Old 10-02-2010, 07:38 AM   #16
x3300
geoff
Oddometer: 170
Originally Posted by fishkens
I mean, do the pistons really care if the guys on the one side of the are a little bit deeper in their bores and the fellows on the other side are a little bit prouder in their bores?
Just for anyone interested, pressure in hydraulic systems was explaned by Bernoulli:
Bernoulli's principle
Relationship of Force Pressure and head
-x3300
x3300 is offline   Reply With Quote
Old 10-02-2010, 07:46 AM   #17
bikecat
bikecat's Avatar
Oddometer: 1,122
Made the mod to my K75. Used the same master cylinder. Shimmed down the caliper and enjoy much better braking power. The key is the mounting points; they are similar, I think 65mm eye to eye if I recall correctly.
Can post pics if anyone is keen.
Originally Posted by Christos 1983
i am an owner of a bmw r100gs p-d.i have change the standard calliper with a 4-piston nissin from gsxr 750,i have put metal brake lines and a brake disk from cbr 900.now i have stronger brake but i have more 'travel 'in the brake lever...i want to change the master cylinder to reduce the 'travel' and make the brake feeling more instant.From what bike can i put?the master cylinder from a 1100-1150 is suitable?
thanx guys!
sorry about my english but i am from greece and i have not practised them for a long time....
Christos, I think you are better off playing with spacers, springs and oil than changing a master cylinder. Nothing wrong with your English! :)
Cheers
bikecat screwed with this post 10-02-2010 at 08:01 AM
bikecat is offline   Reply With Quote
Old 10-02-2010, 08:19 AM   #18
Christos 1983
Oddometer: 10
bikecat i have read threads you have started and i have seen that you are an owner of a r100gs '88.
i have made the following modifications:
1.front usd wp forks from ktm lc4,top yoke from suzuki rm 125/250,lower yoke from ktm lc4 too.ihave made spacers to fit gsxr's caliper.I have left the standard bmw wheel rim and axle.
2.rear shock ohlins
3.renthal fat-bar
With the ohlins and the usd wp i have enormous better handling.But the brake feeling is something i want to upgrade.
i am concerning about my english because i live in Greece and first time i write at a universal forum.
Christos 1983 screwed with this post 10-02-2010 at 08:45 AM
Christos 1983 is offline   Reply With Quote
Old 10-02-2010, 08:33 AM   #19
Toyanvil
Toyanvil's Avatar
Oddometer: 1,687
You guys got me thinking, for some reason my front wheel is dished to the right side 5 mm. I was thinking, I could install the Brembo caliper and change the wheel spacers. This would center my wheel and the caliper would bolt right up, right?
2004 BMW 1150 GS-1993 BMW R100GSPD-2009 Yamaha TW200 1961 Sunbeam Alpine.
Life is like riding a bicycle, to keep your balance you must keep moving.
Some people try to turn back their odometers. Not me, I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. Hell, some of the places I’ve been there weren’t even roads!
Toyanvil is offline   Reply With Quote
Old 10-02-2010, 10:15 AM   #20
fishkens
Further...
Oddometer: 5,149
-x3300
Thanks for the links.
So, centering the caliper perfectly over the disc is not needed to equalize pressure but, depending on the depth of the cylinders and other clearances of the caliper relative to the disc, spokes, etc., it may be needed to allow new pads to be fitted or to keep the disc, spokes, etc. from rubbing on the caliper.
That's what I was thinking but I was interested to hear if that thinking was correct.
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 10-02-2010, 10:34 AM   #21
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,813
Christos - there are other master cylinders available for the G/S, 12-13-14-15 mm bore but they don't have the bonjo fitting like the R100GS, a straight thread in fitting like what's found on the G/S.
Plus using a G/S type MC you'll need to change the brake lever mount.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 10-02-2010, 10:51 AM   #22
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,285
Originally Posted by One Less Harley
...Plus using a G/S type MC you'll need to change the brake lever mount.
The GS used the G/S-style master cylinder through 1990. After that, AFAIK, you can only get them in 13mm and 15mm for the K-style controls.
Are you sure the MC is threaded differently for the banjo bolt vs. the straight-in hose? I've never run into that as a problem. Then again, I rarely work on G/Ses and I can't recall ever reinstalling one of those ancient straight-in hoses on a new MC.
Old 10-02-2010, 10:54 AM   #23
Christos 1983
Oddometer: 10
you mean magura master cylinder from other bmw bikes..master cylinder 15mm had bmw r80 g/s 81-88 and paralever 88-90.i have a gs pd '91.I don't know if is suitable m/c from 1100/1150 models
i have thought to put master cylinder from japan sbk(i wonder if anyone did this so i will have a ready and trusty modification) ...i will have problem with the right standard hand guard because is screwing on the fluid reservoir..but i will change it with Acerbis.
please help,modifications in 2-valve bmw are not famous in Greece..
Old 10-02-2010, 11:29 AM   #24
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,544
Would that change the tracking, i have never checked my tracking on the GS, does a GS front an rear wheel line up in a straight line like most bikes?
Edit. the motor also sits closer to that side, i would guess the Final drive is also set off to the right, mmm questions for the guru's.
ChromeSux is offline   Reply With Quote
Old 10-02-2010, 01:49 PM   #25
AntonLargiader
Oddometer: 4,285
...i have a gs pd '91.
You don't have any bolt-up options. You already have the 13mm which is the smallest. If you want smaller, you could have your existing MC sleeved down and use a 12mm piston because I think the it is the same basic configuration as the 13mm one you have.
Old 10-02-2010, 04:26 PM   #26
One Less Harley OP
Oddometer: 4,813
"Are you sure the MC is threaded differently for the banjo bolt vs. the straight-in hose? I've never run into that as a problem. Then again, I rarely work on G/Ses and I can't recall ever reinstalling one of those ancient straight-in hoses on a new MC."
The banjo bolts at the bottom, but I believe the thread is that same.
Aton, you should have those fork caps soon, if not already,Thanks
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 10-02-2010, 04:38 PM   #27
AntonLargiader
Oddometer: 4,285
Anyone have a picture of that? It's on the bottom for the K controls, but I've never seen the type we're talking about with anything but a side fitting.
My '88 had a straight-in hose and now it has an aftermarket one with a banjo bolt. Same MC.
Old 10-02-2010, 05:30 PM   #28
FR700
Heckler™©®
FR700's Avatar
Oddometer: 8,034
something to think about ...
It would appear that he is having the same experience that I had when I changed from dual twin pots ( Brembo ) to four pots ( Brembo ) and kept the original master ~ too much lever travel .Went from a thirteen to a twenty ,problem solved .The master needs to shift more fluid for the travel to retain the same 'feel' = bigger master .
I'm diagonally parked in a parallel universe.
FR700 is offline   Reply With Quote
Old 10-02-2010, 05:40 PM   #29
fishkens
Further...
Oddometer: 5,149
A 20mm master cylinder? Where does that MC/caliper combination fall on the chart below? Just curous because 20mm sounds big.
Or maybe I misunderstood your post.
http://www.vintagebrake.com/mastercylinder.htm
Old 10-02-2010, 05:51 PM   #30
FR700
Heckler™©®
FR700's Avatar
Oddometer: 8,034
I ride a K100 .The twenty came from a K1100 .I used the forks ,front wheel and brakes from an 1100 but didn't have a servicable front master .Brakes were nice ,but the lever comes back nearly to the bars .Swapped masters for a K1100 and all is good ... except that now my 'flip-a-lever' cruise control will not work .
Was just reading the thread regarding front floating rotors ... a K100 rotor ( four bolt ) has the same bolt spacing and back spacing as an R80/100 G/S .Direct swap/interchange
Times are GMT -7.   It's 06:28 PM.
