Old 10-03-2005, 06:02 PM   #541
Fresno
Adventurero
Fresno's Avatar
Oddometer: 616
Originally Posted by johnnyotis
WOW! Linex?
Fresno is offline   Reply With Quote
Old 10-03-2005, 06:14 PM   #542
johnnyotis
Loungemaster
johnnyotis's Avatar
Oddometer: 138
The Boss is gifted. Truck bed liner from auto zone. Very easy to touch-up after my crashes. I got tired of looking at my beat up silver. Wish I had the black rims.
johnnyotis is offline   Reply With Quote
Old 10-03-2005, 06:17 PM   #543
Ignore Amos
bruised, dazed & confused
Ignore Amos's Avatar
Oddometer: 981
Me like......
AFTER
I think I'd add black rims and maybe gloss black KTM logos in the stock locations..and also paint the windscreen- very stealthy.....yea, what's the paint?
Ignore Amos
Women love men with big KTMs
07 BMW 1200 GS Adventure
07 KTM 950R Super Enduro
08 KTM 530 XCWR
09 BMW G450X
BITD 066
AMRA 54S
SCORE 22X
Ignore Amos is offline   Reply With Quote
Old 10-03-2005, 07:53 PM   #544
S Won
Oddometer: 746
Blue Ridge Parkway trip
Just got back Friday from a trip to the Blue Ridge Parkway and Skyline Dr. The first two pictures were taken at Seneca Rocks in West Virginia. The last was taken on Skyline Dr. Clyde the Vulture was a gift for my daughter. He hitched a ride home on the back of my bike. The KTM ran perfectly. We did almost 1000 miles over 3 days. Not a big Adventure trip or anything like that, but it was a blast. We had a great time. Had some good food and shared a few stories of the road.
There were 2 DL-650 V-Stroms, a Yamaha FZ-1, a H-D Dyna and my KTM 950 Adventure S in our group. A diverse bunch of bikes, but a nice group of friends.
S Won
S Won is offline   Reply With Quote
Old 10-04-2005, 03:01 AM   #545
Autostream
Autostream's Avatar
Oddometer: 5,833
KatieM from Downunder (or are most of you looking up from the bottom?)
Time to stop keeping her all to myself...
Here is my new baby with just 300k's on the clock (180 miles for those that refuse to change)
Her now.... 4000k's on the clock, probably only 1/4 of that on the road. Been up to the top of the Carbon Performance tank covers in mud, dropped about a dozen times, only once real hard and the covers worked well....but she still scrubs up remarkably well. Touratech high front guard conversion, TKC80's
Of course now she's been riden a lot and loosened up, I needed some ribbing (Stomp Grip Pads) for that extra pleasure....really make it easier for me with my tired old knees to cling on for dear life, but will be interesting to see what they age like.
After an altercation with a large branch, I began experimenting with the windscreen, this is what suits me best with the wind cleanly hitting my Arai XD so I get some air, but largely keeping it of the body. No buffetting now between the lower screen and the mirrors I tweaked out a little wider (Used a pipe bender) . Now all I need is a new screen to rework as this has been bent so many times it is all cracked up, hence the black paint.
Found I had no sense of direction when following tracks on my own, so I added a Garmin Quest, using Garmin bike mount and small aluminium (AKA Aluminum) bracket straight to the dash, easy to see and use.
Had problems with right hand going to sleep as I was spending so much time on the pegs, fixed that with 608 bend Renthal fatbars.
Tourateck lock on glovebox. Dropped forks 10mm
What you can't see...
The catalysts just fell out of the mufflers, then the EPC and SAS systems fell off too, the AUS spec never had a canister like US spec, so I did not have to help this fall off.
Then someone came along and drilled a 16mm hole right through the centre of the mufflers, which makes suprisingly little difference to volume, just a little 'raspier' like Jimmie Barns, but breathes much better.
Lifted the needles a click and put them down again, fixed the lean spot with bigger pilots at first service which made all the difference.
16 tooth on the front, 45 on the rear, still way faster than I need, but lots easier in the tight stuff, a true six speed. It is now a pleasure to drive in traffic and on the highway at typical Aussie freeway speeds.
Made a custom pin for brake lever to actuating rod connection to tighten up the real sloppy pedal.
Got a Gel seat, used it twice to be sure, and then filed it under 'waste of money' the original seat breaks in quite quick if you bounce up and down on it in the dirt for a few hours. Also originally got KTM carbon tank covers with the bike, but it just fell over (honest) a day after I fitted them and the left one collapsed...I do not recomend the KTM ones at all.
Coming via post from the US..
Power pegz, KTM/FMF aluminium mufflers, Scotts triple clamp / damper combo & other assorted bling.
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream screwed with this post 10-04-2005 at 03:02 AM Reason: Typo's
Autostream is offline   Reply With Quote
Old 10-04-2005, 04:08 AM   #546
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,431
i happen to have them,,,
if you are doing the black out thing,,go all the way,,,hard anodize the swingarm ,shifter and all related aluminum components satin black,i''ll paint or powdercoat the hubs black
check www.woodyswheelworks.com for some of the trick looking stuff ya can get done,,,you're on the right track ,,,stunning looking bike ya have,,,if ya do more street than dirt,,you may want to consider going to 2.50 x19 front and 4.25 x17 rear,,,same size as all bmw GS wheels,,,hugh tire selection,,,can make tubeless to boot and you can really rock in the canyons,,,,your road handling will improve as well as the braking,,,and it'll lower the bike about 3/4'',,
just something to mull over,,,the thread and the pic
http://www.advrider.com/forums/showt...9&page=3&pp=10
woody's wheel works screwed with this post 10-04-2005 at 09:12 PM
Old 10-04-2005, 04:19 AM   #547
woody's wheel works
Built to Last
Oddometer: 3,431
hey ya need color coordinated rim weights
Originally Posted by scaryfast
Mine in front of work! And no the spot isn't mine!!
those silver rimweights stick out worse than the spot beneath,,we always try to color co-ordinate the rim weights ,,,just spray 'em with satin black krylon before ya install!!!
it'still a gorgeous bike!!!
Old 10-04-2005, 06:19 AM   #548
katoom_950
Life, 2 short 4 traffic
katoom_950's Avatar
Oddometer: 343
Now, only you would have looked directly at the wheels to notice this!
Do you dream wheel rims, offsets and spoke nipples at night Woody?
If only we had real bike professionals like you everywhere, especially looking after my bike!
Well spotted that man and a nice tip for detailing
yesterday is history, tomorrow a mystery, today is a gift, that is why we call it the present. - johnbaker
katoom_950 is offline   Reply With Quote
Old 10-09-2005, 06:20 PM   #549
Farioli
"just do it"
Farioli's Avatar
Oddometer: 539
During NRE, 2005
Thanks Mike for the pic
2015 Dakar Malles Moto #164
Thanks to my Family & Hunter Industries.
ICO Racing, Motionpro.
Farioli is offline   Reply With Quote
Old 10-09-2005, 08:55 PM   #550
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,478
It's good to see ya on the site. I had a great time riding w/ ya in Ouray. Looks like your doing great.
Any bike can be taken off road. The question is; How much fun did you have doing it?
04 950 GO!!!!! 2011 250 XC 89 Transalp 69 350 CL 04 225 XT
08 450 XC-F SOLD to a good home
YOGOI is offline   Reply With Quote
Old 10-13-2005, 05:27 PM   #551
zak0r
Oddometer: 69
thats her, bought mid august, has ~7.5k km now in two months of me actually being at home. she will go to service next tuesday and get mt21's as i am done with long road trips for this year and the enduro season has just begun.
mods are:
- pannier mounting
- akras
-custom ktm sommer heavy duty seat that is 3cm higher and also shaped better
- airbox mod
- 16t
- carbon performance tank guards
- orange exc fender
- scottoiler
- ungimped fork+pds setup
- mt21 (from tuesday on)
- removed rubber from pegs
- adjusted front rim shape (behr rims are )
- poweroutlet for laptop etc
- epc deactivated
- windshield cut 5cm
- 3cm handlebarrisers
- tt tank bag mounts
- neopren forkboots
zak0r is offline   Reply With Quote
Old 10-19-2005, 10:33 AM   #552
adrenalin-junkie
Oddometer: 475
Where in Upstate SC are you ?
I see that you are in upstate SC . I live in Greenville , SC and also have a 950 (ORANGE ) ,the orange ONES are apparently FASTER , but thet throw harder .My bike is at Neeley racing in Spartanburg to have repaired .Once I get it back we should hook up for a ride ,I have a couple of friends with a XR650 ,KLR650 , 950S and a V-Strom. My arm is currently in an orange cast after I ditched my bike on I-85 after a truck's retread was flung into my bike . :uhhuh
Originally Posted by JBird
NC Mountains
adrenalin-junkie is offline   Reply With Quote
Old 10-19-2005, 07:04 PM   #553
Greg Minor
The Trespasser
Greg Minor's Avatar
Oddometer: 2,322
Its a proven Fact just ask me
THE ORANGE ONES ARE FASTER!
Have maximum fun while preserving bike and body
2004 KTM 950
2003 Ducati Multistrada
2001 Honda XR 400
1988 C&J Honda 625
1970 Honda SL 100 (green)
Greg Minor is offline   Reply With Quote
Old 10-19-2005, 07:06 PM   #554
Greg Minor
The Trespasser
Greg Minor's Avatar
Oddometer: 2,322
[QUOTE=johnnyotis]BEFORE
There are a couple of items in the lower right corner of this photo that have peaked my interest
2004 KTM 950
2001 Honda XR 400
1988 C&J Honda 625
Old 10-20-2005, 08:30 AM   #555
AZcacti
Dope on a Rope
AZcacti's Avatar
Oddometer: 1,321
Thanks Greg!!
AZcacti is offline   Reply With Quote
Times are GMT -7.   It's 11:37 PM.
