10-31-2010, 02:59 PM
#181 | |
Oddometer: 4,042
I know I could have used it once or twice myself... a couple deer spooked me a few weeks ago and I instinctively grabbed the brakes and locked them up. ABS would have prevented that. And yea, I think we are going to see ABS (and traction control) on a lot of bikes here in the near future.
My rides... 2009 Yamaha WR250X | 2008 Yamaha WR250R | 2013 Honda CRF250L | 2009 Kawasaki Ninja 250R |
10-31-2010, 04:23 PM
#182 |
Oddometer: 9,700
Dammit, this is about the fifth or sixth thread on Advrider right now which is cluttered up with this silly ABS debate. Take it elsewhere!!!!
- Mark |
10-31-2010, 05:44 PM
#183 | |
Namaste
Oddometer: 1,739
During last fall's cross continental run, my Friend, Bob aboard his WR 250 X pretty much ran away from friend Charlie and I and our wee Ninjas whenever the grades got steep. This probably had as much to do with gearing as anything. When things went downhill or flattened out on the plains, the X bike couldn't keep up .
2013 Ninja 300 ABS, '11 883 Iron ( kicked to 1200), '08 Vespa 250 GTV http://www.secordgallery.com/gallery...2_itemId=35642 |
10-31-2010, 06:00 PM
#184 | |
Target Fixated
Oddometer: 3,871
11-01-2010, 03:50 AM
#185 | |
Oddometer: 1,284
11-01-2010, 11:50 AM
#186 | |
Oddometer: 9,700
If the Honda has any advantage, it will be around town where the extra power isn't needed and the single may require less rowing of the gearbox in traffic. - Mark |
11-01-2010, 11:56 AM
#187 |
Oddometer: 2,276
Disappointed Honda didn't use a V-twin.
I lived overseas for few years in the early 90s and had a couple of these: ![]() Loved it... it was bullet proof and ass-kicking for a 250 and would leave my former BMW R65 in the dust, in any type of comparo, and if I can recall correctly, perhaps even roll-on torque. Have a WRX in the garage right now. It's fun and versatile, can cruise the slab at an honest 75 two-up, but it just doesn't impress me the way the old VTZ250 did. However, I'm sure it largely has to do with owning liter+ bikes since then. ![]() And yeah, wind resistance increases with the square of speed, so the sit-up and beg supermoto riding position really taxes the modest engine at speed.
Lateral G Junkie Fear Deer |
11-01-2010, 12:34 PM
#188 | |
Oddometer: 892
Craig |
11-01-2010, 12:39 PM
#189 |
Oddometer: 697
I'm confused in the comparison of real world preformance (and the power & torque) between the Ninja 250R and the WRX-250R (which is one cylinder from a high-rpm R1). I hope my question is relevant to this thread if the CBR-250R motor is similar to that of the WR.
I believe that the US version of the 2009 Ninja 250R (carbs) has a peak HP of 32 (@ 11,000? rpm) at the crank, and peak torque of 22 Nm (16.2 ft lbs) at 9,500 rpm. (The FI European model has a peak HP of 37.4) My research shows the WR-250R has a peak HP of 30.7 (@ 10,000 rpm) at the crank and a peak torque of 24 Nm (17.7 ft lbs) @ 8,000 rpm. It seems to me that the performance difference uphill and downhill (or on flat ground) must be gearing and not HP / torque. I believe that the WR tops out at about 85-90 mph, and the Ninja at 100-105 mph. With the WR torque peak 1,500 rpm lower in the rev range, it might have a slight advantage going up hill, but if it is a long grade, I would think the only reason the Ninja couldn't keep up would be its top gear ratio. What am I missing? |
11-01-2010, 12:58 PM
#190 | |
full-time dreamer
Oddometer: 873
Bombing for peace is like fucking for virginity. |
11-01-2010, 02:16 PM
#191 | |
Oddometer: 9,700
Going up a steep mountain pass at speed, gearing isn't going to factor as both riders are going to have the engines pinned, in whatever gear is necessary to keep the engine at its power peak. Aero and weight may play some small role, but basically the bike with the most hp is going to get to the top first. - Mark |
11-01-2010, 02:50 PM
#192 | |
Quiet Rider
Oddometer: 26
Real World Performance?
As mentioned by Lateral G in post #187, "wind resistance increases with the square of the speed", thus a bike such as the Ninja 250 which has a very "slippery" shape will go much faster than a bike with the shape of a brick like the WRR given the same max HP and that both bikes are geared for maximum top speed. Thus, given the HP results you state, the speed of 85 mph (GPS) for the WRR and 100 mph (GPS) for the Ninja is exactly what would be expected. As to predicting the winner of a specific acceleration test from X mph to Y mph, there are way too many unspecified variables, e.g. shape of torque curves, spread of gear box ratios, weight of riders, weight of bikes, wind speed, road slope, type of tires and on and on, to be able to make any useful prediction. Somewhere around 60 mph, wind resistance becomes a serious factor governing acceleration. This is why magazines do performance tests and why drag strips and race tracks exist. As to whether the Honda CBR250R engine is sufficiently similar to WR250R engine to draw any useful conclusions, until bore and stroke and valve sizes are published, we are all guessing. All we know now is that both are "250cc" single cylinder water cooled engines with 4 valves. ... Sparky |
11-01-2010, 03:10 PM
#193 | |
Melting in GA
Oddometer: 943
The older engines can get up to about 35rwhp reliably with a good bit of fussing, but I don't know of anyone offering the service anymore since G-Force stopped. 30~31 is realistic with bolt-on crap/for under $1000. Brian |
11-01-2010, 03:15 PM
#194 | |
Oddometer: 9,700
- Mark |
11-01-2010, 04:25 PM
#195 | ||
Oddometer: 2,276
If I recall correctly, these stats are from the same Cycleworld article - biggest difference being weight and top speed: WR250X Ninja 250R
