07-16-2011, 06:44 AM
#166 |
Indubitably
Oddometer: 11,629
5 of 6 cords in the barn for the 2011-2012 season.... yeahhhhhhh boi!!!!!!!!
07-18-2011, 12:12 AM
#167 |
ADV B4 DEM/TED
Oddometer: 119
Flue Heat
Our heating is a Ultimate ( Australian brand) that is to heat up to 25 square ?? our house is 16square .The heater is instaled where there was an open fire place so the flue goes up where the chimney is and made of brick.
It will heat 1/2 the house , my thoughts are to take out some of the bricks at the top of the chimney and pipe the heat through to the other end of the house with some ducted points coming out of the duct . I was hoping to use a transfer fan kit to move the heated air . The house has a cathedral ceiling all the way through and no roof space . Has anyone got any thoughts on this or info on how to acheive this system?????? ![]() Thanks Tezza
Tezza. KTM 990 ADVENTURE. ![]() KTM 520 EXE. ![]() Now the Perfect pair!!!!
07-18-2011, 07:02 AM
#168 | |
Indubitably
Oddometer: 11,629
I wouldn't mess with the flue...for a couple reasons... especially if I understand what you are saying; that you want to create a horizontal flue at the top of the house before exiting the house:
I've seen this in houses with a stove in the basement... it works good and is pretty simple... In your case if you have a basement you can actually create cold air returns by running ducts from the under the floor of the cold rooms back to the stove area to help the convective flow... it helps dissipate the excess heat in the area where the stove is and warms the other rooms nicely... |
07-18-2011, 09:32 AM
#169 | |
mach schnell
Oddometer: 1,435
I'm ready for winter too.
****** Mess with me and you mess with the whole trailer park. |
07-18-2011, 09:44 AM
#170 | |
Oddometer: 1,892
Lots of smart folks here: http://www.hearth.com/econtent/index...s/viewforum/2/ |
07-18-2011, 10:29 AM
#171 |
Oddometer: 3,479
Are their arrangements that provide for heat exchangers, so you could tie in existing HVAC ductwork to pipe the heat elsewhere? I'm talking about the kind of thing that pipes in clean interior air, separated from the fuel/exhaust air, & pipes the hot air back out to ductwork that had already been put in for the AC.
07-18-2011, 09:10 PM
#172 |
ADV B4 DEM/TED
Oddometer: 119
Ducting heat
The flue is rinning in the old chimney and all i want to do is take the heat out of the chimney area and not cut into the flue .
It would be great if i had a basement but in Australia it is not common to have a basement , our house is on ground level and on concrete slab. I do want to use a transfer fan to move the heat about 45feet to the sleeping areas . I still need some info if there is any about ducting heat. Thanks Tezza
07-19-2011, 01:32 AM
#173 |
Oddometer: 659
+1 for Rocket stoves if efficiency is to be a prime factor!
http://www.richsoil.com/rocket-stove-mass-heater.jsp
07-19-2011, 02:10 AM
#174 | |
Oddometer: 2,203
The only other way i can think odf is a wetback to heat water for radiators in the area you want to heat.
aka BMWST?
07-19-2011, 02:32 AM
#175 | |
ADV B4 DEM/TED
Oddometer: 119
Ducting heat
I know that i will have to use duct to transfer the heat , using a wet backand radiators would be great but the house is built on a cement block and we have no way of getting water pipes under the house.
We have the wood heat in the old fire place and has been there for 10 years . Thanks Tezza Quote:
07-20-2011, 07:09 AM
#176 |
The Salt
Oddometer: 3,026
Bought a new home... Look whats inside! Two wood burning stoves, plus a fire place.
This one is in the basement... ![]() This one is in the kitchen! ![]() ![]() With her top off... ![]() What upkeep, advise or other can you give me? Thanks..
~ BMWF800GS ~ "Not all those who wander are lost" |
10-03-2011, 02:54 PM
#177 |
Native Texican
Oddometer: 4,735
This little stove came with my house and was in the garage for 25 years.
The liner was burned out and it was pretty rusty. I took it apart and put in a new liner, blasted the other parts and had the foot rests and feet powder coated chrome.
N. Texas "There is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance - that principle is contempt prior to investigation." |
10-03-2011, 05:30 PM
#178 |
Indubitably
Oddometer: 11,629
First fire in the big stove tonight!!!!
![]() ![]() Wooooo..whoooooooo!!!.. ![]() Getting to heating season.... Been running the little stove a night here and there to get the chill out.... but it is good to get the big one fired up for the first time of the year.... Kinda like firing up a big tractor that has been sitting all winter.... not sure how it is going to go... it has to burn off any humidity that has been collecting and first fire always smells different..... Two hours in... and running great..... needs a good cleaning before the real season gets underway... but the new metallic catalytic converter that replaced the ceramic one cleaned up nice with a little compressed air (which is strictly prohibited with ceramics) and is running like a charm.. Six cords are stacked.... Ready to rock and roll...... |
10-04-2011, 06:10 AM
#179 |
RS'er
Oddometer: 787
Glad I cleaned out the stovepipe last weekend, have had a fire since last Friday night.
Forecast in the 70's & maybe 80's by the weekend. Got to love this time of year
"As a teen I would have fucked a snake if someone would hold it's head, drunk or not. But I've matured. Now I'd make sure I was drunk before I tried to fuck a snake"..........Bueller |
10-04-2011, 06:32 AM
#180 |
Indubitably
Oddometer: 11,629
Great sale going on at Woodstock Soapstone... The stove I have, pictured above is nearly $1,000 of what I paid...
![]() http://www.woodstove.com/home Open house this weekend at their factory & showroom too if you are up in the Dartmouth, Lake Sunapee Region... Door prizes Did I mention no sales tax in NH... They are located at: 66 Airpark Road West Lebanon, NH DISCLOSURE: I have nothing to do with the company.. I don't play the CEO on TV.... nobody I know works there... etc, ect.... I just really...really... like my stove.. and am thrilled it was made right here in NH... |
| Thread Tools | |
