Old 03-25-2012, 07:27 PM   #1531
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,161
Originally Posted by MotorOlly View Post
If struggling with economy 40mpg is easy with the map I posted earlier. 55 is my target, that would give me 500miles per fill up, cool :) my datalogger is showing 10-11:1 AFR everywhere so I think its possible. Believe it or not a stck Akro map barely makes 10:1 shocking! 8(
Hi MotorOlly,
I must have missed it. Would you care pointing where the map you mentioned is located? Thank you.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 03-26-2012, 06:27 AM   #1532
MotorOlly
Sand basher
MotorOlly's Avatar
Oddometer: 32
Hey Bikyto, yeah sure its at the top of this page. Done 15000 miles or so on this map so far.
http://www.advrider.com/forums/showt...orolly&page=88
Would love to get a look at the map from the guy who said he had 50mpg :)
Olly
MotorOlly is offline   Reply With Quote
Old 03-26-2012, 09:25 AM   #1533
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Yeah, I'd like to see that too. If it ever quits snowing here I have some plans to start messing with this again; I've been so pleased with the running charactersitics of the power-tripp map I'm running now I knida let it go last year.
It's sure fun to play with, and so much easier than carbs!
S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 03-26-2012, 10:00 AM   #1534
bikyto
bikyto's Avatar
Oddometer: 2,161
Olly
Thanks, I get about 42mpg out of mine. I'm curious to compare them. Thanks again for sharing. Did you get to lean it out more?
S
It's a map for a 07-08. Wasn't the power-Tripp map for an 09? I did you have a custom map made by him?
Old 03-26-2012, 11:30 AM   #1535
Alleycatdad
Oddometer: 1,439
To clarify....
I ride a 2010 and am currently running one of the power-tripp maps; I don't remember which one I ended up with and this is the wrong computer for figuring it out.
I know the mythical "50 mpg map" is for an earlier bike but I'd still like to see it....At some point if I ever get some time I want to sit down for a weekend with the two big monitors on my photoshop machine and do some pre- and post-09 map comparisions, just for grins. If we could establish some consistent differences, maybe we could come up with a set of "correction factors" to run the later maps on the earlier bikes using cut and paste.
It's probably silly and a waste of time, but this is fascinating stuff and I think it might be a worthwhile exercise.
Steve
Old 03-26-2012, 11:44 AM   #1536
bikyto
bikyto's Avatar
Oddometer: 2,161
Yes you could copy and paste the F/L maps. That would keep the maps functioning. Ignition is different of course.
In terms of on/off and hunting, the mods that made the most of a difference was the 2nd butterflies. That map can be tweaked a lot.
Ya, I'd like to see the f1/f2 and l1/l2 maps on the 50mpg map.
Can we see it ;) J. Are you listening :)
Old 03-26-2012, 02:03 PM   #1537
the foolish fellow
UP FOR IT
the foolish fellow's Avatar
Oddometer: 140
Sorted ( I think )
Today I pasted in the fueling from an 09 map into the standard 07 and loaded it up done the 15min idle and bob's you uncle, running smooth and no hesitating. I'll continue to monitor the transformation but it looks like i'm ready for a run off road again.
990 adv
850 Le mans
Gl 1000
X5 3.0d
FE 450 BERG
the foolish fellow is offline   Reply With Quote
Old 03-26-2012, 02:07 PM   #1538
Masa
Masa's Avatar
Oddometer: 297
Anyone tried '12 tunes on older bikes, '11, '10..? Any difference, apart a bit more hp?
Masa is offline   Reply With Quote
Old 03-26-2012, 02:29 PM   #1539
Dusty
Dusty's Avatar
Oddometer: 1,272
To clarify....
Steve
Not silly at all...
When i did some comparisons this winter what i saw was that the biggest change was the ignition timing. The stock timing looks to retard at the lower mid range. If you have that table up in TuneECU just hit F5 and it toggles to the graph. Also use F6 to toggles between maps.
I compared the fuel tables to my stock 07 and the Arko and the 50-50 Arko and saw that the fuel values on Tripps maps were less than the 50-50 in most areas. I am going from what i remember which can be dangerous, i need to look this over again also.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 03-26-2012, 02:34 PM   #1540
Dusty
Dusty's Avatar
Oddometer: 1,272
Originally Posted by Joe View Post
Was having a hard time with the USB driver until I found this. Thanks for posting
Glad someone found it helpful.
Old 03-28-2012, 10:08 AM   #1541
Tom-Hamburg
Tom-Hamburg's Avatar
Oddometer: 84
03-28-2012 TuneECU 2.2 now Released
Get latest Revision here - TuneECU Links Page
New Features:
* Updated for new maps KTM 690 2012 and Triumph (except Tiger Explorer)
BR, Tom
TuneECU
Triumph Speed Triple 1050
Triumph Rocket Roadster
Tom-Hamburg is offline   Reply With Quote
Old 03-28-2012, 10:15 AM   #1542
ok64
Oddometer: 142
50 mpg ?? Does that map also limit speed to 10 mph
Check out www.ADVSPOT.com, my site with lots of links to Adventure products and information. (I don't sell anything) Send me a PM if you have a link you want to add.
ok64 is offline   Reply With Quote
Old 03-28-2012, 10:30 AM   #1543
ok64
Oddometer: 142
Just tried version 2.2 on the new Windows 8 preview. When I download IE warns me that this is not a commonly downloaded file but gives me the option to download anyway. After doing just that, the app starts without any problems on Windows 8.
Old 03-31-2012, 08:55 AM   #1544
MrLebowski
MrLebowski's Avatar
Oddometer: 158
Are you guys referring to me? I posted last fall (like 7 months ago!) that I touched 50mpg. Had more to do with speed than fueling though.
MrLebowski is offline   Reply With Quote
Old 03-31-2012, 12:29 PM   #1545
bikyto
bikyto's Avatar
Oddometer: 2,161
I was referring to another tuner who does get 50+ on an everyday basis as i understand it. Maybe we'll get to see his map
Times are GMT -7.   It's 01:01 AM.
