Old 05-18-2012, 03:42 PM   #1186
Jabba
"HOLD THE LIGHT!!!"
Jabba's Avatar
Oddometer: 12,556
Ropes are not favored in the hammock community- too tough on the tree. could lead to campgrounds frowning on hammock campers....this has been largely overcome thru the adoption of straps. In fact, some state parks began accepting hammock campers
After this distinction was pointed out to them.
What I've settled on is a strap with a sewn loop on the end- biner attached thru this loop. Throw the biner around the tree at the proper height and attach it to the strap- pull it tight. Further down the strap is a set of rings like you'd find on a m/c helmet strap- only larger- this is your adjustment point. The other end is attached to the hammock. Nothing can be left behind- minimum hardware- fully adjustable- kind to the trees.
"Everybody loves cunnilingus!" Chacifer
"The road to paradise is paradise" Jacques Yves Cousteau
Jabba is online now   Reply With Quote
Old 05-19-2012, 01:17 PM   #1187
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,125
So serious question - can ropes really do long term harm to a tree or is just cosmetic?
rickypanecatyl is offline   Reply With Quote
Old 05-19-2012, 02:17 PM   #1188
Jabba
"HOLD THE LIGHT!!!"
Jabba's Avatar
Oddometer: 12,556
A lot of load on that cross section of material- moving. Yeah, there's a sound reason why straps are favored. They also hold a lot better, pack smaller, never any jammed knots to deal with.
Old 05-20-2012, 12:51 AM   #1189
Pine Sol
Pine Sol's Avatar
Oddometer: 499
Ropes are not favored in the hammock community- too tough on the tree..
id like to see where the study has been done to prove that running a rope around a tree for a night or two, is going to cause enough "damage" to be too tough on it. sure, if i tied a tight rope around the tree and left it there, say for several years, it could be dangerous to the tree, but simply running a rope around the trunk isnt going to be a problem,
Pine Sol is offline   Reply With Quote
Old 05-20-2012, 05:22 AM   #1190
MeanMoe
one really mean cat
MeanMoe's Avatar
Oddometer: 2,900
The trees trap argument goes like this: trees feed thru the thin layer just below the bark. A rope consentrates the force from your hammock ( which is multiplied dues to the small contact patch) and it compresses this layer. Some trees have a thick layer but some do not. You risk damage to the tree unless you take measures to spread the force out by using straps.
MeanMoe is offline   Reply With Quote
Old 05-20-2012, 05:53 AM   #1191
Jabba
"HOLD THE LIGHT!!!"
Jabba's Avatar
Oddometer: 12,556
No study to support using something that does a better job in every visible way, but without a study you have determined that ropes are doing no harm?
Brilliant self-serving argument you've concocted for yourself. Rock on!
Old 05-20-2012, 08:03 AM   #1192
Pine Sol
Pine Sol's Avatar
Oddometer: 499
before i wrote my last reply, i asked an expert if i my thinking was wrong or not, sorry to say, my reply wasnt a "self-serving argument"
ok, i assumed that people here were not experts on trees, so i asked an individual who was, if my ropes would damage a tree, and his reply was, "unless i was running a rope around a small (young tree) to which my force would bend it over, or a newly planted tree, to again, i might run the risk of causing to much force before the roots have a chance to take hold, assuming that the rope is around the tree for a short time (ie a few days, to maybe a week or more) then there aside from perhaps a bit of visual damage, there would be no "damage" to the tree" he did go on to say, what would hurt the tree, is if i tied my rope around the trunk and left it there for several years.
my original remarks were based on reading replies about the complexity of how to tie a hammock up, if you dont like what i have to say, thats fine, but to say that my actions are damaging something, based on what a "community thinks", if there is proof that my actions are indeed damaging, then i will apology and step back, but so far, it seems that everything is based on peoples opinion, to which who can be wrong?
Old 05-20-2012, 08:36 AM   #1193
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,603
http://www.backcountryattitude.com/p...pe_damage.html
Why not just use a strap and avoid any possible issues with the tree itself or a park ranger who may not like it?
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 05-20-2012, 09:14 AM   #1194
HighTechCoonass OP
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,493
Laugh
no reason to insult anyone... I apologize for Jabba.
I did go to a camp ground in Maine years ago where they did not let anyone tie roaps to trees (it was around Freeport LL bean area) . so no hammock camping there... I had to find another camp ground.
Out in the boonies... roaps.. I see no big deal. but in a park one could wear it down...
some roap rules are a result of clothes lines blocking the senery... and roaps swings left hign in the trees...IMO...
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 05-20-2012, 09:19 AM   #1195
HighTechCoonass OP
Oddometer: 2,493
Laugh sweet!!! nice setup!!
I like it!!
Originally Posted by Pine Sol View Post
last friday afternoon, left detroit headed due west, turned north at the eastern corner of idaho, and headed just into canada. here are a few of my stealth hammocking.
Old 05-20-2012, 11:46 PM   #1196
Rev Kiecker
Rev Kiecker's Avatar
Oddometer: 729
IBA #201
INTERNATIONAL TAXI DRIVER REPORTING FOR DUTY.
Rev Kiecker is offline   Reply With Quote
Old 05-21-2012, 07:28 AM   #1197
DGraham
Oddometer: 255
If you really want to leave no trace, sell your motorbike.
Joking aside, just how much does it cost to get straps and replace your ropes? It's worth it if for no other reason that to avoid these conversations with fellow campers.
DGraham is offline   Reply With Quote
Old 05-21-2012, 07:32 AM   #1198
astrolump
astrolump's Avatar
Oddometer: 869
some trees have very fragile bark...the pines in the everglades, palms, and birch for example. even the straps scrape off a bit of bark from these trees...ropes imho would do a lot more damage.
i can see no reason not to use straps...no real downside i can think of.
HEY. did you see something fall off my bike? I mean other than me.
"They see me coming on my KLR......They hide their daughters and their PBR......
I'll take the beer,no time for girls......Got a date in the Forest, chasing squirrels. "
astrolump is offline   Reply With Quote
Old 05-21-2012, 08:43 AM   #1199
Jabba
"HOLD THE LIGHT!!!"
Jabba's Avatar
Oddometer: 12,556
"visual damage" = damage. Particularly in the eyes of a campground attendant. Find one manufacturer of camping hammocks who recommends ropes over straps- or one thread on hammockforums.net that endorses the use of ropes around trees? Your method has the potential to make it more difficult for other hammock campers to find hammock friendly camping. Please reconsider.
Old 05-21-2012, 10:00 AM   #1200
triplenickel
triplenickel's Avatar
Oddometer: 2,428
If you damage the bark enough trees will bleed their sap out and die, it's no mystery. Back in the sticks growing up that's how we would get firewood and straight poles for building, peel a ring of bark off and come back to a dead dry standing tree. For you non believers try one in your yard.
07 SE
PG007
Times are GMT -7.   It's 04:03 PM.
