01-11-2011, 04:54 PM
#196 | |
moto junkie
Oddometer: 1,644
All I ever use for prep is a grinder. Period. |
01-12-2011, 05:36 AM
#197 |
Lampin' it
Oddometer: 4,150
Kirkster nice work man!!
In the same file as overkill, I made my JD bender full hydraulic, it was a fun project. Still trying to get lessons in TIG, it's really hard to start from zero. ![]() Oh and if the JD model 3 dies will work on your bender (I think the only difference between ours is the arm thickness?? Not sure) I have a 1 3/4" and a 1" die set. Easy to loan out |
01-12-2011, 06:51 AM
#198 | |
Oddometer: 1,463
I ended up with button head bolts down through the bottom of the box with locknuts on the outside. The bolts go down through holes in the rack, then I run on wing nuts to hold the box down. The wing nuts are safetied in place with R-clips through holes drilled in the ends of the bolts. Off and on fully loaded in a minute or two. Just another option! |
01-12-2011, 12:36 PM
#199 | |
Oddometer: 344
link to mods required http://www.offroadfabnet.com/forums/...ead.php?t=8260 .
KTM RFS/SXF hybrid http://advrider.com/forums/showthread.php?t=662808 CR500/KTM hybrid http://advrider.com/forums/showthread.php?t=757835 |
01-12-2011, 02:42 PM
#200 | |
Lampin' it
Oddometer: 4,150
01-12-2011, 03:17 PM
#201 | |
moto junkie
Oddometer: 1,644
Yeah, I don't think the dies are interchangeable, too bad. I appreciate you wanting to share. Thanks for that. |
01-12-2011, 03:23 PM
#202 | |
moto junkie
Oddometer: 1,644
Hmmm... didn't think about that! Live and learn! My top case (when I make it) will probably just hold my duffel bag I use as a lunch box for work. In that scenario, I don't need to detach the top case. But, since I used 3/8" nuts on the underside, I could probably do a quick detach like you described with 1/4" hardware, and it will pass right through the 3/8" nut. I still have room on the bottom for a wingnut. The only downside I could see to a quick detach system with wingnuts is that your case is unsecured. Anyone can unbolt it and carry it off. Not likely to happen, but there are some real scumbags out there. |
01-12-2011, 03:46 PM
#203 |
moto junkie
Oddometer: 1,644
more piccys!
![]() Top rack painted and reinstalled. New rear signals installed. I had to tweak the rear support a bit, so the paint on it is still drying. ![]() Photos taken on an angle so I don't get my chops busted for something being slightly off. Just kidding, roadranger! Ha Ha! I made the top rack so that it has a grab bar sticking out the rear when a future top case is installed. That will come in handy, I'm sure. If I like it, I'll probably do something similar on the KLR later on. ![]() I'm having a pretty good time making things. I was just thinking today that I have probably broken even on the welder purchase. I was mentally adding things up that I've made, and it's probably pretty close to what I have in the welder, even considering material costs. Selling the V-Strom now doesn't seem like such a bad idea. It's what allowed me to move in this direction, and I'm pretty happy about that. I have less than $120 in the KLR luggage, and I have right around $50 in the DR setup including the top rack. ![]() I decided to go through the fender with the new signals. I also installed a rubber grommet to keep from chafing the wires over time. I soldered and used heat shrink tubing to extend and attach the factory bullet connectors to the new signal wires. So there you have it. Two full sets for less than one set of bags. The mistakes I made on the first set were not repeated on the second set, and the mistakes I made on this set won't be repeated on the third set. Plus, I've used the KLR for less than 1,000 miles with the original set. I want to put some miles on both sets to see what does and doesn't work. Sometimes when something gets put to use, it's a bit different that what you originally thought it should be like. |
01-12-2011, 07:01 PM
#204 | |
Oddometer: 1,463
01-12-2011, 07:33 PM
#205 | |
Lampin' it
Oddometer: 4,150
The ram is an 8 ton harbor freight air/hydraulic Return springs are home depot bolts are either 3/4" or 5/8" grade 8 from fastenall I might have $125 in the setup. and i haven't bent one tube yet
01-13-2011, 07:54 AM
#206 |
"Cool" Aid!
Oddometer: 41,498
Beautiful stuff man! I am inpressed and motivated!
I'll get back to you on a time to come over, looks better on weekends, but every other Friday is good too! Jim
01-13-2011, 04:28 PM
#207 | |
moto junkie
Oddometer: 1,644
Nice job! |
01-13-2011, 04:30 PM
#208 | |
moto junkie
Oddometer: 1,644
Thanks, Jim! Sounds good. Shoot me a pm when you're ready to line something up. I work 4 on and 4 off, so it will eventually line up with your schedule. - Kirk |
01-13-2011, 04:32 PM
#209 | |
Lampin' it
Oddometer: 4,150
The electric/hydraulics are sweet/fast/expensive. Since I might bend a couple tubes a year I went for slow/ghetto/cheap
01-13-2011, 05:34 PM
#210 | |
Oddometer: 344
even if you buy a power pack $350, valve $80, cyl $150 and hoses $75 it's not that bad price wise.
