Old 03-05-2011, 11:00 PM   #16
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
Hi Mike,
My comments inline:
Originally Posted by Mike Philippens View Post
I read about the rattle and now I'm wondering if that's the rattle I hear lately with my R850RT. It's fine when I don't toch the throttle (idling). But when I just tension the throttle cable a little bit, the revs are not rising yet, I hear this rattle. Not very loud, but it is there. It seems to come from the left side. First I thought it was the valves, but I don't notice any drop in performance whatsoever. It runs as smooth as ever, it's just that rattle.
A couple of questions:
*do I need to do both sides at the same time? They are subjected to the same wear.
Usually, the R/H side wears faster than the L/H side.
*I have a 1997 R850RT. Are the throttle bodies the same?
Dunno what you mean by the same... But I have kits for your bike, both right and left side.
*what are other effects of the wear? What's this surge?
Besides the annoying ticking sound, I have found that by repairing the TB's, a valve adjustment and a sync, the surging was gone. I still had surging after only doing a valve adjustment and sync.
Surge is when you keep the bike at a constant rev while cruising but the riding is not smooth - you would have uneven speed for small periods of time, but constant. Nut sure if observable on the tacho but you can feel it while riding, the bike would like drop the revs then come back. Most probbably to feel it while riding at 2000 RPM in 3rd gear.
*My bike's got nearly 160.000km on the clock. Is that a reasonable milage for this wear?
Most probably. The spindles on my '96 RT had wear on them @ 47k km's. It depend on how much do you use the bike inside a city, where the throttle sees a lot of action, resulting in wear.
Also I had a lot of customers having this issues on 1150's, these bikes usually have lower mileages than the 1100's since they are newer.
So it's not a subject of manufacture year but a matter of mileage and how much do you ride inside city or outside(wear is directly proportional with how much you use the throttle).
Best test is to get the fairing off the bike and get your fingers on the back of the TB's, and check if the pulleys, where the cable goes around them has any play. It shouldn't. Play in the pulleys mean that the spindles are worn.
Dan Căta is offline   Reply With Quote
Old 03-06-2011, 12:58 AM   #17
Mike Philippens
John Deere
Mike Philippens's Avatar
Oddometer: 31
Originally Posted by Dan Căta View Post
Hi Mike,
Ok, thanks. I'll check when I get the chance.
I mean that the topic says R1100/1150, and I have an 850. So, that's why I asked.
BMW R850RT Adventure - Yamaha XT600Z Ténéré (34L)
Mike Philippens is offline   Reply With Quote
Old 03-06-2011, 01:36 AM   #18
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
Yes, I have checked with realoem.com and the intakes have the same code. So the kits fit to your bike too.
We can continue this discussion on PM.
Dan.
Old 03-23-2011, 02:37 AM   #19
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
As an update:
I have found that instead of using a copper wire to remove the bushings, a bent plastic zip tie works even better.
On some recent repairs I just bent one zip tie and put the screw inside it. The bushing comes out easily ;)
Dan.
Old 03-24-2011, 01:56 PM   #20
inoxjewels
Oddometer: 2
Wink TB kit
Hi Dan, email has sent.
inoxjewels is offline   Reply With Quote
Old 04-03-2011, 10:36 PM   #21
inoxjewels
Oddometer: 2
mission completed :o)
Hi Dan, all the items you prepared, are working great! Everything installed easy, my bike runs like the new again! Thank you, Istvan
Old 04-03-2011, 10:45 PM   #22
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
Hi Istvan,
I am glad it all worked out fine for you ;)
Thanks,
Dan.
Old 04-26-2011, 01:52 PM   #23
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,090
One added aspect I didn't see mentioned.
When I disassembled my TB's I made sure to match the butterfly plate to the bore. This of course required that the throttle stop screw be 'changed' which leads to a whole nuther level of complication in terms of getting back to the stock setting. So this step may not be worth the extra hassle for most folks.
But if the stop screw has been messed with, then do make sure you tweak the placement of the butterfly plate in the bore. Granted it's not a huge deal but it can affect the wear of the plate on the bore and will help close up the differences between the 2 sides wrt matching their idle settings.
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline   Reply With Quote
Old 05-30-2011, 08:01 AM   #24
scottydad
Oddometer: 1
need kits
Hey Dan I have a 2004 BMW r1150rt. I need to rebuild both lt and rt throttle bodies. Do you combine shipping costs? How do I purchase thank you I live in USA
scottydad is offline   Reply With Quote
Old 05-30-2011, 08:03 AM   #25
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
PM sent.
Thanks,
Dan.
Old 06-10-2011, 12:38 PM   #26
skip gatrell
Oddometer: 29
Throttle body repair kit, GS1100r, right side
Hello Dan,
How do I go about ordering a repair kit for my 1996 R1100GS? I like in California, USA.
Skip
skip gatrell is offline   Reply With Quote
Old 06-12-2011, 06:16 PM   #27
LoneRider
LoneRider's Avatar
Oddometer: 2
Need to buy
Dan, I need to buy two kits from you. Bike is '05 1150 Adv., 93.000kms on the clock. could you send me email for details? Thanks.
LoneRider is offline   Reply With Quote
Old 06-13-2011, 02:17 AM   #28
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
Message sent.
Originally Posted by skip gatrell View Post
Hello Dan,
Skip
Email sent.
Dan
Old 06-13-2011, 05:47 AM   #29
Tbone
off-ramp slayer
Tbone's Avatar
Oddometer: 4,327
Used the kit on the right side tb Dan and the bike idles and runs smoother!
Tbone is offline   Reply With Quote
Old 06-13-2011, 01:08 PM   #30
Dan Căta OP
Dan Căta's Avatar
Oddometer: 1,678
I am happy you got it running right ;)
Dan.
Times are GMT -7.   It's 08:11 AM.
