Old 01-26-2011, 09:52 AM   #406
Killer Whale KTM
Life is the adventure!
Killer Whale KTM's Avatar
Oddometer: 715
Thanks Grinns,
I'll double check the next time I have the tanks off. Although I did check them recently.
Any other ideas guy's ????
Killer Whale KTM
Friend:"That ain't no dirt bike,it's a damn whale!" Me: " It may be a whale, but if it is, it's a KILLER WHALE !! "
Killer Whale KTM is offline   Reply With Quote
Old 01-26-2011, 04:07 PM   #407
Tom-Hamburg
Tom-Hamburg's Avatar
Oddometer: 84
Hi,
I don't, please ask Alain, he is the programmer from TuneECU.
BR, Tom
Originally Posted by cyborg View Post
Hi Tom, any TuneECU plans to support the Aprilia RXV/SXV series EFI bikes?
TuneECU
Triumph Speed Triple 1050
Triumph Rocket Roadster
Tom-Hamburg is offline   Reply With Quote
Old 01-26-2011, 06:50 PM   #408
wakked1
Aspiring Itinerant
wakked1's Avatar
Oddometer: 62
So does anyone know where you could get the cable from in the US? I'm even willing to build one but so far I've wasted lots of time trying to scrounge up the random parts, with no two pieces available from the same site. The hassle outweighs any financial savings.
wakked1 is offline   Reply With Quote
Old 01-26-2011, 09:13 PM   #409
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,396
http://www.cjdesignsllc.com/TuneECU.html
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 01-26-2011, 10:59 PM   #410
wakked1
Aspiring Itinerant
wakked1's Avatar
Oddometer: 62
Ah cool, thanks!
Old 01-27-2011, 04:24 AM   #411
GlobalTech
GlobalTech's Avatar
Oddometer: 74
I noticed on Tuneecu that there's a tick box for SAS enable/disable, is this a permanent change, I'm thinking download existing stock map from ecu, disable SAS and upload and forget about ripping out the SAS for my Wings.
GlobalTech is offline   Reply With Quote
Old 01-27-2011, 09:32 AM   #412
Spark01
V-Twin
Spark01's Avatar
Oddometer: 304
because tuneecu now has the table export feature, i made a copy of the standard 2031 "akra" map of a SM and exported the F1&F2 table.
and the txt file that was generated, placed it in excel.
To see if i see somethong odd.
What i noticed is that i clearly can see a bump(more fuel injected) around 3250-3750rpm and at 5000-5500rpm??
I don't have wideband lambda to confirm it, maybe somebody who has made a custom map with a logger can confirm this?.
But i like the feature
Some explanation: to the right is TPS to the left RPM and in the y-axis is the fuel.
'10 990SMT
Spark01 screwed with this post 01-28-2011 at 08:29 AM
Spark01 is offline   Reply With Quote
Old 01-28-2011, 11:23 AM   #413
GoNOW
Oddometer: 1,588
GoNOW is offline   Reply With Quote
Old 02-01-2011, 01:51 PM   #414
boyscout_steve
Oddometer: 22
Originally Posted by boyscout_steve View Post
Hoping for a bright answer here...
Firstly I have TuneBoy plus an "open" code for diagnostics running on an old WinME laptop together with a TuneBoy USB cable. This setup works perfectly on my old Triumph TT600 but it will not connect to my '07 KTM990Adv - the cable LED flashes but the software never connects.
Secondly, I have a new WinXP SP3 laptop with TuneECU. With the TuneBoy cable this setup never connects to either bike. The cable LED just stays on (not flashing) and the software never connects.
I always run the laptop from the mains and the bike on the battery charger with the headlamp off. I have tried a few baud rates (the TT and Tuneboy like 9600) and both PCs are set to Xon/Xoff. I turn off virus protection and firewalls.
Anyone got any ideas???
(I have emailed Wayne and Alain to see if either have any thoughts for their own software).
(I am so happy that my CCM has a Carb so I don't feel the need to connect to that one!)
Hi Guys, A quick update: Alain suggested that my Tuneboy USB cable was so old that it may not be compatible. I purchased a 8.95 USB/OBDII cable from Ebay and now all is well. (I was probably one of Wayne's original customer base with my 2000 Triumph TT600) The good news is that I can now connect Tuneboy up to the Triumph and TuneECU up to the KTM at the same time!!!
boyscout_steve is offline   Reply With Quote
Old 02-01-2011, 06:18 PM   #415
Killer Whale KTM
Oddometer: 715
Hi Guy's,
Has anyone had any problems with a "not compatable with ecu" message ?
I have the 07-08 Akro map and can't even change it back to original/reg exhaust ?!
Any idea's if I'm doing something wrong !!
Thanks,
Killer Whale KTM
Old 02-01-2011, 06:57 PM   #416
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,177
Originally Posted by Killer Whale KTM View Post
Hi Guy's,
Thanks,
Killer Whale KTM
hum no.
so you take your saved stock map and open it in tuneecu and click on "download". It tells you "not compatible with ecu" and goes no further?
It should give you a pop up that has a warning in it stating that a wrong map might cause engine damage. But you should be able to click "continue" or "next" (I am not telling you to do that since I don't know what you are trying to upload). But that's the process.
Can you break down the steps that you are taking?
bikyto is offline   Reply With Quote
Old 02-01-2011, 07:24 PM   #417
twodollardoug
the calimesa kid
twodollardoug's Avatar
Oddometer: 337
poor killer whale. you a having a hell of a time with this thing arnt you.
"I don't give it a name, but I always speak with it. I don't know if other riders do the same. This is not only a piece of metal - there is a soul" -Valentino Rossi
twodollardoug is offline   Reply With Quote
Old 02-02-2011, 04:49 AM   #418
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,151
i see him struggling with the thing, but what i find remarkable is that he is still not giving up and i think he won't be any time soon.
i want to "make my FI better" but frankly speaking, i don't have the balls (yet) to jump into it, so i keep telling myself that i have learned to ride with the FI as it is and all is fine with the world.....
to me, all you guys are hardcore !!
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 02-02-2011, 07:23 AM   #419
Killer Whale KTM
Oddometer: 715
Hey guys,
Yes I am having a hard time !! But I'm not giving up !!
If I can't fix it by spring time, I'll through it in the lake !!
I have completely removed my throttle bodies. Why is the surface in the intake tracks so rough and kind of dirty or sooty looking ? Is that from back firing ? I'm going to seal the intake boots with silicone or something to ensure that I have no air leaks.I'm also going to replace the MAP sensor hoses and throughly check the intakes and air box for leaks. I doubt this will help though because it all looks good. Should the idle adjustment bolts touch the bracket things when off the bike ?? Mine each have a gap of nearly 1/8 an inch
Can you check the throttle position sensors when they are off the bike ?? As long as the elec. plug is attached ?? How do you know which one to adjust ?
Reading all the various post lead me to believe that there was only 1 !
Could me FMF mufflers lack of back pressure cause problems ?
I'm not sure why all of a sudden I can't load maps. I'm doing the same as before. I might switch back to stock map and reinstall stock mufflers as a test, but can't seem to change to any map ???!
Thanks for your help !
Killer Whale KTM
Old 02-02-2011, 10:28 AM   #420
catalina38
Contrarian
Oddometer: 1,622
I thought the ECU had a limit to how many times different maps could be loaded, 10 or 12? I have to read back through some of the other threads and find it. How many times have you loaded maps on yours?
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Times are GMT -7.   It's 05:58 PM.
