Old 12-11-2012, 03:02 PM   #46
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,201
Originally Posted by Katoom119 View Post
Take the "not" out and it makes sense.
It's called heat soak. Basically what is happening is that the heat is transferred from the engine to the radiator fluid, then goes to the radiator to be cooled. Well, the stock rubber hoses don't keep the heat in the hoses but lets it seep out into the engine compartment. So now you're running an engine in an oven, essentially. Because of this the radiator has to work even harder to cool the engine.
Put on the thicker Samco hoses and no heat is allowed to seep through the hoses into the engine compartment; the only place the heat is allowed to dissipate is at the radiator. Since the engine is now not-in-an-oven, it runs cooler, simply because there's not so much damn heat in the compartment. This lets the radiator run more efficiently and actually cool the engine, not the entire engine compartment.
Think of it like this: it's 95* outside and you have every window and door in the house open. A/C is going nuts, right? Can't cool the house no matter how hard you run the A/C unit. Close the doors and windows (I.e., change the hoses) and now you have better insulated the house (engine). So now when the A/C unit (radiator) cools the house, it actually works.
That would make sense to me if the radiator wasn't exhausting its added heat onto the engine and into the area those hoses ostensibly are isolating their heat from.
Whatever-- they look kind of cool.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 05-06-2013, 08:35 AM   #47
APA
Supermoto - Steve
APA's Avatar
Oddometer: 83
FYI .... KTM's come stock with the silicone hose clamps....so no need to purchase them unless they get damaged.
www.MotoHose.com sells the clamps for $1.95 cheaper that what KTM sells them for.
www.MotoHose.com
Dealer inquirys invited.
APA is offline   Reply With Quote
Old 05-06-2013, 11:08 AM   #48
Orangecicle
Quest Adventurer
Orangecicle's Avatar
Oddometer: 2,714
I put on Samco hoses this year. I like them so far. It took some cutting on two of the hoses to make them fit.
Orangecicle is offline   Reply With Quote
Old 05-06-2013, 01:52 PM   #49
ktmadv1
KTMtwins
ktmadv1's Avatar
Oddometer: 7
Just a heads up: Samco will not warranty their hose kits unless you buy their clamp kit when you buy the hoses.
Jen Lukas
www.ktmtwins.com
69 Duboce Ave
San Francisco, CA, 94103
415-968-9467
ktmadv1 is offline   Reply With Quote
Old 05-06-2013, 10:57 PM   #50
kingoftwins
kingoftwins's Avatar
Oddometer: 98
Samco and their Included Clamp Kit
In other words. We had offered a stepless hose clamp kit a while ago and it fit nicely both with installation and with durability. Unfortunately for some reason Samco then announced their hose kits would no longer be warrantied if you didn't use their hose clamp kit. The downfall with their hose kits unlike their top of the line hoses is the clamps are from the automotive side of things and not for motorcycles. This causes certain frustrations with installation because of size limitations and we all know that just like the auto world, motorcycles aren't getting any easier to work on but harder with every new year. They're simply isn't much space to get in there and mount an over-sized automotive hose clamp. We haven't had a single Samco Hose fail in all the years that we have been selling their line of products which shows their build quality with their hoses. KTM is using Samco on all their race efforts. That should tell you something. It's up to you on whether you choose to use their clamp kit that comes with the hoses or purchase the OEM Stepless units from the microfiche section. I hope that helps and clears up some things about Samco.
Ron Nichols
www.ktmtwins.com
69 Duboce Ave
415-968-9467
kingoftwins is offline   Reply With Quote
Old 05-07-2013, 11:55 AM   #51
ABuck99
0.0
ABuck99's Avatar
Oddometer: 598
FYI- Moose Racing private labels the SAMCO hose kits and these come with hose clamps. MSRP on the kit for the 950/990 is 198.00 P/n#1902-0504
http://www.mooseracing.com/products/...oductId=114425
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Times are GMT -7.   It's 09:06 PM.
