Old 01-23-2013, 05:42 PM   #211
GrahamD OP
GrahamD's Avatar
Oddometer: 5,289
How to induce a hard start issue
There have been a few users experience the dreaded "hard start".
There is a particular set of things that have to be done to induce this.
Since I have never had this problem I was keen to see whether I could induce it by running through a few scenarios that have led to it...
This is a bit of a log to see whether I could nail down the important parts.
First day was just running through a few of the ideas that had been floating around. (sped up so it doesn't drag on too long)
20th Jan 2013
That was a complete fail as far as the hard start goes.
But often people talk about the bike being left for a few days after fiddling or washing.
Well after 2 1/2 days of sitting without the bike being touched and that includes not charging the battery...
23 Jan 2013.
Now it was cleared pretty easily by going for 1/2 throttle, Some go Wide open and it clears.
After the last video I gave the battery a good rest and a charge.
24 Jan 2013
Started fine. Starting to think it is a combination of a slightly flat battery, cold bike and being left after some short runs.
26 Jan 2013
Last hard tests...
Pretty clear how it happens, pretty clear how to clear it. Put it down to modern closed loop FI. Also note that after the ECU "thinks" the engine has fired , probably from the initial burst of engine acceleration, it turns the headlight on. If you want to save some battery life cycle the ignition again and the headlights will turn off again. No point burning 100W for no reason. It may be a part of the problem.
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD screwed with this post 01-25-2013 at 01:48 PM
GrahamD is offline   Reply With Quote
Old 01-05-2014, 12:11 AM   #212
GrahamD OP
GrahamD's Avatar
Oddometer: 5,289
2013 / 2014 Model differences
Differences between the 2013 XT1200Z and the 2014 XT1200Z and ZE (Europe), according to YAMAHA
2014 XT1200Z
Refined engine with 112PS (82.4kW) @ 7,250rpm and 117 Nm
•Enhanced D-MODE switchable mapping characteristics:
•More relaxed and easy feeling in “T” mode
•More exhilarating and exciting sport riding in “S” mode
•Enhanced driveability from mid to high speed range
•More enjoyable feeling during acceleration and at higher rpm
•Smoother shifting up and down between 2nd and 3rd gear
•New: Manually-adjustable 4-position screen with GPS holder
•New: Cruise Control for more relaxed long distance touring
•Enlarged intake and exhaust ports
•Lighter camshaft assembly
•Redesigned piston rings
•New exhausts
•Enhanced shaft drive damper assembly
•New rubber clutch damper adopted
•Reduced weight
•New: LCD instruments with multi-function display
•New: Gear Position Indicator
•New: Compact LED flashers
•New: Extra protection cover under headlights
•New: Tapered aluminium handlebars
•New: Handlebar crown and bar holder
•New: Enhanced more upright riding position
•New: Redesigned 2-tone stitchless low-profile dual seat
•New: Tail cover
•New: Small muffler protector
•New: Redesigned forged aluminium sidestand
In addition the 2014 XT1200ZE has..
•Electronically adjustable front and rear suspension
•Total of 84 potential suspension settings
•Grip warmers fitted as original equipment
•Top case base
•Assist grip
•Main stand (Centre Stand)
Intruments
2013
2014
GrahamD screwed with this post 01-05-2014 at 12:19 AM
Old 01-05-2014, 08:18 AM   #213
Kawidad
Kawidad's Avatar
Oddometer: 4,751
excellent work
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 01-05-2014, 08:42 AM   #214
sallydog
no more Green KLR
sallydog's Avatar
Oddometer: 5,535
that sure is nice
Its not who dies with the most toys.. Its who wears out the most toys
Just dip me in beer and toss me in the drunk chicks.
if you havent grown up by age 50 you dont have to
Heaven's the place where all the dogs you've ever loved come to greet you
sallydog is online now   Reply With Quote
Old 01-05-2014, 09:38 AM   #215
William42
William42's Avatar
Oddometer: 2,615
Nice job GrahmD. As always.
Mud is evil
William42 is offline   Reply With Quote
Old 01-05-2014, 10:35 PM   #216
silverspurs
what's over there?
silverspurs's Avatar
Oddometer: 866
Yes; good summery Graham... thanks.
Word is that the 2014 won't be released for sale in the States until all previous inventory has been sold... (due to a large inventory here) anyone know if that is true?
Also; what is the new "weight" projected to be??
thanks again for the update, I'll probably upgrade at some point, but I'm in no hurry.
"I have never been lost, but I will admit to being mighty confused for a while."
-Daniel Boone-
Yamaha 1200 Super Tenere, KTM 525exc, Yamaha TW 200
silverspurs screwed with this post 01-05-2014 at 11:08 PM
silverspurs is offline   Reply With Quote
Old 01-05-2014, 11:42 PM   #217
GrahamD OP
GrahamD's Avatar
Oddometer: 5,289
XT1200ZE [Z] Secifications.
Engine type Forward-inclined parallel 2-cylinder, liquid-cooled, 4-stroke, DOHC, 4-valves
Displacement 1,199cc
Bore x stroke 98 mm x 79.5 mm
Compression ratio 11.0 : 1
Maximum power 82.4 kW (112PS) @ 7,250 rpm
Maximum Torque 117.0 Nm (11.9 kg-m) @ 6,000 rpm
Lubrication system Dry sump
Fuel Delivery Electronic Fuel Injection
Clutch Type Wet, Multiple Disc
Ignition system TCI
Starter system Electric
Transmission Constant Mesh, 6-speed
Final transmission Shaft
Frame Steel tube backbone
Front suspension Upside-down telescopic fork, 43 mm
Front travel 190 mm
Caster Angle 28
Trail 126 mm
Rear suspension Swingarm, Adjustable preload and rebound damping, (link suspension), Monoshock
Rear Travel 190 mm
Front brake Hydraulic dual disc, 310 mm wave discs
Rear brake Hydraulic single disc, 282 mm wave disc
Front tyre 110/80R19M/C 59V
Rear tyre 150/70R17M/C 69V
Overall length 2,255 mm [2,250 mm]
Overall width 980 mm
Overall height 1,410 mm
Seat height 845/870 mm
Wheel base 1,540 mm
Minimum ground clearance 190 mm [205mm]
Wet weight (including full oil and fuel tank) 265 kg [257kg]
Fuel tank capacity 23 litres
Oil tank capacity 4.2 litres
GrahamD screwed with this post 01-06-2014 at 03:23 AM
Old 01-06-2014, 12:18 AM   #218
silverspurs
what's over there?
Oddometer: 866
Thanks!... Kg's are Greek to me!...
I'll get my calculator out...
looks like about 18 lbs less... or 566 lbs net
-Daniel Boone-
Old 01-06-2014, 03:05 AM   #219
McBoab
Fast side of farty
McBoab's Avatar
Oddometer: 276
Doing a comparison on Yamaha UK the 2014 ZE spec is 4Kgs heavier (265kg)than the 2012 spec S10 (261Kgs) probably due to the extra bits like electro sussies and adjustable screen /larger cat.
The new 2014 stripped out basic S10 is listed as being 257Kgs .
Don't know if this link will work but is a comparison of 2014 S10, 2012 S10 2014 S10ZE and 2012 World crosser (though no different to the other 2012)
http://www.yamaha-motor.eu/uk/produc...,552148,464261
The older bikes are easy to spot as they only have 80.9Kw listed
blah
McBoab is offline   Reply With Quote
Old 01-06-2014, 03:26 AM   #220
GrahamD OP
GrahamD's Avatar
Oddometer: 5,289
Thanks for that
The only thing I don't understand is this spec from the XT1200Z...
Overall height 1,410 mm high 1,470 mm ??
Old 01-06-2014, 05:28 AM   #221
twinrider
pass the catnip
twinrider's Avatar
Oddometer: 9,294
Originally Posted by GrahamD View Post
Thanks for that
Sounds like they measured from the top of the windshield.
twinrider is offline   Reply With Quote
Old 01-06-2014, 05:46 AM   #222
GrahamD OP
GrahamD's Avatar
Oddometer: 5,289
Sounds about right
Old 01-06-2014, 09:48 AM   #223
fredz43
Location: Illinois- land of straight, flat, boring roads.
Oddometer: 623
Here is an article with some interesting weights of actual adv bikes ,ready to ride:
http://www.touratech-usa.com/Adventu...igh-In-Results
fredz43 is offline   Reply With Quote
Times are GMT -7.   It's 10:05 PM.
