Old 01-20-2013, 02:46 PM   #1456
NoVa Rider
Oddometer: 2,914
Three, and like JVB said, thanks.
K70 has an incredibly neat operation -- his workmanship looked top notch.
He has pretty much what anyone who wanted to do everything metal themselves would wish for. The automated bike lift was just a bonus.
NoVa Rider is offline   Reply With Quote
Old 01-20-2013, 02:49 PM   #1457
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Yep. 3!
Didn't realize that was you!!!
Good meeting you today as well!!
Get all the goodies home safely? Let me know when you run out.
kirkster70 is offline   Reply With Quote
Old 01-20-2013, 02:59 PM   #1458
JimVonBaden
"Cool" Aid!
Oddometer: 53,282
Originally Posted by kirkster70 View Post
Yep. 3!
I have a feeling at I will need a trailer when we come back for the GS!
Jim
Old 01-20-2013, 03:25 PM   #1459
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Jim
Not a problem. Just make sure to have some of that prefix beer with you.
You saw how I have my neighbor trained, didn't you? Heheheh...
Old 01-20-2013, 05:19 PM   #1460
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,205
Found some more pieces parts at the scrap yard yesterday (on the left) to add to what I've accumulated so far for FrankenGantry. I think I've finally got the design that I want sorted out.
Here are the materials so far:
The tubing is 4X4. The piece on the left is 8', and there are 2 6' pieces, and one about 3'. The I beam is 6" with 6" flanges by almost 10', and the OD of the pipe is about 2.375". There are 4 pieces 8' and a couple shorter ones. On top of that, I have some miscellaneous angle and plate accumulated.
The metal wheels on the cart on the right will get cut off and mounted to the gantry bases. They are 6" tall X 3" wide cast and good for about 2,500 pounds each if I believe what I read.
Originally, I was thinking I would use some 2.5" square tube I have for vertical supports, 2 pieces of pipe on each side for diagonal braces, the 4X4 X 6' tubing for bases, and the I beam for the top member. Then I was thinking about putting a piece of 4X4 tube at the top on each side to mount the I beam to, sitting on top of the 2.5" tube.
But, I really want a 10'+ clear span between the legs so I can easily park a trailer underneath. After I found the 8' piece of 4X4 tube yesterday, I changed plans a bit.
New plan is to cut the I beam in two for the bases. Join the 4X4 tube into two 10' tall vertical supports, and buy a new piece of I beam for the cross member (if a suitable piece doesn't show up at the scrap yard some time soon. ) . Based on what I've seen & read, a piece of S6 12.5# I beam is sufficient for a 12' overall beam length with a one ton limit, about 11' clear span. I'll confirm that before aquiring the beam.
Now all I need is for the weather to warm up a little. I have no real need to get it done in a hurry, and it's just a little nippy in the barn right now.
dunno.....
9Dave screwed with this post 01-20-2013 at 05:26 PM
Old 01-20-2013, 08:15 PM   #1461
CaptTeach
Oddometer: 209
I'll pass on the Romex idea.
Not a heavy enough jacket to be lying on the floor doing extension cord duty.
Plus, it's not very flexible.
SO or SJ cord is what I would use, but it's expensive. Buy the cord and the proper end caps, and you're easily at double what you can buy premade for. And that's just material prices - not counting a second of your time running around gathering everything up. The big brown truck will put one on my front porch that's ready-to-use for half price.
Plus, if I ever get a camper with a 50A plug, I can use it there as well! Always thinking ahead. Heheheh
Yeah - it's not very flexible - but I bought a 250ft spool to make my runs (shop is 90ft deep) so it was kinda there and my 'extension cord' is only about 20ft to get me around the work zone. HMMMMMmmmmm I have a shore power cord I got with a sailboat.................
CaptTeach
96 Heritage Softail Classic
89 XT 600
71 CB 200 Cafe Racer
70 CL 100
63 Sporty XLCH
CaptTeach is offline   Reply With Quote
Old 01-20-2013, 09:58 PM   #1462
JimVonBaden
"Cool" Aid!
Oddometer: 53,282
I did, and will do!
Jim :cool:
Old 01-21-2013, 09:05 AM   #1463
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Looks like your project is shaping up! Very nice! Sounds like yours will be a fixed height?
Nippy? The heat is in the tools. I can't tell you how many times I've heard that one on a jobsite.
Old 01-21-2013, 11:37 AM   #1464
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
I'm starting to get very particular with my work, especially when it's someone else's bags.
My TIG uniformity is improving by leaps and bounds, but still not exactly how I want it. I want the exposed weld to remain for strength. I don't want to grind down any more corners on any of my work.
The solution? I employ what I've heard a couple guys on the site call the "sick bro weave".
Using no filler, I dial back the frequency on the Dynasty for a soft outside corner blend. Then I go back over the existing weld and wash the toes just a little wider, making the bead more uniform in the process. I do this on every weld, even the ones in the back and on the bottom that most ignore. When I used to paint, customers always liked the extra attention to detail. I try to use what I learned back then to move forward with what I'm trying to do now. This should give me full strength on the welds while also being aesthetically pleasing to the eye.
I'm very happy with the outcome. Once the GS's racks are complete, it will be a whole new experience dealing with the powdercoater. I'm also waiting on lid gasket material to check that my clearances are what they need to be.
Getting there!
Old 01-21-2013, 06:36 PM   #1465
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 524
Nice, Moving beyond functional to TIG art form.
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Old 01-21-2013, 07:18 PM   #1466
JimVonBaden
"Cool" Aid!
Oddometer: 53,282
Getting there!
Wow, significant improvement over what I saw, which was already very good!
By the way, I used some of the material you gave me to do this:
Raw stock from a generous Kirk!
Going to replace this crap rack and fit this space.
Some of the WORST welds I have ever seen, but they should hold for my application.
Jim
Old 01-22-2013, 04:31 AM   #1467
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,205
Yep - fixed height at about 11' or so under the beam. It will just live in the shop, and if I want to take it out for a walk, I have a 12' door.
"The heat is in the tools" BAH! While some of the tools can produce a whole lot of resistive heat, unless it gets above 40, there is no reason I need to be playing in the shop.
dunno.....
Old 01-22-2013, 03:58 PM   #1468
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Thanks! One day soon I'll have welds nice enough to stand on their own w/o going back over them.
Old 01-22-2013, 04:01 PM   #1469
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Jim
Looking good, Jim!
Old 01-22-2013, 04:02 PM   #1470
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
I got to thinking - with a 6" flange, isn't that an "H" beam? Make sure your trolley will adjust that wide.
Times are GMT -7.   It's 02:31 PM.
