Old 11-26-2010, 11:17 AM   #166
Dusty
Dusty's Avatar
Oddometer: 1,300
On the way.... from brrap at hotmail.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 11-26-2010, 03:50 PM   #167
Tom-Hamburg
Tom-Hamburg's Avatar
Oddometer: 84
Hi,
Post it, I have read it, I find it's good and helpful.
BR, Tom
Originally Posted by Dusty
.....Just wondering if there is a need for me to post this here or start a new thread or just forget it.
TuneECU
Triumph Speed Triple 1050
Triumph Rocket Roadster
Tom-Hamburg is offline   Reply With Quote
Old 11-26-2010, 06:22 PM   #168
Dusty
Dusty's Avatar
Oddometer: 1,300
Originally Posted by Tom-Hamburg
Hi,
BR, Tom
Thanks. Here it is...
I am putting together some screenshots of the TuneECU software install locations and Driver details for those that might have problems with Windows 7 OS.
After looking the tutorial over and over i see that i missed a few screen shots, but i hope i covered enough that most will get it.
I did this just after a new install of the OS. With .net framework 3.5 that came with the software. I did do the security updates for .net 3.5
I was having problems getting things to work on my laptop that had a fairly fresh install of Windows 7 with net framework 4.0
Hope it might help someone.
Cheers...
First get the software and drivers fron the TuneECU site..
I just put them on the desktop for now to be extracted to the directories that you will create.
The next shots are my file locations that i unzipped. This has been working for me.
TuneECU in C:\ program files, you can see location on top address bar.
My driver location. Notice i put my ECUtunes folder, as instructed...
This is what my unzipped Driver folder looks like.
Note from Tom at TuneECU... he suggested to unhook the Internet cable and you don't have to make the changes i did below, to keep Windows from getting drivers from the web.
But this is how I did mine.
After the files are in the proper folders. The first thing i did was find how to shut down windows from going to the web for Device Drivers, so this is how i got there. Note: You can still get device drivers from the web but this stops the windows wizard from doing it.
Open the control panel. Notice i have my folder set to view large icons, i can navigate it better.
Go to the Devices and Printers then open. Next click on the yellow bar that turns blue when you put your mouse over it, at the top of the page that says...Windows can display enhanced icon and information from the Internet. Click to change...click it then choose the option to open device installations and settings, then select that option.
This dialog box shows up. I made these changes and hit save. I did it this way so that i can pick the exact location of the driver with the hope that Windows won't search the web and install something unwanted. Apply the change and hit save.
This is when i plugged my cable in and the dialog box showed that the driver did not install correctly, so i canceled it. Next i went to the control panel and opened the Divice Manager found the new device that i just plugged in, it should have a yellow question mark by it. Then you can expand the Ports(COM & LPT) . If you followed my way of doing the driver update. NOTE: if you followed Tom's way the Drivers should be installed all ready.
Open the control panel. Now you can check to see if the drivers are installed correctly.
Then open the Device manager. Find the ports (COM & LPT) Double click it to open then double click the USB Serial Port to get to the properties. Note: The cable must be plugged in. Now proceed with the driver update from this window if you are following my steps. You can also now see if the Drivers installed correctly. (with Tom's method).
These are the Drivers as of 11-24-2010. Click on Driver details.
And these are the drivers that are installed on my Windows 7 Ultimate after a format and reinstall.
These are the port settings that are recommended. I have used the defaults that install with the USB-FTDI drivers and
these and found both worked, but these settings transfer faster for me.
This next shot is the advanced tab, these are set by the drivers when they are installed.
These are the drivers that should be installed for the USB Serial Converter, open the control panel and expand the usb controllers.
As for the hooking up to the bike and PC, this is what i tried when i first hooked up after the fresh install of Windows.
1.PC fully booted then opened TuneECU unchecked the auto connect button.
2.Plugged the cable into the PC then the bike.
3.Turned the ignition on then hit the connect button in the software.
Easy as riding a bike...
Old 11-26-2010, 09:30 PM   #169
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Hi,
BR, Tom
Great stuff here. Thanks for the effort. Any chance you have this for the new 2009+ Husabergs? They run the Keihin ECU also.
Thanks for all your help.
tahoeacr is offline   Reply With Quote
Old 11-27-2010, 06:19 AM   #170
Tom-Hamburg
Oddometer: 84
Hi,
It's best to ask directly to the programmer (Alain), the contact address you find on our website www.tuneecu.com
BR, Tom
TuneECU
Old 11-27-2010, 07:25 AM   #171
teti
especie en extincion ®
teti's Avatar
Oddometer: 143
help and explanation, in test mode not shows me the temperature and the left are desabilitados panels?
How can you correct the velocimetro 4% error?
the electroventilador as it is called in tuneecu?
Thank you
esto OK ?
Uploaded with ImageShack.us
ayuda y explicacion ,
en modo test no me muestra la temperatura y los paneles de la izquierda estan desabilitados ?
se puede corregir el velocimetro el error del 4% ?
el electroventilador como se denomina en tuneecu ?
gracias
teti screwed with this post 11-27-2010 at 02:57 PM
teti is offline   Reply With Quote
Old 11-27-2010, 03:18 PM   #172
shiskowd
shiskowd's Avatar
Oddometer: 71
Map for 2010 990 Non-R Uploaded
This afternoon I successfully connected TuneECU to my 2010 990 ABS (non-R) and pulled down the map (KM601US0902001Map.hex). I emailed to Tom for posting on the TuneECU sites. Note to non 'R' owners - the diagnostic connector is tucked near the ABS unit - access by removing cover (two screws in the tool storage cavity).
Curiously, the only difference between the 'R' map (KM601US0902002Map.hex) and the non-R map is the position of the 2nd Throttle at the upper right of the map. At 6500 RPM the 2nd throttle starts to back off - I suspect that's where the 8% extra HP shows for the 'R'.
My bike with the stock map works great - experienced none of the fueling issues I've seen discussed on the various forums. Late this fall I installed a set of Leo Vince's and performed the 15 minute idle reset after installation. The bike is even smoother and rev's more readily from low RPM. I'll try the 'R' map when the snow disappears many months from now...
Great tool for self-maintaining a fuel injected ride. Thanks Alain & Tom!
2014 350 EXC-F
2010 990 Adv ABS
2005 XR650R DS For Sale
2005 450 EXC
shiskowd is offline   Reply With Quote
Old 11-27-2010, 04:39 PM   #173
Tom-Hamburg
Oddometer: 84
Hola, teti
Pruebas y ajustes:
En este modo, solo los 3 pequeños indicadores del panel están activos, mostrando el valor del vacío de la admisión (Presión Absoluta del colector) del correspondiente cilindro (solo en la ECU Keihin), proporcionando así los valores de referencia para sincronizar la apertura de las válvulas de mariposa (acelerador).
Todos los otros sensores están deshabilitados.
- (En la columna de abajo a la izquierda) Podemos testear (8) componentes de la moto (excepto KTM), el test tarda aproximadamente 10 segundos.
Por favor, lea el manual
Saludos, Tom
Hi teti,
Tests and Adjustments
in this mode, only 3 small dials of the dashboard are active, providing the value of the vacuum intake (Manifold Absolute Pressure) of the corresponding cylinder (Keihin only), thus providing reference values for synchronising butterfly valve (throttle) opening. All other sensors are disabled.
- (lower left column) Tests (8) certain components of the bike (except KTM), the test takes about 10 seconds.
Please read the manual
BR, Tom
gracias
TuneECU
Tom-Hamburg screwed with this post 11-27-2010 at 04:44 PM
Old 11-27-2010, 04:49 PM   #174
teti
teti's Avatar
Oddometer: 143
Hola, teti
Pruebas y ajustes:
Hi teti,
BR, Tom
If I read the manual but eagerness and desesperacion lei without reading, jaja
I am very grateful to you for providing this and studying and reading in several forums to achieve the best performance of our bikes.
I have many doubts but I don't want to bother with all together and once we will slowly learning.
would be good to create a tutorial with the values of all sensors to check if this all ok
enormously grateful and greetings carefully
teti
si lei el manual pero en el afan y desesperacion lei sin leer, jaja
estoy muy agradecido a ustedes por brindar esto y estudiando y leyendo en varios foros para lograr el mejor rendimiento de nuestras motos.
tengo muchas dudas pero no quiero molestar con todo junto y de una sola vez de a poco iremos aprendiendo.
seria bueno crear un tutorial con los valores de todos los sensores para chequear si esta todo ok
enormemente agradecido y saludos atentamente
teti
Old 11-27-2010, 06:22 PM   #175
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,327
Thanks,... ya it's going to be a a while before i can go for a ride...
I looked at my TPS voltage again today and it was at 7 cold and 6.6 warm, so that is a bit off.
Also looked at the TB's while running and they seemed to be 380 on the front and 370 on the rear cylinder, about 10 points difference at idle. When reved up and held to 3000 rpm they went up to 400 with the rear one now about 7 point higher? Hmm.
Well at least i have a few months to get familiar with the software.
I've noticed the switch between the F and L maps seems all over the place on the different maps, this looks like a place to that needs further investigating and testing.
Also would like to welcome Tom and Alain, and say thank you.
Mine is like 70 off...
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 11-27-2010, 06:33 PM   #176
twodollardoug
the calimesa kid
twodollardoug's Avatar
Oddometer: 337
if your having trouble with disconnections, try plugging your laptop into the wall with your ac adapter. worked like a charm for me. thanks for the tip bikyto
"I don't give it a name, but I always speak with it. I don't know if other riders do the same. This is not only a piece of metal - there is a soul" -Valentino Rossi
twodollardoug is offline   Reply With Quote
Old 11-27-2010, 06:38 PM   #177
Dusty
Dusty's Avatar
Oddometer: 1,300
Thanks...
I also found that having a good charger hooked up to the bike is a good idea, my trickle charger didn't keep up.
Old 11-27-2010, 06:41 PM   #178
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
This applies especially for people using netbooks great idea!
But it might apply to laptops if your laptop is setup in Power Saving Mode once unplugged from your power/adapter. USB ports voltage is throttled based on various factors and triggers disconnections for some people.
Still couldn't find the white phone Mrbubblehead! (inside joke)
bikyto is offline   Reply With Quote
Old 11-27-2010, 06:42 PM   #179
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,327
In device manager windows may be set to manage the power settings of the cable. I can check next time I go in the garage. You can change this setting pretty easily.
Note: At work I am diagnosing a problem with a FTDI USB to Serial cable. I noticed in the above pictures the driver is not the current one released by FTDI. My experience with the older driver is that it has issues going in and coming out of standby in windows. I believe I am using 2.8.2 at work. I have not tested this driver set with TuneECU. I don't plan on testing it either because everything is working great with my current configuration.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns screwed with this post 11-27-2010 at 08:13 PM
Old 11-27-2010, 10:40 PM   #180
CrazyD
Oddometer: 4
How do i program my Immobilizer
I lost my keys from my KTM Supermoto990 R and i just ordered the ignition lock that came with 2 black keys and 1 orange card.
The ktm dealer told me to switch the orange key on and off and that for both keys the same steps, but i still dont get the bike to start. i checked for errors with the TuneECU and i got an error that the pc lost communication with RCU. what is RCU could you please tell me?
And how do i reprogram the immobilizer? i need a special program for it? A sort of diagnostic tool especially for KTM, because the TuneECU can't program the immobilizer
Please help me out, i will appreciate your help ALOT!
Regards,
CrazyD
CrazyD is offline   Reply With Quote
Times are GMT -7.   It's 06:59 AM.
