Old 11-05-2012, 10:16 AM   #211
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,363
Originally Posted by gbacque View Post
Can you deep cycle these batteries? How do they handle a long slow drain to empty before being recharged?
Application: Run three or four HID lights on a boat for bow fishing off just battery power. One or two of the big guys.
Lots of variables to consider, but say you were running (4) x 35 Watt HIDs at 35 Watts each for a total of 140 Watts.
You would end up with almost a 12 amp battery drain, so with a 24 amp hour battery you would be looking at only 2 hours of light. Really no advantage except for small size. Marine Deep Cycle Lithium batteries exist but are super expensive.
If you went with an LED light bar you could get by with much lower drain....
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 11-06-2012, 10:55 AM   #212
redbastard
redbastard's Avatar
Oddometer: 1,124
Order placed!
time to take a little weight off my Wr250f. Just ordered one of your 4 cell battries. Can't wait to get it.
Jonathan
redbastard is offline   Reply With Quote
Old 11-06-2012, 06:02 PM   #213
teambft
teambft
teambft's Avatar
Oddometer: 1,189
Battery order
Just bought a 4 cell Ballistic. Is it possible to get it to me by Saturday? I'm at 37027.
Will buy another soon for my other bike.
Thanks!!!!
2011 KTM 300 XC-W, 2001 Aprilia Falco, 2010 KTM 530 XCW Six Days, others
2012 KTM 500 EXC - sold, 950 SER-sold (regret)
Prior: BMW XC, TE610, KLR 650, 07 KTM 990 Adv, and many more ...BMWs, Ducs, KTMs, Harleys
teambft is offline   Reply With Quote
Old 11-06-2012, 09:52 PM   #214
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,363
Thanks!!!!
To be honest, the 4 cell just went on backorder after the Redbastard got the last one. The next shipment will arrive by the end of the week, but I won't be able to get it to you Saturday. We have Earth X models to fit pretty much every bike, but they are slightly more expensive.
Jim
Old 11-13-2012, 09:16 PM   #215
DiabloADV
Semi-Occasional
Oddometer: 2,254
Got this today...it's rare that a lightweight product actually weighs less than they claim...
Should be perfect for relocating the battery of my airhead dirtbike up under the seat.
1974 R90/6 w/1050 kit. Motor only. Seeking a frame.
1970 R60/5
'91 Bill Holland Steel w/Dura Ace
'01 Z3 3.0 Coupe. The Clownshoe.
DiabloADV is offline   Reply With Quote
Old 11-15-2012, 06:16 PM   #216
teambft
teambft
teambft's Avatar
Oddometer: 1,189
Any word on my battery? Has it shipped?
Jim
Old 11-16-2012, 02:39 PM   #217
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,363
The AM04s are here and yours is going out!
Thank you.
Old 11-26-2012, 11:00 AM   #218
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,363
Free shipping coupon
Free Shipping until the end of 2012!* Use coupon code SHP2012
*Priority Mail USA only.
Old 01-11-2013, 10:31 AM   #219
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,363
Big Bike Model Spec Sheets
By popular demand, here are the spec sheets for the most popular adventure / street models. More to come soon, but they will show up as separate threads so no to cross post.
EarthX is a great product and they have taken care not to advertise on false promises or exaggerated cranking power like the other manufacturers. They are ultra-light and designed to exceed OEM capacity in all conditions. They use a combination of Cylindrical and Prismatic cells to get this added reserve power, and also FINALLY.... have a built-in BMS circuit so no cell balancing or out-of-balance battery failure. Also, a FULL 2 year warranty. Not tiered like the others.
Always check the Vendor Discount Sticky thread. You'll find us there.
PM me for any questions...
herrhelmet screwed with this post 01-11-2013 at 01:19 PM
Old 01-12-2013, 08:46 PM   #220
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,552
My X-Challenge takes a Yuasa YTZ10S and it is pretty snug. Would you happen to know the largest EarthX battery that will fit (ETX18C maybe?). Or would I need to stick with one of the "B" size? Thanks.
Marc
07 XChallenge
Butters is offline   Reply With Quote
Old 01-13-2013, 12:01 AM   #221
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,363
Geez, I know those are tight... helped a friend install a battery in one... What is your max dimensions and I can check for you.
JIm
Old 01-13-2013, 02:18 AM   #222
DiscoDino
DiscoDino's Avatar
Oddometer: 1,819
JIm
FWIW, I was able to barely fit a 12cell Ballistic battery in that red plastic body...
Adventurer transitioning from 4x4 to 2x1
'07 G650Xch - Under Mod-struction
DiscoDino is offline   Reply With Quote
Old 01-13-2013, 12:37 PM   #223
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,552
JIm
Not sure on the box without tearing it apart, but even where there is room, the cables tend to take up that space. The YTZ10s is 6 x 3 7/16 x 3 11/16 (per Yuasa). The box could possibly tolerate more width, but the cables run beside the battery so I'm not sure I'd want too go much wider (Thicker). If I recall right, not much room to go up either. Probably some room to spare length-wise, maybe a bit over 6" would fit. Ideally, probably nothing more than about 1/8" bigger than a typical YTZ10s, maybe 1/4" to play with on the length dimension.
Marc
07 XChallenge
Old 01-13-2013, 02:09 PM   #224
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,363
For a more powerful battery I think the ETX18B should fit nicely assuming you have a lttle room for the height of 4"
I measured more precisely than the specs:
5.290'" L x 2.625" W x 4.05" H
They come with small pieces of adhesive foam since it's a narrower battery, the cabling may work better.
Jim
Old 01-13-2013, 04:54 PM   #225
Butters
Kwyjibo
Butters's Avatar
Oddometer: 2,552
When I get a minute I'll tear the bike apart and see how it looks to be certain. DiscoDino fit the 12 cell Balistic, which is listed at 4.25" high, so it should probably work. Thanks for the assistance! (and to DD too).
Marc
07 XChallenge
Times are GMT -7.   It's 12:57 AM.
