Old 10-20-2010, 08:35 AM   #1
TowPro OP
Lets ride
Oddometer: 3,242
cable lubing
Some forums say "don't lube cables, they are made to not be lubricated" or "the lubrication will attack the plastic liner and destroy the cable".
I have lubed every cable on every bike I have ever owned for the last 40 years. What should I do for my 2010 F800GS?
I have the proper tool that clamps onto the cable allowing you to inject "lube" from the straw on the can.
I have lube made for cables, but I always preferred Tri-flow.
I also have this new DuPont Chain lube (O ring safe) which is beautiful stuff. Goes on wet and drys real nice leaving a Teflon coating. (the matching cleaner worked real nice to remove the factory crud, I mean chain lube).
To lube or not to lube (and what to use), that is the question.
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 10-20-2010, 11:32 AM   #2
GB
Mod Squad
GB's Avatar
Oddometer: 56,897
Dealer says not to lube, the interior of the sheathing is teflon coated, lubing the clutch cable is not recommended or required.
Old 10-20-2010, 11:46 AM   #3
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Good info Gadget Boy. Thanks.
Old 04-04-2012, 06:37 AM   #4
malloy
Oddometer: 772
Question
FWIW: Haynes says to lube. What about the RepRom? How about lubing with DuPont Teflon? BUMP for more opinions.
F650GS (Build Date 11/11)
malloy is offline   Reply With Quote
Old 04-04-2012, 07:28 AM   #5
epicxcrider
epicxcrider's Avatar
Oddometer: 647
Tri-flow would be a good compatable lube if you need it. But I wouldn't do it until it becomes "sticky" as otherwise it will just attract dirt.
Old 04-04-2012, 08:46 AM   #6
conrado
conrado's Avatar
Oddometer: 269
The RepRom doesn't mention lubing.
'11 BMW R1200GS Adv (Germany)
www.duasmotos.com
conrado is offline   Reply With Quote
Old 04-04-2012, 09:29 AM   #7
señormoto
Supermoto Abuser
señormoto's Avatar
Oddometer: 1,110
Carry a spare cable and don't lube the stock one.
I have a feeling that there are some decisions being made on certain teams lately to make things more complex in order to ensure a certain technological standard of confusion is met.
señormoto is offline   Reply With Quote
Old 04-05-2012, 10:20 AM   #8
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
I have a lot of kms on the original cables WITHOUT ANY HANDGUARS, so the clutch + throttle are a bit exposed.
a) to date.. clutch operates INCREDIBLY EASILY... even easier, than 1150 hydraulic. I lube only the both ENDS (not the bowden cable) with WD regularly
b) throttle cable is a bit worse.. but not exactly bad
so the cables and bowdens on 800GS look quite a wear-resistant.
pure onroad.
R1200GS 2013 LC, F800GS '08 (130 000+km)
.de + .at + .it + .sk + .pl + .hu + .li + .ch + .fr + .es + .p + .and + .lu + .be + .nl + .uk + .sco + .ork + .slo + .hr + .bih + .srb
Hicks is offline   Reply With Quote
Old 04-06-2012, 04:57 AM   #9
malloy
Oddometer: 772
Thanks for the replies, one and all . Consensus is don't lube except a little grease on the nubs at the ends of the cables. Quite a change. Back in the day lubing cables was SOP and messy without the cute little lubing device available today. Broken cables were not uncommon, especially on dirt bikes. I have to admit to not lubing the throttle cables on my R1200GS but was pretty religious with other bikes. I haven't broken a cable in years.
Ah, Teflon - the wonders of science and our space program .
Old 04-06-2012, 05:35 AM   #10
Hicks
der Überluber
Hicks's Avatar
Oddometer: 457
this week I've lubed again the ends (I mean the roll directly in the clutch lever and the joint on the opposite end connecting a cable to the clutch lever on the engine) with WD and the clutch operates a bit easier.
So the basic lubing still increases the comfort and wear ;)
Old 04-06-2012, 02:41 PM   #11
Olvi
Ice Butt
Olvi's Avatar
Oddometer: 98
and gathers dust and dirt to increase stickiness and wear....
If you want to lubricate those parts or levers, use dry film lubricants like LE Almasol Dry Film Lubricant.
www.dustywobbls.com
Olvi is offline   Reply With Quote
Old 04-06-2012, 04:08 PM   #12
señormoto
Supermoto Abuser
señormoto's Avatar
Oddometer: 1,110
+1, and the inside of the cable housing does not need any lubrication because the lubrication is actually less productive than plain teflon. Reference: "The coefficient of friction of plastics is usually measured against polished steel.[13] PTFE's coefficient of friction is 0.05 to 0.10,[9] which is the third-lowest of any known solid material (BAM being the first, with a coefficient of friction of 0.02; diamond-like carbon being second-lowest at 0.05)." http://en.wikipedia.org/wiki/Polytetrafluoroethylene
I don't see how the cables being used with or without handguards makes any difference to the operation of the clutch. If you were riding offroad and doing woods riding where the clutch line was apt to be snagged and pulled on by branches that would be one thing, but you aren't.
What exactly are the cables and clutch lever being exposed to in your situation: air?
Hicks - please lay off the ganja before posting - you're not making any sense lately.
señormoto screwed with this post 04-06-2012 at 04:14 PM
Old 05-10-2012, 05:55 AM   #13
MotoRandy123
MotoRandy123's Avatar
Oddometer: 135
I always lube a new bikes cables with silicon oil use for R/C cars. I believe it stops corrosion on the steal cables. They may not need lube but if they rust they won't move so easy...
MotoRandy123 is offline   Reply With Quote
Old 05-10-2012, 06:12 AM   #14
veloce
Oddometer: 33
There is a lot of bad information in this thread.
WD40 is not a lubricant it is a WaterDisplacer. WD40 will dissolve plastics, and is hygroscopic, which will cause your cables to corrode, and will collect dirt.
Silicone oil should never be used for metal to metal contact. It is good for polymer to polymer and polymer to metal, but when used in metal to metal, it will inhibit the formation of an oxide coating an cause galling of metal surfaces. It will actually accelerate wear.
Modern cables have a teflon liner. There is actually no metal rubbing. The teflon itself has a low friction coefficient with metal, thus needing no lubrication. (think of it as pre-lubed)
The only lubricant that is not a bad idea is tri-flow. It is a dry lubricant, so it will not collect dirt as much, and will not attack plastics.
veloce is offline   Reply With Quote
Old 05-10-2012, 12:05 PM   #15
GH41
Oddometer: 822
I wanted to say the same thing but I didn't want to get into a month long pissing match with Hicks! I wouldn't use WD40 on anything unless I wanted it to rust!! I agree with you 100%. GH
GH41 is offline   Reply With Quote
Times are GMT -7.   It's 09:43 PM.
