Old 05-15-2012, 06:49 AM   #1171
Land
Wanderer
Land's Avatar
Oddometer: 3,834
Originally Posted by BgDadddy View Post
It looks like my Superfly with the built in doors.
Awesome tarp!
http://www.warbonnetoutdoors.com/gal...&g2_itemId=148
Originally Posted by 6USMC6 View Post
Doc's tarp is very similar to the Warbonnet Superfly, but his is actually a Wilderness Logics Oldman Winter -- and he has a pole mod done to his. See the middle of the tarp? There's a sectional aluminum, shock-corded pole under there. The Oldman Winter also has two cat cuts along each side and a center guy-out point.
I'm sure that Erik will be along before long to tell us more about it, but it's a really cool tarp.
Chris
I'm not lost. I'm explorin'.
"My dream is to live my life as best I can before I die, even if it kills me." -- Mr. Cob
"If you're on ADV and you're still anonymous, you're doing it wrong." -- Boondoggle
Land is offline   Reply With Quote
Old 05-15-2012, 10:19 AM   #1172
docwells7
docwells7's Avatar
Oddometer: 7,024
Chris
Not much else to add. Wilderness Logics Old Man winter with pole pockets sewn in at the center tie out points. Makes it quite roomy inside
The pole is seven sections @ 16" each, so it fits in most panniers or top-boxes. I'm not a gram weenie since I don't really hike...the VFR didn't complain about the extra weight
The one thing I have noticed from making purchases from Wilderness Logics is that Marty really turns orders around quickly. I ordered the tarp on Thursday afternoon and had it by Tuesday the next week.
Edit: Chris, I didn't get a chance to see you on Sunday before I left. When I left, I honked at your tarp/hammock, but then I realized it was just your pants hanging from the ridgeline.
'1984 was a warning, not an instruction manual.' - Unknown
IBA#25276
Airhead#9654
docwells7 is offline   Reply With Quote
Old 05-15-2012, 12:02 PM   #1173
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,743
Thanks doc.
Two more questions: The pole is one piece (16" sections).
Does it stay in place with tension?
Is there a continuous sleeve?
Or is there a tie in the center to keep the pole located?
Who made the pole?
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 05-15-2012, 12:07 PM   #1174
Land
Wanderer
Land's Avatar
Oddometer: 3,834
So YOU are the FF who woke me up!
Just kidding. Sorry I missed you Sunday. When are you heading back up?
Chris
Old 05-15-2012, 12:46 PM   #1175
docwells7
docwells7's Avatar
Oddometer: 7,024
Thanks doc.
Who made the pole?
It's just like a tent pole. Shock-corded together with end caps on both end pieces. Total length is just over 112".
No. Just two 1.5" pockets located at the center tie out point.
The method I was told, and works well to install, is to tie down one side of the tarp. Leave the other side slack. Install the pole over the ridgeline and into the pocket on the tied down side. Then tie down the other side. You can tie down the center tie outs if you want, but not necessary. One benefit with a silnylon tarp is that usually you need tensioners to gather up the slack when it cools, but the pole tends to take up the slace and just spreads out a little bit. Just makes construction of the tie outs easier. The instructions I got said to tie the pole to the center, and that may be an issue in the wind, but I didn't do it, and it stayed put 24 hours.
I got mine from Wilderness logics as a special order item. It's not an item on his e-store.
If you want to check out another cool solution to the same problem, check out the Hard Rock Winter Tarp. Same basic tarp design, but uses two three section carbon fiber poles on the outside that attach directly to the side pullouts. It's a slick design, and you could probably pull it off as a DIY project with a little thought. After talking to Marty at WL, it's clear that with the pole sections and some sort of attachment, I could go that route if I choose. I like this version...less loose pieces to keep track of.
Hope this helps.
Edit:
If you look closely, you can see the pole entering the pocket on the inside of the back wall. This is my modified porch mode for sitting around during the day. I can use poles if needed, but this works well enough.
IBA#25276
Airhead#9654
Old 05-15-2012, 02:44 PM   #1176
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,743
Nice!
Mike -
Old 05-15-2012, 06:29 PM   #1177
RAGBrian
jonesing for a ride
RAGBrian's Avatar
Oddometer: 1,026
All this talk of your fly's has got me looking....
for something for me!
Found this doing a search online:
Kelty Noah's Tarp 12
12 ft x 12 ft - Diagonal width is 17 ft.
Poles and tie outs not included.
Approx. 3 "Jackson"s plus shipping.
RAGBrian :: NC700X ::1978 CX500 Standard :: 1976 CB360T ::
"Going where you don't belong, I decided a long time ago, is the root of all misery and the soul of all adventure." - Peter Egan
RAGBrian is offline   Reply With Quote
Old 05-15-2012, 07:30 PM   #1178
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,743
Look around for last years model (essentially no difference). I bought a 12' and a 16' for about $80 - shipped last fall.
I use the 12 foot instead of a fly with my tent and as an add-on for my old VV hammocks. The Kelty poles (4 section) only cost $29.95 a set and can be found for less.
The 16 footer was the cook tent for the Laurel Fork Spring Frolic.
Mike -
Old 05-16-2012, 01:13 PM   #1179
weird1
Oddometer: 70
Here is a couple of pics on my current trip.
weird1 is offline   Reply With Quote
Old 05-16-2012, 01:20 PM   #1180
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 18,191
Cool setup wierd1, but what is the slab of wood you are carrying with you on top of the rubbermaid?
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake is offline   Reply With Quote
Old 05-16-2012, 03:09 PM   #1181
weird1
Oddometer: 70
it is just a pice of firewood I didn't use the night before, if I still have it I will burn it in TX next week. lol
Old 05-16-2012, 07:16 PM   #1182
docwells7
docwells7's Avatar
Oddometer: 7,024
That set-up is freakin' awesome!
IBA#25276
Airhead#9654
Old 05-16-2012, 07:46 PM   #1183
HoloHolo
2 wheels !!!!
HoloHolo's Avatar
Oddometer: 268
Has anyone used a hammock on the twat?
Sent from my iPad using Tapatalk HD
HoloHolo is offline   Reply With Quote
Old 05-16-2012, 08:53 PM   #1184
Rev Kiecker
Rev Kiecker's Avatar
Oddometer: 729
Near the lake just south of Lake City, CO. Pulled in late and bivy'd instead.
Woke up to this.
IBA #201
INTERNATIONAL TAXI DRIVER REPORTING FOR DUTY.
Rev Kiecker is offline   Reply With Quote
Old 05-17-2012, 11:55 PM   #1185
Pine Sol
Pine Sol's Avatar
Oddometer: 499
last friday afternoon, left detroit headed due west, turned north at the eastern corner of idaho, and headed just into canada. here are a few of my stealth hammocking.
there has been talk of how to tie the hammock to your anchors, and what is simplified, two pics here show my easy tie up, the thicker blue rope is tied to itself, in a big loop, looped through the end of the hammock, and the white rope has a loop on the end, and the other end of the white rope is threaded through the white loop and onto the blue rope, they are not permanently tied to each other, and can be worked loose with my fingers, should i need to, white rope is about 3 meters long. the white rope thickness is important, too thin and working out any knots is next impossible, to thick, and the slip knots wont hold very well, i think it was 5mm, i tried 3mm before but found the rope to elasticity and not strong enough. depending on my anchor, i will either go once around or twice around to help minimize the rope walking down while your in the hammock, and for knots, i prefer a larger diameter rope through the hammock end, run your rope around your anchor and back once through the blue rope, one simple slip knot, pulled snug (the kind that you can pull the single end of the rope, and it pulls the hoop through the knot) and then with the first slip knot, use the hoop to make another slip knot, and pull it snug. and thats it, i have weight tested this way with 400lbs, never ever ever had a problem with these two simple knots, and the next morning when your packing up, to undo the knots, first pull the single hoop to release the first knot, then the single end of the rope, both knots simply pull free. no need any carbiners, or metal loops, or what not, everything is attached to the hammock, nothing to leave behind
(hope my explanation is understandable)
first slip knot
second slip knot
Pine Sol is offline   Reply With Quote
Times are GMT -7.   It's 02:24 PM.
