01-05-2011, 08:01 PM
#181 | |
Oddometer: 344
a hole saw notcher works well for cutting the fish mouth. (I have the harbor freight one it works and is cheap ~$35) If you plan on doing a lot of 1 3/4 you may want to do a hydro conversion and add one of these http://www.tubebandit.com/xcart/prod...roductid=16133 as well as the bend tech software.
KTM RFS/SXF hybrid http://advrider.com/forums/showthread.php?t=662808 CR500/KTM hybrid http://advrider.com/forums/showthread.php?t=757835 |
01-11-2011, 11:35 AM
#182 |
moto junkie
Oddometer: 1,637
More pics...
![]() Corner welds on bags finished and smoothed with a grinder, 3 coats of black rattlecan inside and out. Satin black was a bit too shiny for me, so I knocked it down a bit with a scotchbrite pad. Hardware and weatherstripping installed on bags. The bottom mount is made from 3/4" x 1/8" angle (old supports from the shelving unit going to the dump) welded back to back to make a "Z". I had orginally planned on using the turn signal stalk for the top mount to hold everything together. I decided that the hollow signal shaft wasn't strong enough, so I extended the signals back by themselves, and used a 3/8" through bolt where the turn signals used to be. I also started fabbing a rear rack to tie into the upper mount. ![]() Some 3M reflective orange tape to finish things off. The steel bags weigh 13lbs each. That's 5lbs heavier per side compared to aluminum bags 1 to 2 inches bigger per dimension. 33 is the magic number once again. 26lbs of steel bags + 7lbs. of DOM side rack. The KLR has 16lbs. of aluminum bags and 17lbs of 1" square tube rack. Pretty funny how that worked out. Maybe my next set will have light racks and light bags. Third time's a charm. I learned something on both set of bags, and I learned something on both racks. ![]() I use the last bit of 5/8" DOM I have on hand for the rack. I still need to weld in a provision for threads to attach a future aluminum top box. I'm going to try to make something universal to mount on the KLR and th DR. The DR is getting close to completion, so I needed abother project to keep me busy... ![]() ...an '85 Elite 150 Deluxe with 316 original miles. The last inspection sticker is from '86. It's in a general state of neglect, but I hope to have it roadworthy by spring so the kids and I can have fun on it. I've been working on it while paint dries on the DR project. The scoot is complete, and I've been tearing it apart a little at a time to get rid of hornets nests, mice nests, and stinkbugs! My little girl loves to ride, and her face lit up when I brought the Elite home! This thing will be a ton of fun! kirkster70 screwed with this post 01-11-2011 at 04:30 PM |
01-11-2011, 03:26 PM
#183 |
aka Road Monster
That first piece, the one towards the front of the bike, appears to be crooked. Whats up with that?
01-11-2011, 03:29 PM
#184 |
moto junkie
Oddometer: 1,637
01-11-2011, 03:36 PM
#185 |
aka Road Monster
From the rear of the bike squat down and sight (align) the tops of the other cross pieces with your eyes, the right side looks a little higher than the left.
01-11-2011, 03:55 PM
#186 | |
moto junkie
Oddometer: 1,637
The rear subframe on the bike was tweaked when I bought it. It is a 20 y.o. bike, so that's understandable. I straightened it as best as I could. I also stood the bike up on the lift as straight as I could, and then used a combination of straight edges, levels, and my eye. So I'm sure it's probably a touch off here or there, but it's correct to the eye when all put together. So, the racks are all plumb and level both ways, but don't jive 100% with the tweaked fender. I made slight adjustments for everything to look as "right" as I could. Sometimes on a compound curve a measurement may be 100% correct, but not look right to the eye. I've had that happen a bunch of times. Oh yeah, I'm also a 6 month or so welder! Ha Ha! Soon I won't be able to use the rookie excuse. kirkster70 screwed with this post 01-11-2011 at 04:07 PM |
01-11-2011, 04:01 PM
#187 |
moto junkie
Oddometer: 1,637
![]() Top view of the rear rack. This took me all day. I started blending the top welds with a grinder, a half round file, and a rat tail file. The 4 pieces welded in are for future top case mounting. I will tack a 3/8" nut to the underside. The pieces are made out of 1 1/2" x 3/16" flat bar scrap. It also took some time to shape them to fit just so. They are only welded from the back for a clean look. ![]() It also took some time to blend the mounting tabs with a grinder. Also made from 1 1/2" x 3/16" flat bar scrap. (x braces from the battery racks) The rack will get spraybombed in the am. |
01-11-2011, 04:19 PM
#188 |
aka Road Monster
Since you deal with conduit and such I figgered you would have a good eye for "straight with the world" rack looks good.
Before you paint that thing, and after cleaning so it can be painted, use a rose bud or weed burner, anything to get it a little hotter than you want to handle.then paint it, kinda bakes the paint on. |
01-11-2011, 04:26 PM
#189 | |
moto junkie
Oddometer: 1,637
Oh yeah. You can run a new conduit perfectly straight/plumb/level next to a bank of crooked conduits, and your conduit will look like crap just because it doesn't match - even though it's perfect. Been there plenty of times. Fabbing to a used, trail ridden dual sport is similar, I suppose. |
01-11-2011, 04:33 PM
#190 | |
moto junkie
Oddometer: 1,637
But I agree, sharp corners are not good on the toes. |
01-11-2011, 04:36 PM
#191 |
moto junkie
Oddometer: 1,637
01-11-2011, 04:38 PM
#192 | |
moto junkie
Oddometer: 1,637
01-11-2011, 04:39 PM
#193 | |
moto junkie
Oddometer: 1,637
01-11-2011, 04:43 PM
#194 | |
moto junkie
Oddometer: 1,637
It's rattlecan paint for a reason. It's a dual sport, and it going to get scratched. Easy touch up!
01-11-2011, 04:49 PM
#195 | |
aka Road Monster
Referigerent such as freon also turn to phosgene when they burn. fxstbiluigi screwed with this post 01-11-2011 at 05:03 PM |
