Old 12-09-2010, 06:27 PM   #211
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,323
Reset TPS (Keihin)
After downloading (Fig. 12), a reset of the TPS is required.
Turn off the ignition, wait ten seconds and turn ignition back on.
With connection re-established with TuneECU proceed :-
ECU Reset TPS
Then start the engine and let idle until the “TPS” status indicator (in the status bar) changes to green (after 10 to 15 minutes).
- KTM
After downloading, start the engine and let running it idle (without touching accelerator) for 15 minutes,
then turn it off.
Thats the comments on the TuneECU page.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 12-09-2010, 06:28 PM   #212
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,323
I need to read a bit, but I thought a full download would require this, but if you were just updating portions of the map it may not be required?
Comments? I did read the last posts too and I am still thinking about it. I have been doing a full 15 min idle.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 12-09-2010, 06:28 PM   #213
blue
blue's Avatar
Oddometer: 152
VeeTwo Dyno
Firstly thanks to Ken, I received my ecu plug.
Thanks also to the guys at TuneEcu for taking the time to find a fix for the lack of tuneability of the LC8 engine, much appreciated.
I've got a 2010 990R Adv with wings exhausts no inserts. Here in western australia there is a group called veetwo motorcycles who tune, modify and remanufacture performance ducatis. They're are considered gurus in tuning high performance V Twins and have access to a dyno. I've got my bike booked in with them in jan and will get them to use the the TuneECU software to try and get a high end map for the above mentioned config. Will upload the results then. Should be interesting :)
Cheers
Matt
blue is offline   Reply With Quote
Old 12-09-2010, 06:49 PM   #214
twodollardoug
the calimesa kid
twodollardoug's Avatar
Oddometer: 337
Cheers
Matt
cool, im curios to see what they set the f-l switch to.
"I don't give it a name, but I always speak with it. I don't know if other riders do the same. This is not only a piece of metal - there is a soul" -Valentino Rossi
twodollardoug is offline   Reply With Quote
Old 12-10-2010, 02:10 AM   #215
924sas
924sas's Avatar
Oddometer: 205
thx to jeff as he explained it nearly the same way as i heard it in mattighofen (where my source comes from) and btw my english is tuned by google.
in my simple words: 15min run = adapting to the current conditions while at work
i'm still not sure if that is the same as a reset via tuneboy as there is no adapting more a reset to start from square one. or am i thinking in the wrong direction
however, i just want to thank everyone sharing the info here!
924sas is offline   Reply With Quote
Old 12-10-2010, 12:25 PM   #216
Tom-Hamburg
Tom-Hamburg's Avatar
Oddometer: 84
12-10-10 TuneECUv1.7.9b now released
* Incorrect position of the TPS (real time) in the F tables, corrected.
BR, Tom
TuneECU
Triumph Speed Triple 1050
Triumph Rocket Roadster
Tom-Hamburg screwed with this post 12-10-2010 at 02:00 PM
Tom-Hamburg is offline   Reply With Quote
Old 12-10-2010, 04:07 PM   #217
chrish4ku
chrish4ku's Avatar
Oddometer: 793
BR, Tom
Shall we ask for the Android 2.2 Version of TuneECU? We could change maps on the fly during a long trip...;)
Wishful thinking
Thanks again. Got my cable and am ready to learn.
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 12-10-2010, 09:45 PM   #218
motorcycledave1000
Speed Thrills
motorcycledave1000's Avatar
Oddometer: 82
Got my cable, Thanks Ken
Some initial observations:
Looking at the stock tunes: Am I to understand the rev limit for the 09-10 Non-R and R models is 9400rpm and everybody else is set to 9600???
On the 07-08 stock tune the L1/L2's around the 3000 rpm/small throttle openings seems excessively low compared to everyone else's. Could this be in part the problem with the herky jerky throttle we all seem to suffer?
Finally how do you copy and paste the values in the tables, my Vista machine doesn't seem to want to copy any numbers in the charts?
-Soup-r Dave
2008 KTM990 Adventure
2002 Suzuki GSX-R1000
2002 Yamaha WR-426
1983 Honda V45 Interceptor
motorcycledave1000 is offline   Reply With Quote
Old 12-12-2010, 03:03 AM   #219
Tom-Hamburg
Oddometer: 84
Originally Posted by motorcycledave1000 View Post
....Finally how do you copy and paste the values in the tables, my Vista machine doesn't seem to want to copy any numbers in the charts?
Hi,
Individual areas or values of a table can not be copied, only whole tables can be copied but only when the tables are the same type.
All other changes must be made individually by hand. Either directly in the F-tables or on the trim tables.
BR, Tom
TuneECU
Old 12-12-2010, 03:28 PM   #220
chrish4ku
chrish4ku's Avatar
Oddometer: 793
Tested: Standard vs Akro Maps 2008 990
First of all, TuneECU is fantastic!
On my 08 A I have ridden with both the standard map and the open map (U.S.) Approx 400 miles on the open map, and 2,000 miles on the standard.
1. The Open (Akro) map totally eliminates herky jerky, and the 4,000 RPM hesitation. Bike runs like a dream. Issue: Mileage 28-31 tops. Fuel light comes on at about 125 total miles.
2. Standard Map: Bike runs well, but still a bit of hesitation at 4,000 RPM. Gas mileage is 37-40 ish. Some decel popping, but very mild.
I have Remus Titanium cans with inserts installed.
My big question to the FI experts - is there an "in between" map that has been adjusted between the 4-5K RPM range. I can see there is quite a difference in levels when doing the "overlay" function on TuneECU. (Akro vs. Standard).
My unprofessional observation is that more fuel = better performance. But I just don't know how much is enough.
My bet is that somebody has the "perfect" custom map out there for the 07-80 models.
Feel free to PM me if there are any suggestions or some sort of compromise.
Chris
Chris' Sat Tracker
Old 12-12-2010, 06:32 PM   #221
motorcycledave1000
Speed Thrills
Oddometer: 82
Hi,
BR, Tom
Tom,
Thanks for the info , I was looking at copying the numbers, paste them into Microsoft EXCEL and make some 3 dimensional surface plots, learn some Fuel Injection science.
Maybe for future release, with the "compare table" feature, have a "difference table" feature, another colored coded table, but showing the difference of each value. Just a thought.
-Soup-r Dave
2002 Yamaha WR-426
Old 12-12-2010, 10:54 PM   #222
Tom-Hamburg
Oddometer: 84
Tom,
Hi,
Suggestions about the program can you send directly to Alain, he is the programmer.
The contact address for Alain, is at the top right of the TuneECU page.
BR, Tom
TuneECU
Old 12-12-2010, 11:49 PM   #223
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,323
Tom,
You can export tables in comma delimited format. I did it but didn't try to import in excel.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 12-13-2010, 02:46 AM   #224
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Akra map that I tested was 12.0:1 to 12.2:1 Air/Fuel ratio. Way too rich.
Hesitation is lean. Add fuel 3,750 to 4,000rpm. But first you must know at what TPS this is.
Impossible to fix without a wide-band. Mine is 52-56mpg
Too much fuel = wasted $$ and not as crisp throttle response.
"Perfect" map is perfect for one engine.
You guys got the software for next to free(hopefully you donated to there sight), the cable for cheep so now get together and buy a wide-band and share it?
tahoeacr screwed with this post 12-13-2010 at 11:06 AM
tahoeacr is offline   Reply With Quote
Old 12-13-2010, 08:56 AM   #225
aldonc
aldonc's Avatar
Oddometer: 36
How? I don't see an export or Save As function.
thanks,
Aldon
aldon
2007 KTM 990 Adv
2001 Ducati ST2
aldonc is offline   Reply With Quote
Times are GMT -7.   It's 06:07 PM.
