10-14-2011, 03:10 AM
#76 |
Oddometer: 2
Weather proof?
Question(s) for anyone that might know:
Are these 3.5mm jacks sealed in any way internally to minimize or eliminate moisture? If not, how would one best retain the weather-resistant nature of an umolested unit after doing this mod (or as part of the mod perhaps)? I ride in wet conditions frequently so the weather-resistance is crucial. |
10-14-2011, 06:48 PM
#77 | |
Oddometer: 218
"I pick, therefore I grin." 2008 BMW R 1200 GS Adventure |
10-15-2011, 01:19 AM
#78 |
Oddometer: 2
^^ My GF and I had a set of Q2s, and recently picked up the G4s. They've all gotten quite wet with no ill effects. Compromising the sealed base for this mod is what concerned me. But it sounds like that shouldn't be a problem if addressed as you suggest. Thanks for the info, and the great write-up
![]() Cheers |
10-19-2011, 04:21 PM
#79 |
FJR Pilot
Oddometer: 46
The thing is that you are really not modifying anything but the clamp. The comm unit is not changed in any way and warranty is only an issue for the $45 clamp.
Eileen Sent from my PC36100 using Tapatalk |
10-19-2011, 04:39 PM
#80 |
Are you a Sheeple?
Are you still doing the modification, I sure would like to get mine modified?
10-20-2011, 08:16 AM
#81 |
FJR Pilot
Oddometer: 46
Yes I am still doing them for $30. I will put a plug on the speakers for an additional $5, some people had asked for that.
10-20-2011, 08:57 AM
#82 |
Oddometer: 1,668
Eileen,
Have you had any experience with the Q2? As stated in the first few pages of this thread, it's a bit more complicated. |
10-20-2011, 10:17 AM
#83 |
FJR Pilot
Oddometer: 46
Yes, I did a few of them. I won't do any more. I found too many different versions of them and every one was a challenge.
Sorry. Sent from my PC36100 using Tapatalk |
01-09-2012, 07:21 AM
#84 |
Oddometer: 1
Problem
So I did the mod to 2 sets. First on with a boom mic, worked great. Secon one for a full face helmet with the other style mic.
Second one ,I only get sound out of 1 speaker when the plug is all the way in. If I push the plug in part way, I get sound out of one speaker, push in a little farther, out of both all the way in 1 only. Any ideas? I tried a different plug and same thing happened. |
01-09-2012, 08:58 AM
#85 |
FJR Pilot
Oddometer: 46
There are 2 possibilities. Assuming it is the same with another set of ear buds, the jack could be bad or it could be misswired . A volt/ohm meter can be handy here to check the wiring.
You just need to take it apart and check it carefully until you find the problem. |
01-09-2012, 07:20 PM
#86 |
Oddometer: 218
Jetgrl is right, get your volt/ohm meter out and begin checking your connections...
Those solder points are pretty small and it could have creeped over and made contact with another solder point, or it could be a bad solder making it a bad connection... Keep us posted...
01-11-2012, 05:56 PM
#87 |
Oddometer: 35
Thanks for posting this walk through. I had the mod performed today and it works great. The headphones of my cradle crapped out and my warranty had expired so I decided to go with this mod so that I can use any 3.5mm plug ear buds or helmet speakers. Plus, if those crap out I can change them out quickly with no tool unlike the hard wired helmet speakers that came with the unit.
01-11-2012, 07:04 PM
#88 |
Oddometer: 218
Glad everything worked out for you, 4n6...
01-26-2012, 06:49 PM
#89 | |
Oddometer: 155
2007 V Strom ("Scout"); 1961 Sears Allstate Moped ("Sparky") |
01-27-2012, 07:50 AM
#90 | |
Oddometer: 218
Anybody else have anything here?
