Old 10-18-2010, 05:13 AM   #31
Kaasua
Kaasua's Avatar
Oddometer: 7
Are you suspecting that the discoloration underside the piston is caused by exhaust gases leaking through the crack ? Could it be that the crown of the piston is so hot that oil has "cooked" to the underside of the piston ?
Kaasua is offline   Reply With Quote
Old 10-18-2010, 08:53 AM   #32
Tseta OP
Lost
Tseta's Avatar
Oddometer: 674
Question
Yes, this is exactly what I am suspecting.
However, this is possible as well. Maybe the truth is somewhere in the middle. In any case, the piston is done.
It seems that I can have the Pro-X or the Wiseco piston kits ordered through a local dealer. I wonder if I would be better off with one or the other, or should I try ordering a Wössner (Motolab approved spelling ) piston myself directly from Germany?
I had the cylinder measured at a measuring lab through some "connections". The results were as follows:
HeightDiameterRunout
-5 mm101.0205 mm0.0137 mm
-45 mm101.0181 mm0.0061 mm
-86 mm101.0196 mm0.0103 mm
It seems that the cylinder is in good condition.
Originally Posted by bmwktmbill
There is quite a bit of carbon on the piston top, when you get to the carb I'd be interested to know what the jetting and needle position are?
The bike has the Dell'Orto PHM 40 SD carburator on it. The current settings are:
Throttle valve - 40
Main jet - 188
Slow jet - 55
Needle jet - DR270
Idle jet - 45
Jet needle - K51
Needle clip - 3rd from top
Mixture screw - 3/4 turns open
Tseta is offline   Reply With Quote
Old 10-18-2010, 09:28 AM   #33
Tseta OP
Lost
Tseta's Avatar
Oddometer: 674
Some updates on today's progress. I experienced a setback once again. This is becoming quite depressing.
So, I continued with disassembling the engine. It was time to remove the clutch and other components under the clutch cover.
I tried many ways to hold the clutch from moving to undo the clutch nut. Nothing worked. Thankfully, my local KTM dealer let me borrow the official LC4 clutch holder tool.
Even with this nice tool, it was difficult to get the nut to move. Yes, I had realized to flatten the locking washer. When the nut finally broke loose, it also broke something else:
More expensive parts to order.
The clutch basket itself looks all right.
The counter-balancer's bearing housing in the clutch cover has some strange marks.
As does the clutch cover itself, right in the middle of the clutch packet.
So, with the clutch out of the way, the oil pumps could be accessed.
Before that, though, the mainshaft bearing retainer was removed for inspection. There has been some discussion about wearing retainers here
The retainer on this bike shows about 0.5mm of wear. To recap, the bike has about 50,000kms on it and one of the previous owners has changed the mainshaft bearing to the newer, roller type.
So, now with everything removed from under the clutch cover,
it was time to inspect the oil pumps.
The oil pump housing had some grooves in both of the cases. The clearances checked out just fine on both, but the upper pump's outer rotor was badly scratched and the lower pump's inner rotor's tip had a chunk missing from it. I think the bike would benefit from new oil pumps. Hopefully KTM has managed to get the oil pump situation under control already.
This (bad) picture tries to show that there is perhaps some discoloration also on the conrod end? Combustion gases, excessive heat or cooked oil?
So, then the components under the ignition cover were removed. A pin wrench works very well as an improvised magneto holder tool.
Unfortunately, it is not possible to split the cases while the engine is attached to the repair stand that I made. Thus the engine was lifted onto the table on wood blocks, and is now awaiting the split. How exciting!
Cheers,
Tseta
Old 10-18-2010, 02:46 PM   #34
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,974
Should you ever consider a Rekluse clutch, this part is replaced with a Rekluse part. Maybe a plea in the Flea Market will locate a used replacement.
Great thread, I love this stuff.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 10-18-2010, 03:07 PM   #35
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,846
vossner.. wössner... woessner.. to lazy to look up shortcuts..
nice work my norwegian friend
and Derek.. let us know its alt whatever for our lack of punctuation prowess. but the alt0246 is easy !
wrk2surf is offline   Reply With Quote
Old 10-18-2010, 11:50 PM   #36
bmwktmbill
Traveler
Oddometer: 5,203
Throttle valve - 40
Main jet - 188
Slow jet - 55
Needle jet - DR270
Idle jet - 45
Jet needle - K51
Does anyone know what the OEM jetting is for the Dellorto is supposed to be?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 10-19-2010, 12:11 AM   #37
Dirtybill
Oddometer: 219
Not to rain on your parade but wouldn't it be cheaper and easier to get rid of the KTMs and get a good bike like a Husky?
That's what I did after my KTM grenaded and it was stuck in a KTM dealership while under warranty for 3 months of prime riding season.
Dirtybill is offline   Reply With Quote
Old 10-19-2010, 12:28 AM   #38
AndyE_UK
Oddometer: 120
AndyE_UK screwed with this post 10-19-2010 at 05:12 AM
AndyE_UK is online now   Reply With Quote
Old 10-19-2010, 12:48 AM   #39
makazica
makazica's Avatar
Oddometer: 749
Right. By Husky you mean Husqvarna?
makazica is online now   Reply With Quote
Old 10-19-2010, 12:54 AM   #40
Dirtybill
Oddometer: 219
Correct.
Old 10-19-2010, 01:06 AM   #41
bobfab
bobfab's Avatar
Oddometer: 1,482
Tseta
I have done the exact same thing on a CRF. Its a real bummer when you realize that the job magnified in cost
Been There! Good luck great thread.
CRF250L | KTM200SX
bobfab is offline   Reply With Quote
Old 10-19-2010, 02:08 AM   #42
Tseta OP
Lost
Tseta's Avatar
Oddometer: 674
Throttle valve - 40
Main jet - 188
Slow jet - 55
Needle jet - DR270
Idle jet - 45
Jet needle - K51
bill
See here.
-T
Old 10-19-2010, 02:12 AM   #43
Tseta OP
Lost
Tseta's Avatar
Oddometer: 674
The bike I'm working on now is not mine, and thus I cannot make that type of decision for it's owner.
I have found that the '03 LC4 Adventure (silver, the fastest color) is just about the perfect bike for me. I will be keeping it as long as I can.
-T
Old 10-19-2010, 03:16 AM   #44
Tseta OP
Lost
Tseta's Avatar
Oddometer: 674
Thanks for all the words of encouragement with this project.
Today I went ahead and split the cases. This was very exciting and nerve wrecking. It is the first time I've done anything like this.
The cases came apart with just a few small taps using a plastic mallet.
I found these bits and pieces (ferromagnetic) inside the case.
The "upper" case half looked clean.
Then onto the the crankshaft and transmission.
I went ahead and removed the rest of the transmission components as instructed in the shop manual.
The problem is that I cannot find any real damage anywhere. The bits and pieces must have come from somewhere, but I found no damaged bearings or gearwheels. I must still take the kickstarter out, and take a closer look at the transmission shafts, but I doubt there is any larger problems there either. I'm very confused by all this.
I did find something wrong with the crankshaft & conrod assembly.
The crank bearing's inner ring moves quite freely on the crank (not so much as to slide completely off, though). This is surely not normal?
The conrod big end bearing has about 0.8mm of axial play.
The specification is 1.0mm max, so that seems ok. There was also a value for radial play, but I have no idea how to measure that. When moving the conrod by hand, there doesn't seem to be any radial play.
There was also a procedure for measuring the piston pin and conrod small end bearing clearance, but since I will be getting a new piston pin anyway, this measurement would make no sense. I did notice, though, that the small end bearing is not centrally located in the conrod.
What's going on here?
I read the manual on crankshaft shimming about 10 times. I still don't get it. How is it possible to measure the cases up to the depth of the crank bearing inner ring when the inner ring is still attached to the crankshaft itself?
I think I need (local and hands-on) expert help...
Cheers,
Tseta
Old 10-19-2010, 07:28 AM   #45
lewis87
lewis87's Avatar
Oddometer: 19
I can't help you with any of your questions but I am enjoying this thread, keep it up
lewis87 is offline   Reply With Quote
Times are GMT -7.   It's 05:28 AM.
