Old 08-08-2012, 07:48 AM   #1696
mato409
Oddometer: 45
what wold be the best F L swich , i have copy and past 2011 map on my 2008 and i have this,
rpm 1000 1300 1450 2000 2400 3500 4000 10000
pos 12 12 12 16 18 24 25 35
i was running beafor a diferent set up
pos 10 10 10 10 12 18 10 10
i read tahoeacr and say "Change your F-L switch to 1800rpm. 0 above that"
So it woud by like this?
pos 10 10 10 10 0 0 0 0
mato409 is offline   Reply With Quote
Old 08-08-2012, 04:28 PM   #1697
MrMike
No self control
MrMike's Avatar
Oddometer: 796
Suggestions
I've just got this 11 Dakar model a few weeks ago and it has been a bitch to ride. I tried to adjust the cables and suspension (to make it softer because I thought I was just moving the throttle when I hit a bump). I did the G2 400. But nothing helped so I thought I'd see if I could get this tuning thing working. I know these bikes can run pretty good as I had an '07 which I got to run pretty good with G2, FMF pipes and Akra tune. So I actually got the cable and a Christmas miracle happened.... I got it to show the Vin number after a bit of fiddling with the computer. I missed the step to read the tune so I had a hard time getting that screen populated. But fumbled around and found that. OK enough small talk. I found that the previous owner and/or his shop had put in the 11 R AKra map. It has stock pipes and no mods. It's all stock. So should I load the regular '11 R map or the regular '11 standard map (that's assuming I can figure out how to load maps)? I've read here that the R map is only different at the very top end so is that what everyone is looking to install? I don't want to do the other tuning stuff (F L and such) before I get the correct tune in it so I only change one thing at a time. So what say you all? Standard or R.
'09 KTM 530 EXC
'10 BMW R1200GS
'06 Bmw HP2 Enduro
'06 Ktm 950 SM
MrMike is offline   Reply With Quote
Old 08-08-2012, 05:08 PM   #1698
Rsquared
Echo
Rsquared's Avatar
Oddometer: 113
I'd use the R. KM601US1102002Map
Kronreif Trunkenpolz Mattighofen
Rsquared is offline   Reply With Quote
Old 08-09-2012, 04:56 AM   #1699
mattc
mattc's Avatar
Oddometer: 451
Go for the R map, the Dakar should have the same map as the R from what I've read.
The F L tables is where you will make the bike run smoother. It was without a doubt the most noticeable change I have made yet.
The throttle is twitchy on these bikes, not sure if there is a fix for it, to make it feel like it's Carb'ed but I have made mine a lot better playing with TuneECU
Now, if someone would just share a map for the CPR filter, I'd Be Set!!
mattc is online now   Reply With Quote
Old 08-09-2012, 05:10 AM   #1700
olec
Rookie
Oddometer: 273
OK, I promise to read all the pages on the of the first days, BUT, before that:
I know I have the Akra '11 map as a base and tuned from there to fit my bike. The bike has Akra's and modified intake using a CBR style setup. The bike has about 13 more hp's after the tuning. The tuner used TuneBoy and there are mods to SAS and butterflies also. Anyway, the tune / map is in there, and it works awesome. If I understand right, I can buy this cable, install the TuneECU, get connected and download / save it to my computer. Then I am safe for the future, and i can just upload it to the bike again using TuneECU and the needed hardware. So my questions is: it shouldn't matter how the map is installed / tuned in there in in the start as long as I can read it and save it by TuneECU? Don't laugh if it's a VERY stupid question......
If the answer is yes, then I can provide a tune for a 990R + Akra's, SAS removal + secondary BF's + K&N airfilter (which someone told me should be very close to the flow of those CBR filters).
olec is offline   Reply With Quote
Old 08-09-2012, 06:31 AM   #1701
mattc
mattc's Avatar
Oddometer: 451
Olec, I hope someone can answer that, because I'm not sure. I would love to have a map that is closer that what I'm running right now.
Old 08-09-2012, 07:11 AM   #1702
mato409
Oddometer: 45
I copy and paste all the table of a adv 2011 on 2008 base map, but the bike don even start..i have read that sameone actually did this with positive results.. with the F tables only the bikes start perfect.so i guees it would be ignition the problem..
Any ideas?
i have 2008 adv with gpr 2-1 (custom made db killer) stock air filter.
Old 08-10-2012, 07:24 AM   #1703
Junglerot
Hodor!
Junglerot's Avatar
Oddometer: 3,436
I would like to know the answer to this as well
What's the worst that could happen?
Junglerot is offline   Reply With Quote
Old 08-10-2012, 09:36 AM   #1704
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,185
Any ideas?
Yes only copy the F maps. The ignition maps from 2009-10-11-12 don't work on 2007-2008.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 08-10-2012, 09:39 AM   #1705
bikyto
bikyto's Avatar
Oddometer: 2,185
I have mine setup like tahoeacr. It's useful to avoid the open/close loop. Especially if you are testing your af ratio.
Old 08-10-2012, 09:41 AM   #1706
bikyto
bikyto's Avatar
Oddometer: 2,185
Yes if it's in the ecu you can read it with tuneecu, play with it, reupload it and share it if you'd like. After v1.4, tuneecu can no longer read tubeboy maps if it's not in the ecu already. So you're good!
Old 08-10-2012, 06:12 PM   #1707
Gimme 2
wheels , with nobs
Gimme 2's Avatar
Oddometer: 2,110
DUMB question?
is any one here useing an isolated co2 sensor @ the exhaust to measure unburnt fuels, i know the bikes have their own.
Gimme 2 is offline   Reply With Quote
Old 08-10-2012, 08:46 PM   #1708
Junglerot
Hodor!
Junglerot's Avatar
Oddometer: 3,436
As far as I can tell, you can't change the rpm points. So I guess I'm wondering if someone says to set it to zero above 1800, but your two rpm data points are 1450 and 2000, how is that accomplished?
Old 08-10-2012, 10:56 PM   #1709
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Older software allowed you to do that. It had more points. Might have been my Tuneboy stuff. Even the Tuneboy software changed so I was using old software to change some points that wasn't available on the new versions.
Go with 20 up to 2000. Remember that doing this DOES NOT lock out the L1/L2 maps completely.
tahoeacr is offline   Reply With Quote
Old 08-11-2012, 08:59 PM   #1710
Junglerot
Hodor!
Junglerot's Avatar
Oddometer: 3,436
Gotcha. Thanks for the info
Times are GMT -7.   It's 02:29 PM.
