Old 12-03-2012, 09:19 PM   #1906
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,806
Originally Posted by pdxthmper View Post
Where might I find it?
http://www.tomhamburg.net/KTM_Tune_list.html
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 12-03-2012, 09:46 PM   #1907
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,140
Look in the KTM directory that came with the TuneECU program. It's at the bottom of the list.
"Son, you can't do both"
Old 12-05-2012, 10:35 AM   #1908
stevodadevo
What happened?
stevodadevo's Avatar
Oddometer: 177
Tune Recommendation?
2008 990 Adventure with dual FMF slip-ons and desmogged. Looking for a tune that helps with the throttle snatch issue. Higher MPGs would be nice too.
Can anyone recommend me a tune to load up?
stevodadevo screwed with this post 12-05-2012 at 01:45 PM
stevodadevo is offline   Reply With Quote
Old 12-05-2012, 01:32 PM   #1909
Tom-Hamburg
Tom-Hamburg's Avatar
Oddometer: 84
!! Update December-04-2012, TuneECU 2.4 now Released !!
Note:
Possibility of changing from values in the tables in graphical mode with the mouse.
The description follows with the revision of the online sites between Christmas and New Year.
BR, Tom
TuneECU
Triumph Speed Triple 1050
Triumph Rocket Roadster
Tom-Hamburg is offline   Reply With Quote
Old 12-05-2012, 04:12 PM   #1910
Dusty
Dusty's Avatar
Oddometer: 1,302
Note:
BR, Tom
WOW!!!
Thanks....
Just gave it a test.
Went into the ignition graphic tables (f5) and right clicked a RPM and then hold shift and click throttle position you want and drag the point on the graph to where you want it.... BRILLIANT.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty screwed with this post 12-05-2012 at 04:20 PM
Dusty is offline   Reply With Quote
Old 12-05-2012, 08:41 PM   #1911
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,140
Whoaaa!!! That's great! I've just loaded it up and it works great.
But to state it better - Right Click the RPM, then you only need to Click the throttle position at the top of the chart. Then you can drag in the graphics area to modify the value. You can select or unselect multiple throttle positions at the top of the chart, so you can make changes to several values at the same time.
Another unintended feature of this change - now you can do screen shots of a single RPM curve. It also shows the 'comparison' curve if you load a comparison file. I'll try to create one and post it.
Zuber screwed with this post 12-05-2012 at 09:41 PM
Old 12-05-2012, 10:19 PM   #1912
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,140
More on V2.4 - if you have a Comparison file loaded, when you right click on the RPM, it will now show the values AND the percentage difference between the current file and the compare file. This makes it very easy to compare the changes you are making.
Tom's release notes really under sell the changes that he makes.
Old 12-05-2012, 10:41 PM   #1913
Dusty
Dusty's Avatar
Oddometer: 1,302
Yep you dont need to hold the shift key, just select desired field at the top, 1 or many.
I saw the percentages also... ain't that sweet...
Old 12-09-2012, 10:18 AM   #1914
EOD3MC
What will break next
EOD3MC's Avatar
Oddometer: 4,866
For the guys that are getting near 40 mpg....
How are you measuring distance? (bike's odometer or GPS)
If your using the bike odometer, what is your speedometer set for? 19 or 21 inch wheel size?
When I got my 990 about a year ago, I was getting around 40 mpg using the bike's odometer. Since then I'm tried different maps, replaced the fuel filters and installed and removed O-2 sensor bypasses...but lately I can't seem to get better than 35 mpg.
It suddenly dawned on me that I have "corrected" the speedometer accuracy by changing the wheel size setting to 19.
Current plan is to use the GPS for distance measurements this week when commuting to work to see what my "actual" gas mileage is.
EOD3MC is offline   Reply With Quote
Old 12-09-2012, 06:25 PM   #1915
AZ-Twin
Dusty and Thirsty
AZ-Twin's Avatar
Oddometer: 1,323
Are any of you guys using the OBD II cable that CJ Designs sells to check codes on your car? I'm looking for a good software package to look at the status of the sensors on my car. I'm trying to figure out the specks of that cable, or at least the make/model. I asked on his site, but I figure some of you guys might use the cable on your car too so I thought I would ask.
Rob Swartzwelder, Southern AZ
I'm not real fast, but I do have a dog named Dakar!
97 M900, 07 G650 XChallenge,11 KTM 990 ADV R
2011 North up the CDR
Sierra Vista AZ to Paonia CO and Back through Moab UT
AZ-Twin is offline   Reply With Quote
Old 12-09-2012, 07:29 PM   #1916
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
I'm way past 40 but I'll tell you anyways. With my bike when set on 21 the speedo is accurate and the Odo sucks. When set at 19, the speedo reads fast by 3 or 4 mph. The Odo is off 1/10th per 5 miles with a knobby on front. I use both odo and GPS.
tahoeacr is offline   Reply With Quote
Old 12-09-2012, 10:54 PM   #1917
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,071
Speedo settings
Maybe you got it upside down? When speedo set at 21 it reads faster so to give us a safety margin of 8% odo is accurate? what speedo does is multiply revolutions X circumference - smaller circumference = lower speed
gefr is online now   Reply With Quote
Old 12-10-2012, 08:30 PM   #1918
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,140
TuneECU and Blue Screen of Death
Many times I get the BSOD after using TuneECU. I think it is due to the USB drivers, but I'm not certain. Any tips on on this? I'm guessing it is the order that I disconnect the bike, the usb cable, and shutting down TuneECU. Windows 7, 64 bit OS, HP Laptop with lots of memory.
Old 12-10-2012, 08:38 PM   #1919
Rockwell
Rockwell's Avatar
Oddometer: 669
Maybe try running TuneECU in compatibility mode?
To do this:
1. right-click the TuneECU shortcut or exe file
2. click "Properties" in the right-click menu (bottom)
3. select the "Compatibility" tab
4. check the "Run this program in compatibility mode for:" box
5 ...and try "Windows XP" fromt he drop-down menu.
Try this and let us know. I am also running Window 7 64-bit, but with no problems. I didn't need to run TuneECU in compatibility mode, but it's worth a try.
not all those who wander are lost | two earthlings ride around the world
Home | Photo Blog | The Route | The Bike | About Us | Participate!
Rockwell is offline   Reply With Quote
Old 12-10-2012, 09:55 PM   #1920
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,140
Thanks Rockwell, will give it a try.
Times are GMT -7.   It's 10:46 PM.
