Old 10-02-2010, 05:55 PM   #31
fishkens
Further...
Oddometer: 5,149
Ahhh, twin discs. My head was all caught up in a single disc paradigm.
Thanks.
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 10-02-2010, 05:57 PM   #32
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,728
I checked the location of the caliper to the rotor and it lines up perfect!!!
So now to get the other five machined!!
Looks pretty good....
Galfer Green pads will be in Monday, not sure about the stainless brake lines.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 10-02-2010, 06:16 PM   #33
FR700
Heckler™©®
FR700's Avatar
Oddometer: 7,757
Nice .
I'm diagonally parked in a parallel universe.
FR700 is offline   Reply With Quote
Old 10-02-2010, 07:28 PM   #34
Mike in NJ
Mike in NJ's Avatar
Oddometer: 46
I am definitely interested in one of them once you get it all sorted out!
'93 R100GS
Mike in NJ is offline   Reply With Quote
Old 10-03-2010, 02:06 AM   #35
950slider
Oddometer: 118
Laugh Been There, Done That...Works Well!
Easy conversion with easy access to replacement pads. I believe I took 4mm off of the caliper ears which is close to your measurement to center up the caliper to the rotor. I also used 'easy on the rotor' EBC pads.
950slider is offline   Reply With Quote
Old 10-03-2010, 07:46 AM   #36
C Squared
Now with TURBO!
C Squared's Avatar
Oddometer: 7,214
I think that is pretty much it.
Originally Posted by fishkens
Thanks for the links.
So, centering the caliper perfectly over the disc is not needed to equalize pressure but, depending on the depth of the cylinders and other clearances of the caliper relative to the disc, spokes, etc., it may be needed to allow new pads to be fitted or to keep the disc, spokes, etc. from rubbing on the caliper.
That's what I was thinking but I was interested to hear if that thinking was correct.
I can explain it to you, but, I can't understand it for you.
C Squared is offline   Reply With Quote
Old 10-04-2010, 11:39 AM   #37
One Less Harley OP
Oddometer: 4,728
Five sets of Galfer green (FD198G1532) pads just arrived, the machinist got the ok to machine the calipers. Notice the spring for the brake pin, helps keep the pads from squeaking.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 01-08-2012 at 08:10 AM
Old 10-05-2010, 12:36 PM   #38
kbasa
Colnago!
kbasa's Avatar
Oddometer: 69,611
One Less Harley: If this is a product you intend to sell, this thread should be in Vendors.
I doubt you have either:
a) 5 GSs
b) 5 friends that you're working on this with.
Please advise. If this is indeed a sale item and you're building publicity in Old's Cool, I'd be happy to move it over to Vendors for you.
Thanks,
kbasa
friendly neighborhood moderator
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 10-05-2010, 03:35 PM   #39
One Less Harley OP
Oddometer: 4,728
My intentions for the post,
1)to show how to do the conversion and what was needed in case others wanted to do it themselves.
2) get feedback on how well it had worked for others
3) and when it was sorted out to post a link to the vendor section for the 5 calipers and no more. Unless someone wanted me to have one machined. I won’t be making that much on them wanted to do one just for the heck of it. When I found 6 calipers at a good price I figured it’s just as easy to do one as six and probably cheaper.
I didn't feel this was out of the scope of posting in this section or against the rules until I started to sell them at a price. There is also a post in old school for the brake adaptor which a member was selling and people posted what they had done w/ it. I felt this was the same.
I would like to keep the post here for the peoples comments on the conversion and also here so others can do it themselves if they want.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 10-05-2010 at 03:56 PM
Old 10-06-2010, 05:23 AM   #40
mtiberio
mtiberio's Avatar
Oddometer: 88
You can certainly machine what is a rare caliper to get the 4 pot brakes you want, or you can get a bracket to fit the 4 pot caliper to the standard Brembo F08 mounting lugs. I did this on the front of my Guzzi Disc Brake Eldorado. This has the side benefit of allowing you to shim the rotor over the center of the caliper either in or out depending. Shims between the caliper and bracket move the caliper inboard, shims between the bracket and fork leg move the caliper outboard. The adjusting shims are a standard Guzzi part. The bracket is available from guzzitech.
mtiberio is offline   Reply With Quote
Old 10-10-2010, 05:56 PM   #41
One Less Harley OP
Oddometer: 4,728
a shameless vendor plug- all the parts are in now, please check vendor section if interested.
http://www.advrider.com/forums/showthread.php?t=627723
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 10-12-2010 at 06:40 PM
Old 05-13-2013, 04:36 PM   #42
johnalex
Rider of rides.
johnalex's Avatar
Location: Los Angeles, CA, USA l Todos Santos, BCS, Mexico
Oddometer: 52
Just ordered a set of EBC CFA407HH pads.
My question is, is the master cylinder sufficient for the 4 pot Brembo?
JohnA in LA
85 RZ500 - Tricked out
00 Pegaso - SOLD - 01 RSVR - SOLD
98 VFR - 133,000 miles
89 BMW R100GS - in Mexico
johnalex is offline   Reply With Quote
Old 05-13-2013, 08:26 PM   #43
lesman
Live easy, Brake Hard
lesman's Avatar
Oddometer: 641
Yep, I then went to a 6 piston Tokico setup on my GSPD.
Bigger and better.
I still have my 4 piston caliper setup. I powdercoated it.
I'm interested in selling it
Les
Obsessive compulsiveness always trumps good sense.
lesman is offline   Reply With Quote
Old 05-14-2013, 05:10 AM   #44
orangebear
orangebear's Avatar
Oddometer: 1,253
my r100gs has been fitted with a 4 pot brembo caliper from a r100r it good
it will need split and rebuild as one pad wears fast then the other.
suzuki gsxr 600 srad sound fun bike
bmw r100gs i sold as it be came to unreliable.
road legal stomp pitbike sold
Klr 650 the worst ever made
Honda xl125rc powered by a cg125 block fun wee bike
orangebear is offline   Reply With Quote
Old 05-14-2013, 01:24 PM   #45
One Less Harley OP
Oddometer: 4,728
Try the MC that you have first see if it is acceptable to you, if not look under my sig and see what I used..I don't remember, maybe a 12mm?? Motobins was cheaper than the US dealer.
Do not split your calipers for a rebuild..you've been warned..they can be rebuilt without splitting.
If you want to sell your caliper then you should post in fleamarket not here. I found this 4 pot at good as the 6 pot Harrison, far cheaper when figuring pads. The brembo is an easy swap plus uses OEM BMW parts, that's a plus in my book. The 6 pot has a lot of material and leverage on the mounting tabs, a minus in my book in case of an accident..think about that one.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Times are GMT -7.   It's 09:58 PM.
