Old 09-26-2012, 08:42 PM   #1351
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,632
Sometimes. I used a ridge line the last time I set up my daughters hammock and it worked real well.
Mike -
"For those who fight for it life has a flavor the protected never know."
USMC 65-68 RVN 66-67
6USMC6 is offline   Reply With Quote
Old 09-29-2012, 05:14 PM   #1352
TomN
TomN's Avatar
Oddometer: 2,503
Anyone ever make an under quilt out of a poncho liner? Seems like it would not be too hard.
2011 DL650
2009 KLX250S
TomN is offline   Reply With Quote
Old 09-29-2012, 07:19 PM   #1353
AlanCT
The Byronic Man
AlanCT's Avatar
Oddometer: 3,508
Originally Posted by TomN View Post
Sorry if these questions have been asked before, did not see answers in the pages I looked at. Never hammock camped before but as I get older I am getting less and less comfortable sleeping on the ground so I want to try hammock camping. Getting tired of waking up 10 times a night when my arm or goes to sleep or hip/shoulder hurts from pressing into the ground.
1) I sleep on my stomach and side, I have read it is possible in a hammock but does anyone really do it? Or is there something about sleeping in a hammock that allows stomach sleepers to sleep on their back?
2) What is the most cost effective way to try out hammock camping, I am looking for something that has a bug net and canopy, is not junk but doesn't break the bank?
3) In cold weather can I put my RidgeRest in the hammock and sleep on it to get insulation? I get cold easy when I sleep. Seems like that might not work since it is a stiffer pad.
I have a Hennessey Hammock. I think it is the Expedition model.
1. I sleep on either side easily in a loose, fetal position. The trick is to hang it with just a bit of slack and to lie diagonally.
2. A Hennessy comes with everything you need. I got mine used here in the Flea Market for a hundred bucks. Try the Hammock Forums for used gear too, but be quick as they get snapped up fast.
3. For insulation I have been using a truck windshield sun reflector. It is cheap and light, and has been warm enough down to the upper 40's so far. Sleeping pads tend to slide out from under you in a hammock, but maybe you could stick it inside your sleeping bag instead of under it?
"You wouldn't be riding a motorcycle if you weren't an optimist."
- Matthew Crawford
2005 Ural Tourist, 2000 Kawasaki W650
IBA #23064
AlanCT is online now   Reply With Quote
Old 09-30-2012, 12:27 PM   #1354
triplenickel
triplenickel's Avatar
Oddometer: 2,428
Thermarest prolite with a silk liner slipped over it for luxury. On cold nights with long johns on use the silk liner as designed as the longies keep you off the pad. My first 100 or so nights in my HH was this way, the last 50 have been with JRB quilts and they both work well but the quilt is better, whether it's $500 better is still up in the air. I liked having the pad along incase I had to go to ground which hasn't happenned yet.
07 SE
PG007
Old 09-30-2012, 09:16 PM   #1355
ravenranger
rave
ravenranger's Avatar
Oddometer: 1,532
I have two Grand Trunk All Terrain Hybrid Shelters (fancy name for a hammock that can also be used as a tent or tarp - got mine on sale for about $30 each) and a 9x9 Noah's Tarp. I hang one hammock under the other with a mylar space blanket in between. I also have a Sleep Cell sleeping bag I picked up from Costco for $40. The Sleep Cell is cool because it has a built in foot vent (it originally had mesh in the vent but I cut out the mesh and can slip the whole bag over my double hammock set up. I've used this set up down to the mid-20's and been quite comfy.
Here's all the different configurations for the All Terrain Hybrid Shelter
(both of my "hammocks" and the mylar space blanket fit inside just one stuff sack)
I also have a Hennessy that I've used with the Sleep Cell bag on the inside but found the "cocoon" set up works better and the Noah's Tarp gives better rain coverage.
BTW, just found this but it looks like Grand Trunk makes a "hammock" sleeping bag that works similar to what I came up with using my cheapo Sleep Cell from Costco!
1989 NX250
2006 ST1300A
2006 Aprilia Caponord
ravenranger screwed with this post 10-01-2012 at 10:26 AM
ravenranger is offline   Reply With Quote
Old 10-01-2012, 09:00 AM   #1356
TomN
TomN's Avatar
Oddometer: 2,503
Ordered a Grand Trunk Ultralight for $20, figured it would be a good cheap way to try it out, can't wait!
2011 DL650
2009 KLX250S
Old 10-01-2012, 11:24 AM   #1357
kitesurfer
kitesurfer's Avatar
Oddometer: 1,633
Originally Posted by Jabba View Post
Tree straps have helped this issue quite a bit- I have not encountered any bans- but it does happen. Be sure you use straps and that if given the chance, educate the host or ranger about the difference this makes to the health of the trees. I believe FL state parks used to ban hammock camping, but lifted that ban after being educated about tree straps.
not in my area of Fla :(
2012 VSTROM ADV 650
US NAVY RETIRED
kitesurfer is offline   Reply With Quote
Old 10-01-2012, 03:29 PM   #1358
astrolump
astrolump's Avatar
Oddometer: 787
So....back in July I finished another run along the TET-s and TET from Florida to Maine. i was about 13 days on the road and in the hammock as i mentioned earlier in this thread.
I just got my camera back so i figured id post some photos and observations about the trip with a hammock and the gear.
the only place i came across an outright ban on hammock camping was in the Connecticut state parks. I was told the state officers would give me a $75 dollar fine with no warning issued. so the three days i was in Ct i camped in a private campground.
PYTHON STRAPS UPDATE. when i bought these things i thought they were great...but then one morning i saw this.....
i think that is enough damage to piss off a ranger...and maybe rightly so.
also they do stretch if they get wet overnight. i may go back to the the hennesy tree huggers of some combination of both...the extra length of the pythons is great though.
all in all the hammock was great....i treated it with permathin and no mossy issues at all. super comfy and i awoke refreshed every morning....always dry no matter how much rain....and comfy in the heat...or cold with my shorty underquilt
my first hammock stealth camp....
mile high campground outside Cherokee
cant wait for the next trip...................
HEY. did you see something fall off my bike? I mean other than me.
"They see me coming on my KLR......They hide their daughters and their PBR......
I'll take the beer,no time for girls......Got a date in the Forest, chasing squirrels. "
astrolump is offline   Reply With Quote
Old 10-01-2012, 03:39 PM   #1359
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,504
That sucks. I see python straps are only 3/4" wide. Wonder if that same level of damage would have happened with 1" straps. 1/4" doesn't seem like a whole lot.
I've been using 1/2" straps on my backyard trees and see a little damage, but I am setting up at least once or twice a weekend on the same spots. Maybe the bark was soggy? Maybe more wraps around the tree would have helped?
Old 10-01-2012, 05:05 PM   #1360
6USMC6
R.I.P. Party Boss
6USMC6's Avatar
Oddometer: 4,632
Certain barks - especially on some fir trees - have a very thick but soft bark that is easily compressed. I have found however, that it usually springs back after a few days **unless you hang a hammock from the same spot for several days**. You must also be careful about moving the strap - like sliding it while under tension, which will tear the bark.
Now, I have a strap question:
I've been using 11 mil climbing rope for the past 25 years or so, only switching to straps two years ago when I bought my Hennessy. Recently (because I had a coupon) I bought an ENO Doublenest along with a set of their Slap Straps for my daughter. The first time I used the straps, I felt that it was much better for setup than the Tree Huggers. I was going to order a set of their Atlas Straps to replace my Tree Huggers but based on the photo above, now I am not so sure.
Are there straps like the Slap Straps or the Atlas Straps (i.e., same principle) that are better/wider/better construction?
Mike -
Old 10-02-2012, 03:48 AM   #1361
K0m4
K0m4's Avatar
Oddometer: 551
There's also http://www.madtree.fi/products.html that looks pretty nifty. Expensive, but I'm considering giving one a try. The weight is really, really low, but I think I'd need it made a bit longer for my stature..
Suzuki DL1000 -07 || Suzuki TL 1000 S -99 || Suzuki GSX 1100 E -82
Introduction/ride report: what's in an adventure?
K0m4 is offline   Reply With Quote
Old 10-02-2012, 09:10 AM   #1362
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,504
That's pretty cool. Like a bridge hammock with no spreaders. Just set the hammock up close enough to the tree and the tree acts like a spreader.
Old 10-02-2012, 10:18 AM   #1363
triplenickel
Oddometer: 2,428
Neat but unless I missed something I don't see a bug net. No net=no go for this part of the world.
07 SE
PG007
Old 10-02-2012, 12:13 PM   #1364
K0m4
K0m4's Avatar
Oddometer: 551
Comes as an optional. Where they're from, the mosquitos are.. well, prevalent, let's say.
Old 10-02-2012, 05:36 PM   #1365
MeanMoe
one really mean cat
MeanMoe's Avatar
Oddometer: 2,906
IIRC, the Kamock Python straps are like the Slap Straps without the stretch. Don't know what the width of the strap is though.
http://www.kammok.com/product-p/11003.htm
What I like, for simplicity, is an OnRope1 Cinch Buckle and Webbing strap with a biner or Dutch Clip. Setup is toss the strap around the tree and clip on the biner, stretch the hammock to the other tree, toss the strap around the tree and clip on the biner then pull the webbing to center and set sag. I've got my HHED setup with 1" buckle and straps. Would like to move to a wider strap to reduce the pressure on the tree as OnRope1 has a 1-3/4" cinch buckle and webbing but Dutch doesn't make a clip that wide. I would think that a biner would constrict a 1-3/4" strap a bit much, unless I could find a rectangular wire gate biner rather than the angled biners that common
MeanMoe screwed with this post 10-02-2012 at 05:50 PM
MeanMoe is offline   Reply With Quote
Times are GMT -7.   It's 04:42 PM.
