Old 02-27-2013, 10:31 PM   #2041
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,144
Originally Posted by felixblack1 View Post
This time it ran a lot smoother Thanks for the tip Zuber!! Did you only smooth out the peak at 8% throttle or on either side where necessary?
For those keen to give it a go look at the igntion tables in graphic mode and right click on 8% and you will see the peak betwen 2500-4500rpm
I smoothed it between 6%-15% (about). Like I said, look at this example:
Compare the ign maps between the stock 09-10 Adv and PowerTrippsWings maps. You can't directly copy it over to the 07-08 ADV, but use it as an example.
"Son, you can't do both"
Old 02-28-2013, 06:42 AM   #2042
two trackin fool
two trackin fool's Avatar
Oddometer: 1,311
OK so it is possible to get the wick so its not so sensitive (jerky) without hurting performance ?
I am very happy with with my '10 so far only 1500 miles but the dam throttle is just to touchy !
Stay Patient and Trust your Journey
'10 990 in White
two trackin fool is offline   Reply With Quote
Old 02-28-2013, 09:51 AM   #2043
pdxthmper
pdxthmper's Avatar
Oddometer: 420
I see the spike your are talking about in both the Ix and Ix LOF maps, are you adjusting both or just Ix?
(Ix = I1 or I2)
KTM 990 ADV MAKING GROWN MEN ACT LIKE HOOLIGANS
XR 650"L"
pdxthmper is online now   Reply With Quote
Old 02-28-2013, 09:53 AM   #2044
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Originally Posted by tilting40s View Post
I was wondering if running the bike less lean would be a solution to cool the temp or if this is completely normal operation for the bike. I've done some poking around and seems that people have operating temps all over the board.
You can add some fuel to cool it some if you want. Add to F maps but it can possibly throw off your smooth throttle depending on the tune. Just keep your current map so you can put it back in. The fourth bar on the temp scale is 158-212F. Fan kicks on at 216F. Mine seems to kick on about 30 seconds before the fifth bar shows up. Operating temps are all close. The newer 990's have more bars on the gauge than our older ones.
tahoeacr is offline   Reply With Quote
Old 02-28-2013, 10:28 AM   #2045
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Originally Posted by Duhfactor View Post
O.K. my friend, I know you have experience with this, help a brother out? Help me understand.....
L maps work off of manifold pressure(more active with quick throttle movement and low TPS). F maps are TPS(active with steady state throttle). The switchover point is NOT set in stone with the F-L map. You can take the FL point down to 1800rpm yet the L map will still be active when you hit it hard like an accel pump. If you lean the L maps your acceleration inreachment will suffer. When tuning on a dyno you hold a load on an engine at steady throttle. So, say your loading the engine at 20%TPS and 3,500RPM. You add fuel until you reach peak hp. At that point that is all the fuel the engine needs. Now lets say you cruising down the road at 20%TPS and 3,500rpm. You know your bike is at max hp with the map you just did. You nail the throttle to do a wheelie past all the BMW's sitting at the Starbucks. The engines load suddenly changes as the throttles open. Can't think of the term but what happens is the new fuel charge tends to stick on the walls of the intake manifold and in the cylinder for a split millisecond. As this happens you can see where the A/F ratio will go lean. This is why the L maps take over and add more fuel to account for the loses until things catch up.
Old 03-02-2013, 09:23 AM   #2046
Tom-Hamburg
Tom-Hamburg's Avatar
Oddometer: 84
Update March-02-2013, TuneECU v. 2.5 now Released
Note:
* Ability to copy tables from compared map to the current map.
BR, Tom
TuneECU
Triumph Speed Triple 1050
Triumph Rocket Roadster
Tom-Hamburg is offline   Reply With Quote
Old 03-02-2013, 10:29 AM   #2047
Dusty
Dusty's Avatar
Oddometer: 1,302
Way cool Tom...
Thanks again...
tahoeacr, thanks for the intel.
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is online now   Reply With Quote
Old 03-02-2013, 10:49 AM   #2048
Pistolero
W. F. O.
Pistolero's Avatar
Oddometer: 709
Note:
BR, Tom
Pistolero is offline   Reply With Quote
Old 03-02-2013, 12:54 PM   #2049
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 957
Note:
BR, Tom
awesome job Tom!
690R
Old 03-03-2013, 10:27 PM   #2050
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,602
Note:
BR, Tom
Has anyone else tried the and successfully performed the "copy/paste" from compared to current map? Perhaps I am missing something, but the "paste" function is greyed out when I "F6" flip between the two tables, in effect making it not work?
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-03-2013, 10:29 PM   #2051
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,602
OK, so I am a ID10T.... figured it out
Old 03-09-2013, 12:25 PM   #2052
Tom-Hamburg
Oddometer: 84
Update March-09-2013, TuneECU v. 2.5.1 now Released
Note:
* Minor bugs in vers. 2.5 fixed.
BR, Tom
TuneECU
Old 03-09-2013, 10:29 PM   #2053
chrish4ku
chrish4ku's Avatar
Oddometer: 868
Nice one - like the copy function! Sweet.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 03-14-2013, 06:42 PM   #2054
Gustavo.Ramos
Oddometer: 957
When testing the ignition coils, do you hear clearly both clicking or is it a silent test?
690R
Old 03-14-2013, 08:59 PM   #2055
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,144
I fires the coils, just like when running. Pull the plugs, connect and lay on the heads. You should see sparks.
Times are GMT -7.   It's 12:35 PM.
