Old 05-11-2013, 04:19 PM   #1
4corners14 OP
4corners14's Avatar
Oddometer: 279
First issue with my "08" 990......20K miles
I haven't even started to try and figure this out yet, as I just made it home.... We were on an exploratory trip around all three forks on the Snoqualmie river today and as I was headed to the last leg (South Fork) the 990 started to act like it was running out of gas. Anything past 5,000 rpms it would start to fall on it's face. Pull the clutch in and it revs freely. I only had 90 miles on the tank and no low fuel light yet. It was pretty dusty on the 2 forks we did make, but I can't imagine that the filter was that plugged? If the fuel pump starts to go, would this be a common scenario...where it appears to be fuel starved, but only under load?
Where should I start?
4corners14 is offline   Reply With Quote
Old 05-11-2013, 04:54 PM   #2
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 909
Send a message via Skype™ to ciedema
Fuel filter, not pump is a good starting place.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
No Four Wheel Drives, No Fixers and No Fricken Whingers
ciedema is offline   Reply With Quote
Old 05-11-2013, 05:47 PM   #3
Zuber
Zoob
Zuber's Avatar
Oddometer: 984
Classic symptom of a clogging fuel filter. The RPM's will continue to drop as it gets more and more clogged. If it dies, you can just let it sit for a while and it will run again, for a while. This is not good for the pump.
The fuel filter on the 07-08 bikes was a little small. KTM increased the 'tea bag' pre-filter and the main filter glue was fixed. I've seen these fall apart after they dried out. Get a filter and the two o-rings. Not cheap, bou probably won't need to do it again for 40k miles.
"Son, you can't do both"
Old 05-11-2013, 06:03 PM   #4
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 825
I've got well over a hundred thousand miles on the 990's
and the fuel pumps failing IMHO is a rare occurrence.
Much over hyoed on this forum by those that fail to perform
the routine maintenance on the fuel filters.
Or continually run the fuel so low that the pumps over heat.
They are liquid cooled.
Have you ever changed them?
Do that first.
Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 05-11-2013, 07:27 PM   #5
4corners14 OP
4corners14's Avatar
Oddometer: 279
Thanks Guys! Filters first......
.....hope that's all it is!
Old 05-12-2013, 10:06 PM   #6
dirtdiver
Oddometer: 1,859
My 2008 (at 20K miles)would run fine then every once in a while when I jumped on the throttle it would sag bad. No power, the revs dropped, etc... If I kept real easy on the throttle then no issues.
Then the problem went away.
A month and a thousand miles later the bike was running great. Then all of a sudden it just died. Nothing would bring it back. it left me and Mrs DD high a dry in Mexico. We had to hitch rides/taxi/bus/friends out of Mexico. You have not lived till you have yourself + your 50y/o wife in riding gear and boots and backpacks trooping through Mexico trying to get to the border. Sweating the whole way. I am pretty sure she had never ridden a greyhound bus prior to that.
Until you figure it out I would be always worried about the fuel pump leaving you with no recourse but to walk.
DD
04 CRF230F
06 CRF250x
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
dirtdiver is offline   Reply With Quote
Old 05-13-2013, 05:35 AM   #7
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,150
So what caused it?
2011 White 990 Adv R
2003 565exc
FakeName is offline   Reply With Quote
Old 05-13-2013, 07:53 AM   #8
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,101
Long distance travelers
DD
How about a backup fuel pump?
http://advrider.com/forums/showthread.php?t=850343
and fresh fuel filters every now and then?
http://advrider.com/forums/showthread.php?t=874262
Cheers
There is always a reason!!
Old 05-13-2013, 11:13 AM   #9
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,144
Here is a thread to give a good view of what your going to have to do to change out the filters.
Hope it helps
http://advrider.com/forums/showpost....79&postcount=1
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
WWW.DSM8.whereamiriding.com
DSM8 is offline   Reply With Quote
Old 05-13-2013, 11:45 AM   #10
FakeName
FakeName's Avatar
Oddometer: 1,150
Originally Posted by DSM8 View Post
Hope it helps
It does, and thank you.
2003 565exc
Old 05-13-2013, 12:42 PM   #11
990west
Oddometer: 8
the stock filter and o-ring package prices from KTM will make your eyes water. I am waiting on parts right now for my 2011. Only 2000 miles so I can only think I got one hell of a dirty load of fuel on the last fill up. Symptoms exactly like yours. First time I have needed to get a tow truck home on any bike I have owned so I guess I have been lucky.
990west is offline   Reply With Quote
Old 05-13-2013, 01:09 PM   #12
DSM8
DSM8's Avatar
Oddometer: 3,144
Check out the link from Gefr he has sourced an economical replacement to the stock stuff worth checking out.
Old 05-13-2013, 10:59 PM   #13
990west
Oddometer: 8
I have one on order with Gefr as well. Unfortunately I had it ordered from the dealer before discovering him but at least I will have a spare.
Old 05-15-2013, 09:25 PM   #14
dirtdiver
Oddometer: 1,859
Originally Posted by FakeName View Post
So what caused it?
The filter looked OK. It was the fuel pump.
DD
04 CRF230F
06 CRF250x
09 KTM 530 EXC
Old 05-15-2013, 09:33 PM   #15
dirtdiver
Oddometer: 1,859
I have heard that heat can kill the fuel pump. Some say that if you like to run your tanks low then the pump will not get the cooling it needs and it will have a shorter life.
So, in my case the fuel pump did fail. I like to run my tanks down to near when the light comes on +- 10 miles. The particular trip it actually failed I had just run my tanks down to the fuel light plus another 10 miles. I filled up and then about 5 miles later the pump stopped pumping. It was also a hot ride that day in Baja with high speed (80-90 mph) highway run of about 150 miles before it died.
I dont do anything different now but I can tell you it was a PITA, breaking down south of the border with no other people (with us) and my wife on the back. She is a good sport but it added to the anxiety of the whole situation.
DD
04 CRF230F
06 CRF250x
09 KTM 530 EXC
Times are GMT -7.   It's 11:06 AM.
