Old 10-18-2010, 05:31 PM   #61
Srbenda
Embassy of South Carolina
Srbenda's Avatar
Oddometer: 11,929
Originally Posted by Nailhead
Perfect place for one.
It seemed to me that the earth may he borrowed but not bought. It may be used but not owned. It gives itself in response to love and tending.... But we are tenants and not possessors, lovers and not masters.
Srbenda is offline   Reply With Quote
Old 10-19-2010, 09:04 AM   #62
Bulleteer
Aimless Wanderer
Bulleteer's Avatar
Oddometer: 320
I'm not proselytizing; I'm explaining.
10 bonus points to Nailhead for the use of the word proselytize in an ADV thread.
Bulleteer is offline   Reply With Quote
Old 10-19-2010, 11:58 AM   #63
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
Originally Posted by Srbenda
Are these only for commercial use?
Nope
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-19-2010, 12:01 PM   #64
crankshaft
crankshaft's Avatar
Oddometer: 13,783
Originally Posted by A-Bone
Yup... Plus the Tarms can come as a dual fuel boiler... so that when the system is calling for heat and there is no wood it will switch over to oil or propane..
The guy whose land we cut our christmas trees on has one... he loves it... but man does it take up some realestate in his basement... I'm guessing his is a much older one though...
But it is pretty cool to get your domestic hot water off it though...
Dual fuel is gone.... Against code
Just say'IN
Old 10-19-2010, 12:05 PM   #65
JohnDavid
JohnDavid's Avatar
Oddometer: 374
http://us.rais.com/
http://johnallendesign.com/
JohnDavid is offline   Reply With Quote
Old 10-19-2010, 02:09 PM   #66
Cirrus
Oddometer: 85
We just moved into our place in May and we've only had this little thing going a few times.
I don't think its a great stove. I've had it chock full and it barely heats up the down stairs.
The house also came with this combo. We fired it up when we first moved in but had to shut it down after fire started raining down on our deck. I cleaned the chimney after that but I haven't started it since. I've been trying to get wood delivered since May with no luck.
Cirrus is offline   Reply With Quote
Old 10-19-2010, 02:17 PM   #67
nofate
what blackflies?
nofate's Avatar
Oddometer: 2,622
The problem with some of those dual fuel furnaces is that the chimney gets creosoted when the damper on the wood fire closes to maintain the temperature set at your wall thermostat. Keep the chimney hot by either burning hot fires for short periods or smaller long term fires with the thermostat set at a higher value. Chimney fires are not fun. If you had one inspect the flue for signs of damage.
Rick, Chapleau, ON
Triumph Scrambler 900
Honda Trail CT90
Flying with Rick float plane video: http://www.youtube.com/watch?v=g6my0FM9F_Q
nofate is offline   Reply With Quote
Old 10-19-2010, 02:47 PM   #68
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 5,385
If you only knew how many attempts I made to spell it correctly...
-Chris
'04 GS Adv- A fond memory
'07 990 Adventure- still bonding...
How hard can it be? - Jeremy Clarkson
Nailhead is offline   Reply With Quote
Old 10-19-2010, 03:44 PM   #69
A-Bone OP
Indubitably
A-Bone's Avatar
Oddometer: 11,624
they use seperate combustion chamber but a single flue...
http://www.woodboilers.com/multi-fuel-boilers.aspx
A-Bone is offline   Reply With Quote
Old 10-19-2010, 05:44 PM   #70
crankshaft
crankshaft's Avatar
Oddometer: 13,783
Exactly..... Solid fuel and liquid fuel cant vent in the same flue in our code jurisdiction .....as I recall. Gas is for sure a no no.
Most do the wood side as an add on.
Just say'IN
Old 10-19-2010, 08:10 PM   #71
nofate
what blackflies?
nofate's Avatar
Oddometer: 2,622
My combination furnace is wood - electric so the chimney is only required for wood smoke. I heat mostly with wood and in 26 years have only had to replace the fan motor. My wood warms me many times though.
Rick, Chapleau, ON
Honda Trail CT90
Old 10-20-2010, 12:29 PM   #72
Bryn1203
Dances with spaniels
Bryn1203's Avatar
Oddometer: 1,754
we run a contemporary Jøtul F 273 stove - love the contemporary look - it takes 18" logs diagonally - we get thru about 2.5 cord (4ftx4ftx8ft stack) a winter to heat a 4 bedroom house.
http://www.woodburningstovesco.co.uk...l65h6&model=25
I fancy heaping large pebbles round it to get thermal mass - but the wife won't let me. I reckon the pebbles could be stacked and taken down in the summer - not need for a permanent fit.
I sell firewood wood as a side line.
Current prices are £50 a cubic metre bulk bag - its probably about 3 cu.m. per cord.
Bryn1203 is offline   Reply With Quote
Old 10-20-2010, 05:34 PM   #73
A-Bone OP
Indubitably
A-Bone's Avatar
Oddometer: 11,624
I thought you guys cut down all your trees a long time ago???
I honestly thought you guys mostly burned coal....
Do a lot of people burn wood??...
Old 10-20-2010, 06:01 PM   #74
Nailhead
Painting by numbers
Nailhead's Avatar
Oddometer: 5,385
It's not like Lebanon-- they do actually have some trees there.
At least I saw some on Top Gear.
-Chris
Old 10-20-2010, 06:07 PM   #75
A-Bone OP
Indubitably
A-Bone's Avatar
Oddometer: 11,624
I know they have some trees, but everyone makes the UK out to be the ultra Nanny State that regulates the shit out of everything...So I naturally thought if they are hard to burn in California they must be just about illegal to burn in the UK...
Thread Tools
Times are GMT -7.   It's 01:25 AM.
