03-02-2011, 09:46 AM
#481 | |
Oddometer: 2,170
03-02-2011, 09:48 AM
#482 | |
Oddometer: 2,170
03-03-2011, 02:39 AM
#483 |
Sand basher
Oddometer: 32
Logs would be great to see thanks
very interested to get to the bottom of this one.I had looked up the part numbers yesterday out of interest and you're right it looks like the 09 ADVs got the cams the SDs had been running for a while. I'll keep my eye out for some SDs then before the tip finally falls of my faulty cam! Ah but its ok 'cause KTM said 'they all do that sir'.....erm.....
03-03-2011, 09:16 AM
#484 |
Contrarian
Oddometer: 1,408
Sine the 2009+ 990's got SD cams and they got new heads and water pumps among other up grades are the heads etc from the SD as well? The rated power went from 98hp on the 07/08 990 to 106hp and 115hp on the 09/10/11 990 and 990R
Born 10,000 years too late Scientific Wild Ass Guesser:hmmmm |
03-03-2011, 08:06 PM
#485 |
Oddometer: 2,170
I doubt it. The SD heads have bigger valves and give more hp up at higher rpm. Not what the average Adventure rider would want. Someone with parts # access could check. As far as I know only the SD got the water jackets changed. Haven't been following the 09,10 adventures though.
03-03-2011, 11:42 PM
#486 | |
SE990R
Oddometer: 1,928
Only the SDR... .
~ Ken |
03-04-2011, 02:58 PM
#487 | |
Oddometer: 2,170
The scale in red on the far left is for the stock Lambda(Blue line on the bottom of the graph). This Lambda was going out and replaced with a Bosch one right after this. You can see at 8:55 it drops off for over 4 seconds at .09 volts. Plus, the Lambda was reading to low/high. It should stay within .2 and .8 volts. Next is the Red TPS. It starts at .70v on the scale which is 0% TPS. Peaks at 1.23v(16%) at about 9:15. Black is RPM Purple is Air Fuel ratio. During the first 30 seconds the bike is at idle. The Purple A/F for the most part averages 14.7. At times the stock Lambda drops down and you can see how this effects the A/F(as the ECU is correcting) and idle speed. Cyborg has one of those lazy guy clutches. It would create a little drag on the engine at idle(IMO) changing the MAP making the ECU constantly try and correct. At 9 minutes 2 seconds the TPS drops while RPM is climbing. Cyborg is probably going downhill or coming up on a traffic jam . Two seconds later TPS and RPM drop rapidly while A/F ratio goes rich . The A/F should at that point go lean. This is a perfect example of what causes the throttle jerk that everyone is trying to get rid of. At about 9:21 you can see the Lambda is working well and the A/F stays at about 14.7 were it should be for MPG. This is flat ground cruising 3-4% throttle at 3,500RPM. He is getting 50+mpg right there if he is in top gear. Hope that helps a bit. |
03-04-2011, 03:25 PM
#488 | |
Muchacho mui loco
Oddometer: 2,298
Thanks for going at that again, TACR... |
03-04-2011, 05:51 PM
#489 |
Oddometer: 2,170
Forgot to add that all of that log is in closed loop.
03-05-2011, 02:47 AM
#490 | |
V-Twin
Oddometer: 260
Is the bike of Cyborg now running closed or open loop?, do you have a screen shot of a open loop run?. I didn't have a change to buy a logger yet, some tax payments got in the way ![]() Because i want to reprogram the ecu to a open loop and i wondering how it affects the afr/lambda: more stable because is not corrected or is it hard too controll to get it close to a prefered value?
'10 990SMT |
03-07-2011, 07:21 PM
#491 | |
Oddometer: 529
Could we have some pictures please? I am having trouble visualizing. Thanks |
03-07-2011, 09:58 PM
#492 |
All Orange :-)
Oddometer: 2,920
Check post #473
03-08-2011, 04:59 AM
#493 |
Oddometer: 529
Probably wasn't clear. I know how to adjust the TPS but not how to balance the TBs. I've poured over the repair manual but I am either thick or its not there. I believe that it involves an adjustment screw on the linkage between the two TBs but I am unsure if it is the front one or rear one.
BTW. I was having connecting issues even after I had made sure all my settings were as suggested in earlier posts. Finally I took my laptop out of power conservation mode and set it for performance and VOILA everything works as it should. No more disconnects
gixxersteph screwed with this post 03-08-2011 at 09:51 AM Reason: typo |
03-08-2011, 08:54 AM
#494 |
Oddometer: 1,021
Cable side on the back, with the yellow paint on it in the pic is what i used. Good tip on the power saver mode...
Originally Posted by d0gWateR Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider! |
03-08-2011, 09:50 AM
#495 |
Oddometer: 529
