Old 11-25-2010, 11:53 PM   #76
kbasa
Colnago!
kbasa's Avatar
Oddometer: 69,712
crankcase breather, I bet.
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 11-26-2010, 12:17 PM   #77
fadingfastsd OP
fadingfastsd's Avatar
Oddometer: 262
Hey guys, thanks for the input.
I've got the starter cover pulled and I'm checking out the crankcase breather.
It looks fine.
What about it can cause a rattling noise like that?
Just it coming loose? It was completely tight, both screws.
Specifically what do I check on it?
I run RaceTech Electric.
RaceTech Electric: High Power Motorcycle Stators & Voltage Regulators - www.racetechelectric.com
We design, develop, and manufacture high power motorcycle stators, voltage regulators, and other charging system, electrical, and ignition components.
fadingfastsd is offline   Reply With Quote
Old 11-26-2010, 12:50 PM   #78
Jasper ST4
Guest
Oddometer: n/a
I would be tempted to start the bike and observe. But if it's the round style, change it anyway to the newer reed type.
Old 11-26-2010, 01:53 PM   #79
fishkens
Further...
Oddometer: 5,149
It looks fine.
I'm not sure that there's a visual check. They just seem to crap out and start talking.
Or, as Renner suggested, it could be the rear main...
http://bmwmotorcycletech.info/oilingsystem.htm
NOTE that some of these types of noises are often confused with noises in the rear crankshaft SEAL (Turkey gobbler noises, honking noises).
Forging ahead, down a false trail.
fishkens is offline   Reply With Quote
Old 11-26-2010, 02:31 PM   #80
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,291
Get it honking again and mess with the breather while it's squawking, see if you can alter the noise.
I'm guessing it makes the noise once it's thoroughly warmed up. Take another 15min. ride then whip off the starter cover to expose the breather, etc...
Better yet, remove the starter cover and breather housing then run the bike around the neighborhood till the noise returns. Then fiddle with the breather while the bike honks away.
Don't run the bike in the garage without a big fan moving air past the cylinders for more than a few minutes.
The noise may be a sort of bilabial fricative caused by crankcase pressure passing a sort of reed, either a breather disc or a main seal.
Doesn't hurt anything but can be annoying...especially when your buddies begin making comments.
Renner is online now   Reply With Quote
Old 11-26-2010, 04:39 PM   #81
Jasper ST4
Guest
Oddometer: n/a
I guess you could always consider it a matter of pride, like a Ducati dry clutch.
Old 11-26-2010, 04:52 PM   #82
fadingfastsd OP
Oddometer: 262
Man what would I do without my own personal pit crew here to help?
haha
I took the starter cover off again, and the breather cap. Started the bike (it was hot already), and the noise started. I push down on the breather valve disc, and it stops completely. So it is the breather!
Now, how do I fix it and get rid of the noise!? The disc looks fine, no cracks or chips. Do I have to replace it with a new one? Or I read I can cut a new one from a circuit board?
Any way to refurbish this original one so it stops chirping?
THANKS GUYS!
Old 11-26-2010, 05:11 PM   #83
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,291
awesome
best if you can install the upgrade reed valve, part number 11 11 1 335 712
Hans of Hucky's offers it for $35.25. http://www.bmwhucky.com/010011.html
Or fabricate a replacement as you mention.
Maybe use a slightly heavier spring as well?
A better crankcase breather may be considered a performance enhancing modification.
Check out Udo Gietl's upgrade: http://www.omnilex.com/public/bmw78/kotb.pdf
Old 11-26-2010, 05:53 PM   #84
Overdog
'Burghherfer.....
Overdog's Avatar
Oddometer: 242
I replaced the one on my 74 90/6 about a year ago The breathers can be a real bitch to remove (as you may soon find out). I'd just replace it with a new style breather and be done with it for another 36 years or so.
1983 Goldwing Interstate
1974 R90/6
1971 Honda CL 350 (shed queen)
Overdog is offline   Reply With Quote
Old 11-26-2010, 06:09 PM   #85
fadingfastsd OP
Oddometer: 262
Sounds good, I will order a new one soon.
I may try and cut a new one form circuit board material, I have a couple old boards from some power supplies I blew up.
To fix the problem at the moment, I pulled the spring/clip/washers out, and I added 4 small washers on top of the disc. Then reassembled. This increases the springs pressure on the disc, and the disc/valve can still open, but it stops the chirping noise when it vibrates too much.
Seems to work for now.
Old 11-26-2010, 06:19 PM   #86
Overdog
'Burghherfer.....
Overdog's Avatar
Oddometer: 242
When I pulled mine the disk didn't look bad....the spring probably just gets weak. Your "fix" may last quite a while.
1974 R90/6
Old 11-26-2010, 07:29 PM   #87
fishkens
Further...
Oddometer: 5,149
Whew!
Now you can stop worry about your apparent bilabial fricative (WTH? ).
Old 11-26-2010, 08:49 PM   #88
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,291
While in grammar school I'd heard (maybe incorrectly) that it was another word for fart... and it seemed appropriate
Old 11-26-2010, 09:03 PM   #89
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,643
Hijack:
Mine still gobbles. Never got around to fixing it. Am I damaging anything?
crazydrummerdude is offline   Reply With Quote
Old 11-27-2010, 05:50 AM   #90
Renner
rockin' the toaster
Renner's Avatar
Oddometer: 2,291
no, not damaging.
mine gobbled till I got tired of it.
at first it was part of the bike's character, then it became more persistant and annoying.
(I hadn't heard one so enthusiastic as seen in FFSD's video.)
While trying to get my old disc breather out, thinking I could pull it with a skyhook, I had the bike nearly suspended from the rafters
Then I got moderately smart and looked through some archives... found a post on the Airlist by T. Cutter that recommended removing the disc & post and turning a woodscrew in the center bore, then using a prybar in class II lever mode with the fulcrum on a small block of wood placed on the engine case.
Using that set-up it came out in a very satisfying way.
But after installing the reed breather it continued to gobble-gobble-gobble when warm from a long ride so I replaced the main seal and that seems to have cured it.
Times are GMT -7.   It's 05:29 AM.
