Old 07-25-2012, 03:53 PM   #751
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Originally Posted by 100mpg View Post
I am not even going to give my thoughts on the color silver. Its your rack.
When you make my set of racks, could you paint them red?
I'm going to paint them like candy canes!
kirkster70 is offline   Reply With Quote
Old 07-25-2012, 03:59 PM   #752
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,565
100mpg is offline   Reply With Quote
Old 07-25-2012, 04:47 PM   #753
EvilGenius
1.5 Finger Discount
EvilGenius's Avatar
Oddometer: 20,319
Never mind caging the trash, build a bear trap!
Screw that!
Build him a minibike!!
"Try turning that burn into torque. Then we're getting somewhere. Riding the potato to work seems quite impractical." - anotherguy
"Never bring a Nerf gun to a shovel fight." - My Brother
EvilGenius is offline   Reply With Quote
Old 07-25-2012, 04:55 PM   #754
100mpg
Self Imposed Exile
100mpg's Avatar
Oddometer: 17,565
Originally Posted by EvilGenius View Post
Screw that!
reminds me of that joke Robert shimmel used to tell his daughter when she asked him how the circus bear kept his feet on the pedals? He said, they nail them to the pedals!
100mpg screwed with this post 07-26-2012 at 09:38 AM
Old 07-26-2012, 10:57 AM   #755
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Screw that!
Old 07-26-2012, 11:14 AM   #756
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
The silver spraybombing is a pretty decent match for the frame.
I work up a quick sketch and get to it. Using more 5/8" x .065" wall DOM tube, I start working on the top rack.
Using some scrap, I eyeball the rack layout.
I bend some back-to-back 90s to serve as a grab bar. It should also protect the turn signals.
After about an hour or so, it starts taking shape.
Now I need to make the supports.
Front, center support made from 1/8" x 1" flat bar bent to shape.
This bolts to the factory fender support hole. I removed the OEM tool bag because it was pretty useless to me.
I make some tabs out of 1/8" x 1" flat bar to attach the rear rack to the lower support. Then I tack on some tube.
Then I use some more 1/8" x 1" flat bar for the front L & R supports. I attach to factory mounting points. I bend an offset in the flat bar using the vice and a hammer.
Getting there. Now I need to finish weld everything, and also weld in some mounting points for a top box, then do another rattlecan job.
I plan on making a long, narrow aluminum top box just big enough for my lunch bag.
Old 07-26-2012, 12:02 PM   #757
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,779
Very nice, though no surprise at all!
Jim
Old 07-26-2012, 08:31 PM   #758
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 8,013
Why all the space between the seat and rack?
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 07-26-2012, 08:42 PM   #759
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Jim
Thanks, Jim!
Old 07-26-2012, 08:46 PM   #760
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
I left room to overhang the top box. I plan on the box overhanging about 2" over the center rectangle on all sides.
All that will be seen of the rack will be the left, right, and rear grab rails.
If I remember correctly, the top box dimensions should be close to 14" W x 18" L. The depth will probably be around 8" or so.
Plus, I was thinking it will help in seat removal by not having the rack tight to the seat.
kirkster70 screwed with this post 07-26-2012 at 08:54 PM
Old 07-26-2012, 09:27 PM   #761
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 8,013
Figured you had a reason. Just too impatient, I guess.
-DustyRags
Old 07-26-2012, 09:41 PM   #762
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
It never hurts to ask.
Old 07-28-2012, 06:42 AM   #763
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
All welds finished with the MIG. I weld in some 1" x 1/8" flat bar for the future top box mounting. I welded a 3/8" nut to the underside. I got a little sloppy with one of the hole centers. Oh well, the box will cover it and will likely be on the bike all the time.
Top rack tips the scales at 5lbs. The lower support is 3lbs. I used exactly 16' of tube combined. You can see where I had to scab in a small piece in the rack.
Now I need to dress up a couple of welds and break out the rattlecan. I'm pretty happy with the majority of the welds.
I just came off night shift and I'm supposed to be in bed. Maybe I'll have more to show tomorrow...
kirkster70 screwed with this post 07-28-2012 at 06:47 AM
Old 07-28-2012, 10:50 AM   #764
mnd
mnd's Avatar
Oddometer: 1,073
Building out of 1/2" EMT would save you ~3.5lbs. I've found it plenty durable for racks and such.
Map of Northern Virginia Tag-O-Rama
My NoVA Dirt map.
mnd is offline   Reply With Quote
Old 07-28-2012, 04:31 PM   #765
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
I think 1/2" EMT would be fine just for a small rack, but if I decide to actually take it in the woods and the bike takes a fall, that EMT won't hold up to that very well at all.
I wanted it to have more strength so that all three grab rails are actually functional for picking up the bike when down, or dragging it out of a mud hole if stuck. I don't think 1/2" EMT would fare very well for that purpose, either.
Times are GMT -7.   It's 08:16 AM.
