the A1 at 30, using a ratchet strap to keep the engine in.
I also have an issue starting the bike when it's been ran for a while, with exhaust fumes going through the air filter (plumes of white smoke). It blew the paper filter to bits.
Throttle is way to hard and hurts wrist keeping it at 55. I've tried lowering the spring and bought a "thumb throttle" with hope it'll help.
Determined as ever, the engine came out this evening as me and neighbour made a new bracket using same stuff as the front one. I'll re-try tomorrow.
RTW on a Honda PCX Scooter soon.
http://www.andrewcharnley.com
snoopy is offline   Reply With Quote
Old 04-09-2011, 03:39 AM   #153
snoopy OP
Oddometer: 265
Here goes everything ... attempt #2.
Delayed as the exhaust had fractured and required welding...
Old 04-10-2011, 11:34 AM   #154
Chris K
Chris K's Avatar
Oddometer: 775
Did the Dawg make it to Dover??
Old 04-11-2011, 01:28 AM   #155
snoopy OP
Oddometer: 265
I am in lyon alternator fell off at leeds but working despite daamage. Only doing 50 throttle too hard on wrist must have spring wrong. Rear tyre and chain damaged tring to get em replaced. Seal on prim drive failed i have no oil in clutch. Engine continues to try starting backwards. Spent more on toll roads than fuel
Old 04-11-2011, 03:33 AM   #156
Sibbo
Oddometer: 358
Snoopy , a new definition of persistence ! I recommend a nice new DC inverter welder for Christmas .
Sibbo is offline   Reply With Quote
Old 04-11-2011, 09:48 AM   #157
Packer
Packer's Avatar
Location: Scotland, wonderful biking when it's dry (rarely)
Oddometer: 333
Snoopy, you'll remember the various parts of this trip by the breakdowns
Good on you for trying, better still for succeeding!
Packer is offline   Reply With Quote
Old 04-12-2011, 12:26 AM   #158
snoopy OP
Oddometer: 265
Now in Nice . My mate thought it would be funny to spend the first night in a hostel (room has 12 blokes in it)...
Strange noises coming from the primary drive casing. I have turned music up to compensate.
Split link on chain has been wearing through the casing so I reversed it. Front brake has turned to absolute shit. Found a dealer and hope to get the oil leak sorted as everything is covered.
Still I made it.
Old 04-12-2011, 12:38 AM   #159
Sibbo
Oddometer: 358
That front brake will never be as good as a disc but the Hitchcocks website has a pdf on a pretty easy way of setting it up .I did it on mine and it improved it heaps .A well set up twin leading shoe can be just fine .
http://www.hitchcocksmotorcycles.com/technical-notes
Old 04-12-2011, 10:49 AM   #160
snoopy OP
Oddometer: 265
Did that before I left. Still crap.
Today the air filter bracket weld failed. Cable tied and electrical tape came out...
The oil leak I investigated further. The gearbox is on a pivot and bolted to the engine but the top of the gearbox (and the rear frame) can flex towards the engine a little - the flex comes from the primary drive chain which does it on the compression cycle. If I had of bolted through all four gearbox holes instead of just the bottom it would have been much better, but still not good - a spacer between the engine and gearbox (top part) needs to be made to prevent the clutch seal eventually blowing (as mine has). Should get the problem fixed tomorrow.
Nice is a great start. Tomorrow Monaco.
Old 04-12-2011, 10:55 AM   #161
Chris K
Chris K's Avatar
Oddometer: 775
You'll get more attention on your bike than any of the glitterati in their Lambo's.
Old 04-12-2011, 03:43 PM   #162
Sibbo
Oddometer: 358
Strange , mine wasn't great but it worked Ok and a lot better after the mod .Maybe better linings ?
Old 04-12-2011, 07:15 PM   #163
Ash
UFO Pilot
Ash's Avatar
Oddometer: 469
great stuffs snoops!
RESPECT.
Ash is offline   Reply With Quote
Old 04-13-2011, 11:35 AM   #164
Farmer Palmer
Farmer Palmer's Avatar
Oddometer: 254
Nice is nice! Any photos of this epic journey?
FP.
13 G650GS Sertao, 11 G650GS/FL, 10 R1200GSA30 Desierto 3
Farmer Palmer is offline   Reply With Quote
Old 04-13-2011, 12:34 PM   #165
snoopy OP
Oddometer: 265
Here's one...
Times are GMT -7.   It's 05:59 PM.
