02-07-2013, 08:32 PM
#1996 |
Oddometer: 21
Okeee Dokee, thanks! Also, I loaded up my first modified map tonight, and the starter wouldn't activate......I went back to the original map, and it fired right up. As I looked things over, I found that on my modified map, I didn't have the "idle speed control" box checked. I went ahead and checked it, then re-downloaded the map. She fired right up, did the 15 minute deal, and I went and rode it around. I went from an early KTM akra map, to a modified Shootis map. I added 25% opening of the secondary butterflies from the bottom RPM, gradually increasing through the RPM and throttle position. I changed the FL switch to "0" at 2000 RPM and over. It's definitely smoother on the bottom end, but I think I lost some mid range power in favor of MPG. I've still got a lot to play with, as it's still herky jerky on the bottom, but it is substantially less than the akra map, and deceleration is less abrupt.
~D
"Never argue with ignorant people. They will just bring you down to their level and beat you with their overwhelming experience." |
02-07-2013, 11:38 PM
#1997 | |
Greek n00b
Oddometer: 24
trickster screwed with this post 02-08-2013 at 03:37 AM |
02-09-2013, 07:12 AM
#1998 |
Oddometer: 21
Thanks my man! I still want to try the akra and stock 07' map from the Tune Ecu site just to see how they run on my bike. I still agree with Tahoeacr in that on deceleration, theres too much fuel, and once you crack open the throttle a bit to add a little air, we get a big combustion leading to the jerking. The problem is, I'm not sure exactly how to modify the fuel to decrease it when I want. Part of me wants to try decreasing the fuel on the L-map under low map (high vacuum), low RPM and low throttle position. I do love how easy and quick it is to make changes with Tune Ecu. It's freaking snowing today, and my wife just had surgery yesterday, so no playing today
02-09-2013, 10:58 AM
#1999 | |
Oddometer: 10
Put the 2011/12 map on my 2010 today
I used the CJ Designs Tune Ecu Cables For KTM Engines with 32-bit Windows 8. The cable was recognized with the correct driver version. No driver download needed. Bike was on center stand and ambient temperature was just above 0C. Here's the order that I did things in for my own reference later on... 01. Set COM3 speed to 921600 and flow control to Xon/Xoff (all other settings left at default) 02. Connected battery tender jr. and waited for solid green light 03. Removed 15AMP headlight fuse 04. Removed seat 05. Removed two screws from where the tool kit sits and removed plastic cover 06. Pulled out wiring bundle and removed from the cap from the connector that looked like it would fit the cable 07. Connected cable to bike and laptop 08. Turned ignition on 09. Started TuneECU and selected ECU > Connect and verified green light in lower-right of TuneECU 10. Selected ECU > Read Map and waited about 3 minutes for map to load from bike 11. Selected File > Save Map File and saved as KM601US0902001Map.hex 12. Selected Diagnostics button and took a screenshot - TPS @ 3% and 0.79V 13. Selected ECU > Download 14. Selected KM601US1102001Map.hex that I had previously downloaded from TuneECU site 15. Accepted warning about destroying the engine and waited about 10 seconds for ECU to receive new map 16. Received confirmation that download was completed 17. Selected ECU > Disconnect 18. Closed TuneECU and disconnected USB cable from laptop 19. Started engine 20. Opened http://timer.onlineclock.net and selected 15 minutes (did this within about 5 seconds of starting engine) 21. Let idle while keeping an eye on temperature (fan cycled on/off starting at about 10 minutes in) 22. Turned ignition off after 15 minutes 23. Connected USB cable to laptop 24. Turned ignition on 25. Started TuneECU and selected ECU > Connect and verified green light in lower-right of TuneECU 26. Selected Diagnostics button and took a screenshot - TPS @ 0% and 0.67V 27. Turned off ignition, disconnected cable from bike, and re-assembled I haven't had a chance to take the bike for a ride yet and probably won't until tomorrow. I thought I had read that the TPS voltage should be 0.66 when cold so I was concerned about the 0.79 reading. Then I saw 0.67 when hot and thought maybe I had hot/cold reversed in my head. I hadn't planned on making any TPS adjustments today. Here are the before and after screenshots: ![]()
02-09-2013, 11:06 AM
#2000 |
So does anyone has this shootis map available? I PM'd him some couple days ago but I havent got reply yet.
02-09-2013, 07:03 PM
#2001 |
Oddometer: 21
I have one, but I've modified it. I am running the Shootis map, but I've opened the secondary butterflies to 25% at idle, gradually increasing them as RPM's and throttle opening increases. I've also changed the FL switch to "0" from 2000 RPM on up as suggested. If you want to try it, PM me and I'll send it to you.
Thanks, ~D
02-10-2013, 12:52 AM
#2002 | |
Husky BRAAAAAAAAP!
Oddometer: 268
What would be a good tune for just a straight through wings exhaust up in yucca valley ca?
02-10-2013, 05:34 PM
#2003 |
Zoob
Oddometer: 984
Which bike?
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
#2004 | |
Husky BRAAAAAAAAP!
Oddometer: 268
02-10-2013, 06:49 PM
#2005 |
Oddometer: 60
ECU help
Is there anyone around the Orlando,FL area can install a map for me on my 07ADV ?
I do have the cable,but no idea how to work with it. Ken Wheeler did a custom map on it now she runs perfect,but my light come on at 100 miles. I know it can be better than that. 26,000 miles on the bike 2to1 Akra pipe sas removed. Thanks in advance. |
02-10-2013, 07:43 PM
#2006 | |
Newer than Noob
Oddometer: 77
At first, after the 15 min idle the ABS light stayed on, and I thought "crap the new map turned off my ABS". So I hopped on and headed out the driveway and gave it some strong back brake. After a nice 3 foot skid the ABS light went out and then returned back to normal (ABS working). ![]() I noticed a stronger pull in first and second, but it has been a few weeks since I have been out, so who knows. It can still lift the front end up in the air with my fat ass on it. ![]() More testing soon. |
02-10-2013, 08:28 PM
#2007 | |
Oddometer: 10
That's the way my ABS light has always worked - and when I say always I mean the last two weeks so take that for what it's worth. The light is solid red for the first 20 feet or so of every ride. Can somebody confirm that my TPS voltage is correct? 0.79V while cold and 0.67V when warm. I'm still not sure that it shouldn't be in the 0.66V neighborhood when cold. |
02-10-2013, 10:36 PM
#2008 |
Life is a trip
Oddometer: 3,101
I believe 0.5 - 0.6V when warm is the correct. Cheers.
There is always a reason!! |
02-11-2013, 01:53 AM
#2009 |
Orange Fever
Oddometer: 1,190
The two bikes I've worked on (mine with 4500km) and another with 30000km had .66 and .67 volts when warm respectively, both run perfectly, not sure I'd bother adjusting it as doesn't seem that critical. I think .65 is the specs upper limit for the fuel injected 990 anyway, so it's pretty close!
Rudall River ride 2011 Kimberley ride 2012 Australasian Safari 2012 Event Report Take risks and live an extraordinary life! |
02-11-2013, 02:53 AM
#2010 | |
Oddometer: 399
runs very nice now, a bit crisp, albeit the different TPS values
Growing old is mandatory... growing up is optional! ![]() Raid de L'Amitié 2011 RR (link) 690R & 990Adv |
