Old 10-13-2010, 12:57 PM   #91
groundrules
groundrules's Avatar
Oddometer: 1,655
Originally Posted by hilld
I didn't think that you could powdercoat aluminum as it is not magnetic. We have always anodized aluminum if you wanted to coat it with something. Maybe there is a new way of doing, I would like to know about it.
My understanding is that it doesn't have to be susceptible to magnetism, just has to carry an electric charge.
groundrules is online now   Reply With Quote
Old 10-13-2010, 03:53 PM   #92
the kaz
has become "FERAL"
the kaz's Avatar
Oddometer: 1,684
We have been selling Ambulances that have the entire aluminum body powdercoated YUP the factory has one big assed oven
They only started doing full bodies four years ago but before that they have been doing doors and parts for decades.......not cheap but worth it in the long run.
< spell cheqeur is bustimicated >
the kaz is online now   Reply With Quote
Old 10-13-2010, 04:40 PM   #93
showkey
Oddometer: 1,895
Mostly correct..........nothing to do with magnets............the item being coated needs a slight charge and is cured with heat................they can powder coat just about anything that can be charged and withstand some heating....... examples: nowdays wood and wood products are often powder coated.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey screwed with this post 10-14-2010 at 06:56 AM
showkey is offline   Reply With Quote
Old 10-14-2010, 11:07 AM   #94
hilld
riding isn't an addiction
hilld's Avatar
Oddometer: 268
Always good to get more educated. Thanks for that info.
Every day is a new day
hilld is offline   Reply With Quote
Old 10-14-2010, 12:18 PM   #95
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Originally Posted by the kaz
OK I am impressed
and my welding gear has never looked that shiny
It's funny to look at the first photo of my table, and look at it after 3 mos. It's getting pretty smoked up!
So is everything else. I have holes and burn marks in everything!
kirkster70 is offline   Reply With Quote
Old 10-14-2010, 12:33 PM   #96
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
More piccys...
I use 900 to prep, then I scuff with 80 grit dry sandpaper, then clean up with 901.
Dishsoap is actually one of the best degreasers you can use, but 900 and 901 evaporate very fast so you don't have to wait for it to dry.
I mix the bedliner well, then start dabbing the seams with a 2" disposable brush. Make sure to mask off the mounting holes on the exterior.
Then I use a 3" trim roller to apply the first coat.
The instructions say to wait 1-2 hours for the second coat. While I'm waiting, I fab up and paint some rear turn signal relocation brackets out of 3/16" x 1 1/2" flatbar.
Second coat applied and waiting to dry. Once all dry I will clean up the excess on the lip underneath.
Brackets are dry, so I mount the signals. I moved them straight back 2 1/4". Luckily, I had rewired my whole bike (due to poor wireharness routing from the factory) and mounted the signal connectors under the seat for protection. When I did that, I had to extend everything, so there was plenty of slack without having to re-do the wiring.
Tomorrow will be another trip to the hardware store for some 3/8" panhead bolts to remount the lower support.
Old 10-14-2010, 10:34 PM   #97
Iwantabikesobad
Iwantabikesobad's Avatar
Oddometer: 1,071
reply
Awesome job. Looks like you have the tool side of things covered.
Take a look at these, I have one and really like it. Yes it really does what they advertise.
It might be a way for some of you to get into welding with less expense.
http://www.cut-like-plasma.com/
Good safe riding to all.
Yes it's my Bike, No I wont help ya move!
Proud member of Father & Daughter riding club
09 KTM Adv. The Orange ones are faster!
Iwantabikesobad is offline   Reply With Quote
Old 10-16-2010, 09:21 AM   #98
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Niiiice torch! Definately on the want list as well.
Old 10-16-2010, 09:47 AM   #99
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
The bags are finished, so I start back on the low buck lift.
End supports from the lift and base are cut out of the way and preliminary framing for the base begins.
I finally run out of my very first 10 lb. spool of filler wire and remember to install an ear plug to keep dust and grit off the wire as it enters the liner. Thanks for the helpful tip BIGJim!!
My garage helper supplies 48 lbs. of test load.
I add another outside piece of channel to the lift platform.
Another lift with approximately 175 lbs. The results are promising! No flex.
A full tank of gas puts this load at 500 lbs or so. Now we have some sag at the rear, but everything seems quite stable. I will have to beef up the platform a bit more, but at least I know it will work. I have some flatbar that I got for free when getting all the scrap from the battery racks, so I will box the strut for more rigidity. I will also add another channel to the outside of the base and box it.
I will figure out a way to make the rear lock into different slots as it raises. That will add a good degree of safety.
So...lift : free, materials : free, gas and filler wire : maybe 10 bucks, and about 6 hours of welding practice. Once I'm happy with the framing, I will probably cover the deck with some thin diamond plate.
The bags are finished, and I'm quite happy with them. I road tested them for about 400 miles before using the bedliner on them. I didn't notice any difference in handling, which was a total surprise to me. I'm sure with a heavy load I will notice a difference.
I added some reflectors to the bags from a H-D Electraglide that I've been hanging onto for 5 years or so. They were from a customer's bike I painted, and he didn't want them. Yes, the packrat in me appears once again!
More to come next week.
kirkster70 screwed with this post 10-16-2010 at 10:10 AM
Old 10-16-2010, 01:17 PM   #100
capeklr
capeklr's Avatar
Oddometer: 321
Wow is about all I can say.
You did all this in a few month as a working family man, what are you going to get up to when you retire?
Very inspiring, keep it up.
Time for me to dust off my welder.
capeklr is offline   Reply With Quote
Old 10-16-2010, 04:08 PM   #101
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,187
This thread should be titled Magic With UniStrut.
Nice work.
Laconic is online now   Reply With Quote
Old 10-16-2010, 04:22 PM   #102
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Well, I have 13 years until retirement if all goes as planned, so I should be making jet planes by then. Ha Ha!
In reality, I will have 3 in college, so retirement will probably not happen as planned since I will have to pay for the house 3 times in a row!
Maybe I can at least buy their textbooks with some of my projects in the future.
Old 10-16-2010, 04:26 PM   #103
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Nice work.
You made me laugh out loud!!! Ha Ha! Literally!
- at least it's the solid strut with no holes in it!!!!!!!
oh, by the way, I scored over 70) 16 feet long pieces of the strut, and with everything made, I think I have used up maybe 8 sticks!!!!!! I have it all tucked up under my building out of sight and out of the weather.
I'm trying to figure out how to make some cool outdoor furniture that is actually contoured and doesn't look like doo-doo.
Old 10-16-2010, 04:37 PM   #104
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
More pics until about 4 days from now...
I just started experimenting with some floor jacks. I figure if I can come up with a contraption in the rear that locks in different positions as it goes up, I can go higher than I need, then drop down to level to overcome the sag.
I added support to the platform and the base, so I'm done there. There is no hesitation in the lifting process at all. It lifts the KLR as easily as it lifted my boy. It is rock solid on the jacks, so the locking contraption will solve the sag issue.
This lift is rated at 750 lbs 3 feet away from the base, so 7 feet away lifting 500 lbs is probably all I would be willing to put on it. Just like an engine hoist, or a crane for that matter, the load capacity is reduced the farther out you go.
Next on the to-do list : the above mentioned locking contraption, a home brewed wheel clamp on the front, and the platform with drop-down ramp.
- just in time for my KLR's 20,000 mile oil change! Perfect!!!!
Old 10-16-2010, 11:20 PM   #105
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,872
IN!
Top work, Kirk!
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Times are GMT -7.   It's 12:37 PM.
