Old 12-13-2010, 01:04 PM   #31
SpeedStar
XT1200Z and DL650
SpeedStar's Avatar
Oddometer: 528
Another nice video. Now we know why the bike was so dirty in the pics from the Seattle show!
FS: XT1200Z Super Tenere Gas Tank Side Panel Guards, Rear Tank Guards, Fork Tube Guards, Headlight Masks and Exhuast Shield Masks
http://advrider.com/forums/showthread.php?t=714789
FS: V-Strom Frame guards, triple-clamp guards and THE ORIGINAL Headlight Masks
http://www.advrider.com/forums/showthread.php?t=356383
SpeedStar is offline   Reply With Quote
Old 12-23-2010, 10:12 AM   #32
Jeremy L OP
Jeremy L's Avatar
Oddometer: 185
Disable the ABS
We believe the ABS system is dramatically improved over what was previously available to consumers. That said, there’s no question you need to be able to disable ABS. For those who ride off road, disabling your ABS is a serious part of the enjoyment, as well as – I believe – a safety concern in downhill situations.
We evaluated the ABS system, and found a clean plug-and-play solution that provides an on-dash switch to disable it.
It was important to us that you would not need to hack the wiring loom, so we’ve identified OEM-like terminals so this is a true plug-and-play application. We also wanted high-end, truly waterproof switches while keeping them small. What is left to figure out is location and other options to incorporate.
We’ve played around with several different dashboards to mount the toggle switch – tell us what you guys would prefer.
- Switch to the left of dash
- Switch below the dash (preferred location, because it gets the wiring out of the elements and overall cleaner appeal from the back)
Other options we’re thinking of while designing/prototyping, before this goes into production:
- Additional auxiliary cigarette lighter
- Optional mount location for heated grips controller
  • Who is going with the OEM heated grips?
  • Who is considering aftermarket options? (If we get enough interest, we’ll try to make the aftermarket heated grips plug-and-play, as well)
What are your thoughts?
Venture on.
AltRider.com
Jeremy L is offline   Reply With Quote
Old 12-23-2010, 10:52 AM   #33
simmons1
simmons1's Avatar
Oddometer: 1,547
I would be interested in an auxiliary "BMW" type outlet that you can run more power through than the OEM cigarette type outlet.
I will be using the aftermarket grip heaters shown above. I currently use them on 5 other bikes and they work great.
For the ABS somewhere below the dash. Even if it is a little harder to reach. I don't think people will be turning the ABS off and on all the time.
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, GT750, H2 750, H1 500
simmons1 is offline   Reply With Quote
Old 12-23-2010, 01:03 PM   #34
TallRob
TallRob's Avatar
Oddometer: 1,395
Finally got to sit on the Super T at the Long Beach show. At 6'9" it was a tad more comfy than my Tiger 1050 with the tall seat. that is, my legs were more straight and forward positioned. One thing that really bugged me annd most other people were those damn heat grip and brake cables running infront of the instrument cluster. I think it would be smart to see if you could make some sort of harness guide that would keep those cables from blocking your vision of the instruments.
TallRob is offline   Reply With Quote
Old 12-23-2010, 03:01 PM   #35
DuFuS
WEEEEEEEEEEEEEEE!
Oddometer: 3
ABS Switch
I prefer the ABS cut-off out of the way and protected. I will be wiring aftermarket grips with a simple HI/Lo switch. Simple and easy and lasts a long time.
I'm going to hard wire any other devices in, but it would be nice to have an extra electrical socket.
DuFuS is offline   Reply With Quote
Old 12-23-2010, 03:12 PM   #36
whyknotboats
CRANK IT UP!
whyknotboats's Avatar
Oddometer: 510
easy fix
mount the abs switch bypass on top left instead of out in the open on left. No brainer location.
whyknotboats is offline   Reply With Quote
Old 12-23-2010, 04:41 PM   #37
Jeremy L OP
Jeremy L's Avatar
Oddometer: 185
Thanks for the feedback, guys. This is good information, and helps us to provide parts you want.
To give you a little more information about our product line for the Tenere, check out this video. Don does a great job explaining some of our decisions about materials, manufacturing methods, and choosing mount points.
Venture on.
AltRider.com
Old 12-24-2010, 05:59 AM   #38
Mugatu
Sidewalk adventurer
Mugatu's Avatar
Oddometer: 279
Hi, any news regarding the availability date for the skid plate and luggage rack?
And will the skid plate work with the oem crash bars?
Mugatu is offline   Reply With Quote
Old 12-28-2010, 08:50 AM   #39
Jeremy L OP
Jeremy L's Avatar
Oddometer: 185
Mugatu: the luggage rack and skid plate should be ready in the first part of the new year, along with our crash bars. One thing to note: there's been a lot of interest in our crash bars specifically, so they are available for pre-order now.
Other items that can be pre-ordered include our exhaust heat shield and the rear brake master cylinder guard. The side stand foot for the Yamaha Super Tenere is available now (so if ordered before 2 pm it ships the same day).
Concerning the compatibility of our skid plate with the OEM bars: we haven't yet had the opportunity to verify, but will do so when we have access to a bike fitted with OEM bars.
Venture on.
AltRider.com
Old 12-28-2010, 09:06 AM   #40
Mugatu
Sidewalk adventurer
Mugatu's Avatar
Oddometer: 279
Thanks for the reply Jeremy.
I will wait to see how it's going with the oem crash bars / altrider skid plate then.
Old 12-29-2010, 04:20 PM   #41
Jeremy L OP
Jeremy L's Avatar
Oddometer: 185
COMBO -- our luggage rack right now will not accommodate the Yamaha top box. If there's interest, however, we will definitely look at doing that in the future. Are you planning to purchase their top case? What about other Yamaha accessories?
Venture on.
AltRider.com
Old 12-29-2010, 04:23 PM   #42
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Still hoping someone will produce a rear fuel tank like on the Worldcrosser...
ktm950se
ktm950se is offline   Reply With Quote
Old 01-13-2011, 10:41 AM   #43
Jeremy L OP
Jeremy L's Avatar
Oddometer: 185
Thought you might want to know that Pivot Pegz MK3s will be coming, we'll be carrying them, and they're great on the Super Tenere.
If you're thinking about these foot pegs, check out this video our lead designer finished last week.
Venture on.
AltRider.com
Old 01-13-2011, 11:01 AM   #44
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,423
Absolutely not on the fugly heated grips , esp. at that price. that controller couldn't look more after thought, and it's huge!
Definitely aftermarket, but which ones? I've never had aftermarket heated grips. I went straight from suffering for years to OEM once I could afford a bike newer than myself
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain screwed with this post 02-01-2011 at 06:48 PM
levain is offline   Reply With Quote
Old 01-22-2011, 09:35 PM   #45
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 13,743
Jeremy, it was great to meet and talk to you at Dr's party...really good stuff man, cant wait to see your kit hung on my ST...good stories tonight...
Good luck.
Bill (formerly...and soon again known as MoBill)
MoBill is offline   Reply With Quote
Times are GMT -7.   It's 02:42 AM.
