Old 06-04-2012, 08:25 PM   #361
ktmklx OP
ktmklx's Avatar
Oddometer: 703
Originally Posted by pjm204 View Post
I may have to add the length to the swingarm as you did, the rear suspension and lock-to-lock steering reduction are the only issues I have with my build(aside from it not being entirely finished). I bottom out the tire on the underseat way too often, pretty much any time I hit the whoops.
I don't think lengthening the swingarm will help much with the stock inner fender. Most of my travel increase came from the inner fender mods.
I wonder if the R1 shock dampening is up to the task?
ktmklx is offline   Reply With Quote
Old 06-05-2012, 04:16 AM   #362
jdrocks
Gravel Runner
Oddometer: 4,586
i thought you had a R1 on there already. the whole deal with the R1 is the spring rate you choose. excellent shock.
get that rat buttoned up, almost time to hit the road.
hey, don't forget to vote.
jdrocks is offline   Reply With Quote
Old 06-05-2012, 08:15 AM   #363
pjm204
Oddometer: 2,019
I don't plan to keep the stock inner fender, I can't imagine it will last too long getting pounded by the rear wheel. I found some Versys parts like 100 miles away, the guy won't ship but I may go buy the peg mounts and tank. If he'll ship the peg mounts, I probably won't go pick up the tank, though an extra gallon would be nice.
I'm currently running a 13 kg/mm spring on my shock, I think it should be fine for my weight (155lbs), though I do bottom it out regularly off road. I probably need to up the preload and dampening a bit.
Current bikes:2006 DL650
Past bikes: 2008 WR250R, XT225, TTR125, '04 CRF50 '74 DT125,'70 TS250,'85 v45, '89 zx600c, '78 GS400x, '99 GS500E, '01 GS500E '05 Z750s, '77 GS400e, '82 GS1100ez, '97 GSX600, '07 VFR800, '03 KLR650, '03 FJR1300, '06 DL1000, '00 KLR650, '99 WR360, '08 DL650, '05 DR650, '08 EX650r, '96 CR500, '82 GS450T, '06 Ural
pjm204 is offline   Reply With Quote
Old 06-05-2012, 09:01 PM   #364
ktmklx OP
ktmklx's Avatar
Oddometer: 703
Yes, there is an R1 shock on the bike with the same spring as you are using. When I stroke the rear suspension in the shop it compresses and rebounds a lot faster that my KTM 200 or the KLR, it seems like it could benefit from heavier oil. But I am an idiot when it comes to suspension tuning. I'll have to get it out on some ATV trails this weekend and try adjusting the settings and see how it works.
Yes voted AGAIN today. Same result as last time, hmm maybe the tax payers of our fine state know what they want. What a waste of money this election was.
Old 06-06-2012, 04:58 AM   #365
jdrocks
Gravel Runner
Oddometer: 4,586
then that R1 should work great, you just need to adjust it. you need to have your touring load on the back, real or simulated, unless you want to make notes on two setups.
yeah, i talked to an old friend in madison over the weekend, he was pretty angry about the $18M taxpayer cost to conduct the recall election.
Old 07-22-2012, 08:53 AM   #366
JAFO
displaced Jeep guy.....
JAFO's Avatar
Oddometer: 3,975
Looks like there's a lot of inspiration to be had for my own build here.. .I have to catch up!
JAFO is online now   Reply With Quote
Old 07-23-2012, 02:25 PM   #367
pjm204
Oddometer: 2,019
http://www.advrider.com/forums/showthread.php?t=805408
Mine is for sale, save yourself some work!
Old 07-23-2012, 06:01 PM   #368
JAFO
JAFO's Avatar
Oddometer: 3,975
Neat bike, PJM, but if I bring another moto home I'm gonna have to sleep with it.....
Old 07-24-2012, 05:41 AM   #369
pjm204
Oddometer: 2,019
So what's the problem?
Old 07-24-2012, 12:41 PM   #370
JAFO
JAFO's Avatar
Oddometer: 3,975
Heh, right? :)
When/if I ever build my shop out back (shortly after I win the lotto), ought not be a problem. Now, not so much...
Sorry to hear you're injured... hope you're healing well.
Old 07-24-2012, 12:44 PM   #371
pjm204
Oddometer: 2,019
Heh, right? :)
Hoping to get my 6 pins and external fixator removed Friday. Then I can start trying to strengthen my wrist a bit. Healing is going well so far. Thanks
Old 07-24-2012, 01:31 PM   #372
JAFO
JAFO's Avatar
Oddometer: 3,975
Heh. "strengthen my wrist"
OVERSHARING! ;P
Old 07-25-2012, 07:35 AM   #373
pjm204
Oddometer: 2,019
OVERSHARING! ;P
Haha not what I meant, but likely a truthful statement. It's like losing your best friend.
Old 07-25-2012, 10:55 AM   #374
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,853
Eek
OVERSHARING! ;P
TMI
Have you been on the girls n bikes thread?
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 07-25-2012, 11:01 AM   #375
pjm204
Oddometer: 2,019
Originally Posted by ben2go View Post
TMI
haha no, that doesn't cut it anymore.
Times are GMT -7.   It's 12:31 AM.
