Old 01-19-2014, 06:58 PM   #17776
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,611
Nice ride, Stupot.
What if you took Axl Rose down to Paradise City, but the grass was brown and under watered?
bigborefan is offline   Reply With Quote
Old 01-19-2014, 07:58 PM   #17777
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,235
Originally Posted by Pyndon View Post
You cannot fit the new balancer shaft without changing the engine casing....so my guess is you do not want that expense?
No I do NOT!! I actually meant the spring loaded gear vs the standard gear that turns the balance shaft. But then I thought, that's just one more part to break.
Speaking of balance shafts....
Something has been eating me lately, well, more like my counter balancer
The only thing behind it is the cam chain and what used to be behind it, the lower end of the cam chain guide opposite of the tensioner. Some how, it managed to find it's way out and lodged between the primary gear and the trigger wheel.
The piece wore a groove in the pulse generator but it seems to be fine. I am guessing the groves in the balancer are from the cam chain shuttering and if they hadn't hit that, would have probably derailed and caused a big dent to appear in the piston. When I thread the cam chain tensioner caps in, I should get 6+mm of space between the case and the head of the tensioner cap, I get maybe 1.5mm to 2.5mm of gap. I am replacing all the tensioners and chains, after 10 years of heat cycles and vibration, I'm not taking chances.
Maybe they were stretched enough to allow enough of a cam timing change that the new ones will bring back a few ponies, but I doubt it!
Originally Posted by charlie264 View Post
Comparing the basket roller bearing at 20k miles, noticeable less play with the new one. I've not found the oil jet to be blocked when I've checked.....
Oddly, the inside of the basket's wearing surface looks fine as well as the bearing, but the shaft does have 2 wear tracks in it and the difference if I remember correctly was about .01mm
The ears are dented from the fiber plates so I'll file those down. The plates are still in spec but both pressure plate surfaces have taken a beating.
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 01-19-2014, 08:04 PM   #17778
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,235
I did find one other odd-ball thing. For some reason the chain slider on the swing arm got cocked towards the shock and by the time the chain reached the curve where it wraps around the swingarm, the chain was fully on the left side of the hump that runs down the middle. I made a sheet metal bracket that is behind the frame and under the new slider to keep it from drifting off center.
Michael
Old 01-20-2014, 04:27 AM   #17779
charlie264
charlie264's Avatar
Oddometer: 8,314
I wish there was a mechanical plus hydraulic cam tensioner alternative, something that could be adjusted to take up most of the play and oil pressure taking up the rest....
If you're going to replace the shaft, or not, wouldn't be a bad idea to upgrade the basket...no steel band on the newer one. You would expect the bearing to be the weak point and wear out first, a bit of play is normal. Source a new bearing from a bearing shop, they are not cheap from Austria and compare.
Old 01-20-2014, 06:10 AM   #17780
Decepticon
Decepticon's Avatar
Oddometer: 124
Oppi Fjellet. Up in the mountains
2007 KTM 990 Adventure ABS
A lot of bad things have been said about me, all of them are true
Decepticon is offline   Reply With Quote
Old 01-20-2014, 07:02 AM   #17781
maxinux
KiLR
Oddometer: 39
Installed the Christmas Trio from Rottweiler/CPR Fab, HT Racing 2-into-1 pipe, Rally tank, SAS and Canisterectomies, Seat Concepts seat and re-wired some aux lights.
And, since this is a show off thread - a pic of my bike out @ Lake Berryessa before I did any of this work.
A few more things to finish up and then to go for a ride!
maxinux is offline   Reply With Quote
Old 01-20-2014, 08:02 AM   #17782
xTomKx
xTomKx's Avatar
Oddometer: 195
Originally Posted by FakeName View Post
That's a lot of air for a big bike
2012 KTM 990A, 2006 KTM 250 2s, and many other toys
xTomKx is offline   Reply With Quote
Old 01-20-2014, 08:10 AM   #17783
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,818
Actually, he caught me on the descent
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 01-20-2014, 10:02 AM   #17784
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,235
Looking at it, it shouldn't be hard to make one like the Tokyo mods units
Mine has the steel band, wonder why the took it off?
Michael
Old 01-20-2014, 11:07 AM   #17785
Pyndon
Pyndon's Avatar
Oddometer: 2,544
One explanation could be? ..... Those look like brute force marks where some dodgy mechanic has been trying to force the balance weight off the shaft.....I say this with all seriousness, I've been asked to put engines back together for people that have got in too deep and seen the same thing. They try to get the weight off using a screwdriver or similar. Bad disassembly skills if you ask me, in a previous life?
Could be totally wrong but looks like.
Can I add also, this is in the wrong thread, it should be on it's own or in a similar mech type thread, not a 'show off your bike thread'. Can we move this discussion elsewhere?
Lyndon Poskitt Racing
Currently racing my way around the world at: www.facebook.com/LyndonPoskittRacing
Blogging at: www.racestoplaces.com
My Dakar Rally Experience
and blog www.LyndonPoskittRacing.com
My KTM 950 Story
Pyndon screwed with this post 01-20-2014 at 11:39 AM
Pyndon is offline   Reply With Quote
Old 01-23-2014, 06:05 PM   #17786
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,235
Sorry, wasn't meant to be, you all were showing yours off riding the open road, I was showing mine riding a repair stand exploring my garage!
I'll be on the road in 4 weeks, hopefully with pictures worthy of a post.
Michael
Old 01-23-2014, 09:37 PM   #17787
Elusion
Elusion's Avatar
Oddometer: 85
I'm finally contributing to this thread.
'13 KTM 990 Adventure
Elusion is offline   Reply With Quote
Old 01-24-2014, 05:01 AM   #17788
Smox
Smox's Avatar
Oddometer: 8
Awesome bike!
'11 Berg FS570
'02 Honda "The Thing" - sold
'09 Husky SM610 - Sold
Smox is offline   Reply With Quote
Old 01-24-2014, 07:30 AM   #17789
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,683
Haven't gotten out to the desert for a couple of weeks, but from last time,
I'll have to get a proper camping shot soon.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is offline   Reply With Quote
Old 01-24-2014, 06:46 PM   #17790
HellsAlien
a has-been that never-was
HellsAlien's Avatar
Location: Baja Sur winter. PDX summer (that's like 6 wks!)
Oddometer: 2,375
My 950A chatting with my pal's SE under a tree after riding up to El Triunfo, BCS.
The SE was explaining why it was so fast in the dirt, but couldn't understand why the old black A-model would blow by +20 on the long straight runs. Fun place to ride on two great bikes.
"Hells AL is right."Zuber "Bad roads, good people. Good roads, bad people." Mama Espinoza
“Ride first, tart second. Sorry bro but that’s the way it has to be.” Cbrit, 2008
“You gas it where I brake!” trackday passenger, Thunderhill, 2005 "Especially since he's one of the fastest riders on the planet, on any surface!" Earwig, 2014
HellsAlien is offline   Reply With Quote
Times are GMT -7.   It's 11:02 PM.
