01-18-2013, 11:33 PM
#1951 | |
V-Twin
Oddometer: 260
by the way a tps voltage of 0.68v is quite high, this should be between 0,55-0.65v when the engine is warm (according 2011 ktm smt/smr manual) so optimal setting is 0.6v when the engine is warm
'10 990SMT |
01-19-2013, 04:02 AM
#1952 | |
Oddometer: 409
Yes, the tps voltage is quite high but it's the only setting where the idling works ok. Tried many values, believe me, many values, from 0,45 up to 0,8 , this is the best it could do. On my 950 had it set to 0,6 flat and it ran like a dream. this one is acting like a bitch...
Growing old is mandatory... growing up is optional! ![]() Raid de L'Amitié 2011 RR (link) 690R & 990Adv |
01-19-2013, 04:05 AM
#1953 |
Hmmmm, dirt!
Oddometer: 892
did you ever reset adaptation after readjusting the tps? sound like your doing manual adaptation with the tps instead of calibrating the ecu software to the new setting.
950 Rally custom - 690 Enduro Ride ON! |
01-19-2013, 11:12 AM
#1954 | |
V-Twin
Oddometer: 260
just a long shot, because i know the ecu also uses the map sensors for idle rpm. and i assume the throttle bodies are properly synched. maybe there is a rubber booth between the throttle bodies and cylinder a very little bit leaking or the map sensor connection is a bit clogged (at throttle body). causing this strange behavior??
'10 990SMT |
01-19-2013, 02:54 PM
#1955 | ||
Oddometer: 409
Am i missing some step? Quote:
Yes TB's appear to be synched, relying on tuneecu map info, these are less than 5 units apart from each other.
01-20-2013, 04:34 AM
#1956 | |
Wanderer
Oddometer: 171
Hi there, did you by any chance check the condition of the fuel filters? Had something similar a couple of years ago (and EXACTLY the same now) and it was fixed by new filters. I haven't had the opportunity to install the new filters yet (KTM didn't have any on stock, ordered them in August... finally got them in November - a bit late to mount / test them) but I'm hoping it would fix it again. I've got a TuneEcu cable on it's way anyway. Thanks, Alex |
01-20-2013, 05:29 PM
#1957 |
Oddometer: 286
Values in F1 and F2 tables
Ok so have been comparing differnt maps, stock, arka, custom extra and know I am wonder what the values in the fuel tables actually are, or put another way what are the units for the various tables?
KTM 990 ADV MAKING GROWN MEN ACT LIKE HOOLIGANS XR 650"L" |
01-21-2013, 12:09 AM
#1958 |
Oddometer: 2,170
Milligrams of air. Higher the number the more air the ECU thinks it is getting. The more fuel then the ECU delivers.
01-21-2013, 03:19 AM
#1959 | |
Oddometer: 35
01-21-2013, 03:34 AM
#1960 | |
Oddometer: 409
But when loading back the previous map, did not use the battery charger and when started the engine the idle was fine, so we can assume the battery had good power.
01-21-2013, 06:39 PM
#1961 |
Oddometer: 15
Anyone need a Cable?
I've got a spare TuneECU cable for the 990Adventure. If anyone is interested send me a private message.
David Desolate Wasteland (Houston) ![]()
01-22-2013, 11:59 AM
#1962 |
Zoob
Oddometer: 989
Adjusting the TPS and High Idle
When you adjust the TPS, the idle may be very high or low afterward. You need to turn off the power for 5 sec. or so to let the ECU clear out the previous setting. Then when you re-start it will be normal again.
If you get erratic idling. Look at the TPS sensor quality. Open the throttle and snap it shut, it needs to go back to the same voltage. It should smoothly change voltages when you move the throttle. These will get dirty and need to be replaced.
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
01-22-2013, 04:59 PM
#1963 | |
Oddometer: 409
Doesn't appear to have erratic figures, did that too. Even did the adjust throttle procedure of the 690, power on, rotate gently till full, then back, switch off, always looking at the voltage value and % pointer in tuneecu... One interesting detail is that at full throttle the voltage is 4,07volts instead o 3,91v or so... been told to ignore this, but it seems rather unusual.
01-22-2013, 10:13 PM
#1964 | |
Zoob
Oddometer: 989
When you load a map, TuneECU will perform a Reset Adaptation for you. You don't have to push the button again. You can ignore the high voltage at full throttle, all TPS' are different. So, does it run ok now?
01-25-2013, 09:14 AM
#1965 |
I love sand !!!
Oddometer: 2,575
I've been trying out different maps and settings and improving the feel of my bike. Now i think that i should go to a FI tuner who can tune the bike on a dyno alongwith AFR measurements. My intention is to have smooth power and better mileage. Not looking for peak power, but will be happy if it is a side-effect
![]() oh, and a BIG thanks again to the TuneECU creators, just made a small contribution for their good work and suggest you guys (who still haven't done so) to consider doing the same.
'07 KTM Adv990S No myriad hues of laser lights no bottles that are oozing with nectars from heaven, no beautiful body soft and warm to the touch but, i have a very small desire.. Give me a dark.. long.. winding road, three gears to go and my Hellas on fire.. 950Rally picture thread |
