Old 03-25-2011, 02:39 PM   #226
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,774
fwiw, you can get "bronze wool", which we use on boats, since little shreds of steel make for gazillions of rust spots on salt water boats....
also, stainless steel wool is available.
just in case.
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 04-08-2011, 06:07 PM   #227
crazydrummerdude OP
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,604
So, I've got a couple bucks for once.
What should I buy (from Hucky's) for my /2's that I will for sure need soon? So far, I have:
-sidecar bars,
-front, rear, and sidecar tires,
Are there any "Oh, you're totally going to need a _____" items you can think of?
That reminds me. On my R60, I have aluminum wheels. On my BMVW and sidecar, I have steel wheels. I've heard (maybe in this thread) that I should have all the steel wheels on the sidecar rig. So, should I swap the aluminum ones on the sidecar rig with the steel ones on the BMVW?
Two aluminum + one steel:
Two steel:
(Actually, two of the tires on steel wheels still hold air. I'd be willing to save some money and keep them during the resurrection process, rather than letting a brand new set get hard and dry from sitting. (Note: I didn't say I'd be riding cross country on the old tires. Just keeping it rolling so I could do a lap around my field or something.))
crazydrummerdude is offline   Reply With Quote
Old 04-14-2011, 05:01 PM   #228
crazydrummerdude OP
Wacky Bongo Boy
Oddometer: 7,604
-sidecar bars,
For the R60, I ordered Metzeler K sidecar tire/tube and sidecar (wide) handle bars. For the BMVW, I ordered headlight ignition switch cover pieces (the pieces on the outside of the headlight shell). For my /6's, I ordered a few doo-dads. Lately, I've been putting more money/parts into my Japanese dirtbike collection. Blasphemy!
Old 04-15-2011, 09:00 AM   #229
davef
The Chief
davef's Avatar
Oddometer: 320
Absolutely put all the steel wheels on the sidecar rig. Sidecars tend to put a lot of lateral forces on the wheels when turning. Aluminum rims would fold sooner under those forces.
The metzler K's are nice, but damn expensive. Since I know you live for deals, you should look at the Duros. I have a set on my rig, and they seem to hold up fairly well. They do have a lower speed rating, but I highly doubt the rig will exceed their 90mph rating.:
http://www.heindlengineering.com/Onl...ecar_parts.htm
Dave F
"My greatest fear before I die is to turn into a boring old fart."
davef is offline   Reply With Quote
Old 04-15-2011, 10:52 AM   #230
crazydrummerdude OP
Wacky Bongo Boy
Oddometer: 7,604
Thanks for the info on the wheels. Looks like the Duro is $15 cheaper than the Metzeler. How long does one last with "normal" use?
Old 04-15-2011, 01:04 PM   #231
davef
The Chief
davef's Avatar
Oddometer: 320
I don't know yet how long they'll last. This is my first set. I have over a 1K on them so far and they still look new.
Dave F
Old 04-15-2011, 06:17 PM   #232
danedg
Horizontally Opposed
Oddometer: 6,542
This is a rhetorical question right?
Just start saving for a complete engine, tranny and rear drive build.....after that, then you'll be needing a few more odds and ends.....
Just a reminder, ride every chance you get. You just don't know how soon it can be taken from you. T.Low
danedg is offline   Reply With Quote
Old 04-15-2011, 06:28 PM   #233
photomd
photomd's Avatar
Oddometer: 718
Well....post up some Japanese dirtbike stuff. RTWdoug is shipping out and you're not posting anything. What the heck are we supposed to read?
1979 V-1000SP
1988 R100RS
1996 R1100RSL
1998 CR250
photomd is offline   Reply With Quote
Old 05-01-2011, 10:03 PM   #234
crazydrummerdude OP
Wacky Bongo Boy
Oddometer: 7,604
Some bad news today.. I took the ape-hangers off.
I was able to slide everything off with little fanfare. I polished one handlebar mount up (as best as I could) and left the other one untouched for a picture.. but I didn't bring a camera.
The left grip had a surprise*. Someone cut down a dowel and shoved it in the end of the handlebar since the grip wouldn't go all the way on before the bend. Also on that side, the wedge/perch/whatever-it-is was missing and in its place was a wedge-shaped piece of broken plastic. I cleaned and greased the lever and set it aside. The right side grip had the wedge/perch, but was missing the wave washer on the top of the lever inside the grip and the nut/washer on the bottom of the pivot bolt. I cleaned it fairly well, removing the black hard grease from the throttle disc gear(s).
I then un-electrical-taped the two wires for the switches.
Also, after primer, I rattle-canned the battery tray and lower tank mount.
A little at a time. I'll get some more done in a week.
*Actually, who knew BMW used Japanese grips? Ha! One more thing to add to the list..
Old 06-27-2011, 12:00 PM   #235
crazydrummerdude OP
Wacky Bongo Boy
Oddometer: 7,604
This is what Scotchbrite does to severe rust (before/after):
Edit: Cumminsman76 told me I have way too much patience.
Since the ape-hangers were so tall, someone spliced in an extra 1' of wire to each control. I took the extra off. I figured it wouldn't be any worse than before to just put the wires back together and electrical tape them.. until I feel like buying new harnesses.
I had never seen electrical tape make wires so sticky before. It was a slimey mess.
I put the wide sidecar bars on it. I can roll it around easily, again.
I am polishing up the sidecar wheel in preparation for the new rubber I have waiting. I tried to cut the old tire off, but the bead is pretty tough. I'll try again.
crazydrummerdude screwed with this post 06-27-2011 at 12:07 PM
Old 07-22-2011, 02:34 PM   #236
crazydrummerdude OP
Wacky Bongo Boy
Oddometer: 7,604
I got titles for both of my /2's!
Old 07-22-2011, 06:35 PM   #237
Whitey1
"Whitebread"
Whitey1's Avatar
Oddometer: 10,129
We need more pics. I am subscribed to several of your threads and I have no clue how you find time for them, but I applaud you.
Whitey1 is offline   Reply With Quote
Old 07-22-2011, 07:58 PM   #238
crazydrummerdude OP
Wacky Bongo Boy
Oddometer: 7,604
The threads I have cover only about 1/3 of my projects.
During my entire time on this forum, I had been in school full time to become a rocket surgeon, and half the time I was running my own business.. and I played drums in a couple shows. Now that I've graduated and on Monday will accept an official rocket surgery job, I will have time and most importantly.. a constant source of money for my projects.
Expect much more progress in the near future.
Old 07-22-2011, 08:10 PM   #239
RAGBrian
jonesing for a ride
RAGBrian's Avatar
Oddometer: 1,013
Congrats on the job! I like that description "a rocket surgeon"
RAGBrian :: NC700X ::1978 CX500 Standard :: 1976 CB360T ::
"Going where you don't belong, I decided a long time ago, is the root of all misery and the soul of all adventure." - Peter Egan
RAGBrian is offline   Reply With Quote
Old 07-22-2011, 08:35 PM   #240
melville
melville's Avatar
Oddometer: 1,453
Woo Hoo! Didja get tltled in Missouri or Mizzourah?
Call me Mel. Some years ago- never mind how long precisely- having little or no money in my purse, and nothing particular to interest me at home, I thought I would ride about a little and see the other parts of the world. It is a way I have of driving off the spleen and regulating the circulation.
melville is offline   Reply With Quote
Times are GMT -7.   It's 02:47 AM.
