Old 05-01-2011, 09:19 AM   #61
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
Originally Posted by mpanther View Post
Would it be possible to get a 2.3ah battery made that is two X two?
I would guess this would have a size of 2" X 2" X 2.75"
Matt, how soon would you need it? I can custom make one, or have one set up that way by my guys the next time I make a production run in the next month.
Jim
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 05-01-2011, 01:18 PM   #62
mpanther
KotW - Just Ride!
mpanther's Avatar
Oddometer: 1,036
Jim
probably After the Remix. no rush.
I have some measuring to do, if it works I might need Two.
but I'm not sure yet.
Peace in your heart & Light on your soul.
ad·ven·ture n.
1. Participation in exciting or hazardous experiences.
2. An undertaking of a questionable nature.
3. An undertaking of a hazardous nature.
'83 GL650swi "My Little Grey Lady"
'86 LS650 Milady's bike
mpanther is offline   Reply With Quote
Old 05-18-2011, 09:48 PM   #63
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,694
Originally Posted by h8chains View Post
jim, this is the answer!
i am putting an electric starter on the xr400 and there's no room for a regular size battery.
your batt is the perfect size. i will order once i get all the stuff installed.
electric starter is now installed!
the new battery is the perfect size for the limited space i have under the seat....; side by side with the old baja kit battery.
NSFW is online now   Reply With Quote
Old 05-22-2011, 05:00 PM   #64
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
10% ADV Coupon code!
ADVRIDER000000000001
This is for all items. Thanks for all your support!
Jim
Old 05-31-2011, 05:52 PM   #65
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,325
hey jim can you put an overcharge cutoff on these? i am real interested in one right now.
2 SPOT is online now   Reply With Quote
Old 05-31-2011, 06:41 PM   #66
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
I used to have them made with a connector for this type of overcharge protection:
(I don't sell these myself)
http://www.all-battery.com/protectio...erypack-2.aspx
...but frankly there has been no need for them as used as a starter battery. What kind of application are you planning? If your bike has a steady 14.8 V output during running you won't hurt the battery. If there was a lot of demand for the plug I could have it added back in, but it ads another $15 to the battery packs.
Jim
Old 05-31-2011, 07:28 PM   #67
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,325
it will be a starting battery for my bike, it runs a consistent 16-18 volts and nothing i have done or read changes it.
Old 05-31-2011, 07:51 PM   #68
mpanther
KotW - Just Ride!
mpanther's Avatar
Oddometer: 1,036
Have you thought about changing to a different voltage regulator or even putting one right between the battery and the rest of the bike/stock regulator?
ad·ven·ture n.
Old 05-31-2011, 08:25 PM   #69
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
+1 Matt. Either a dead VR or no VR. 18 volts will kill any battery.
Old 05-31-2011, 08:57 PM   #70
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,325
sure i thought about it, and i'd do a mosfet if i could but apparently mine is a super duper special black ground wire reg/rec and it needs to be replaced with the same. i'm pretty good with electrical and have done much reading but i think i need to rewind and change the whole charging circuit? i dunno for sure, i dont fry lead batteries, my current one is 1.5 yrs old and i am replacing it because it broke this past w/e mechanically, not electrically.
Old 05-31-2011, 09:08 PM   #71
mpanther
KotW - Just Ride!
mpanther's Avatar
Oddometer: 1,036
its a reg/rec with a black ground wire. i'd like to run a mosfet style but aparently I can't as it needs the ground wire. I don't know a bunch about it so I have been relying on reading and manufactureres.
There are regulator/rectifiers (R/R) and just regulators out there.
if you don't want to mess with changing your current charging system. and a New R/R does not fix it. try picking up a small stand alone 12v regulator.
they have some cheap 4 wire ones from china. just carry an extra one with you in the tool kit encase it fails. lol.
there is no problem running 18v dc into a R/R either. it will will just ignore the diodes in side that "rectify" it and regulate the voltage down to it's set output.
That said, you don't actually Want 12v output. you want 13.2-14.5v output.
Most bikes regulate to about 14.2v.
If your bike does not have a starter, it has a single wire running into the postoperative side of the battery. if you put a small 12v regulator on this wire between the bike and the battery positive, and a second wire that bypasses the regulator with a hi amp diode in it, A 5amp diode should work fine, set to block the 18v system voltage, but allowing battery voltage to flow back to the bike. (if system votlage is lower than battery voltage)
you will have 14.2v at the battery charging it, no mater What system voltage is on the bike while it is running.
Here is a cheap one that would work.
http://cgi.ebay.com/ebaymotors/Regul...item2307405968
or you could buy one for a modern sport bike or something.
I plan on doing something similar for my KE100 and DT175.
I will rewire my stator to put out 12+v (if it isn't already.)
install a battery from here, install 12v lights and a 12v R/R.
Then take a small 6v (7.2v) R/R similar to the 12v I linked to.
this will be set between system voltage and the ignition system.
Should kick start really well with 7.2v available from the system voltage even before it starts running.
Plus, i can do all the cool stuff with my lights and charge my cell phone or a GPS.
(and my light bulbs will be available Anywhere. lol)
ad·ven·ture n.
Old 06-28-2011, 02:00 AM   #72
peter650
Oddometer: 422
Do you post to Australia?I have a klr650 kick start only,but has a 1.3amp electric waterpump.What would be the smallest battery i could use?Cheers Peter
peter650 is offline   Reply With Quote
Old 06-28-2011, 05:38 AM   #73
-N8-
Ride like you stole it!!
-N8-'s Avatar
Oddometer: 125
herrhelmet
Placed an order for my Dakar. With the BMW electrics how long could the battery remain hoked up before the voltage gets too low, (obviously I would disconnect for extended periods, eg; winter) but could you leave it for say a week or two? Longer? Is it alright to top off with a trickle charge every few days if its not getting ridden?
2006 BMW F650GS Dakar
The More moving parts...the safer I feel!!
-N8- is offline   Reply With Quote
Old 06-28-2011, 06:41 AM   #74
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
We post regularly to Australia...
As long as your charging system works and you only have stock lighting you could get by with the 2.3 Ah.
Old 06-28-2011, 06:44 AM   #75
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
Originally Posted by -N8- View Post
herrhelmet
If its just the digital clock and no alarm, etc. you can leave it without a charger for weeks. If you are going to have a charger connector that sticks out of the bike, check the voltage after a few days and if it/s around 13.3 it should hold that for some time.
Times are GMT -7.   It's 05:10 PM.
