05-13-2011, 09:27 PM
#781 | |
Oddometer: 1,020
Originally Posted by d0gWateR Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider! |
05-13-2011, 09:33 PM
#782 | |
Oddometer: 1,020
05-13-2011, 11:47 PM
#783 | |
Potius Sero Quam Numquam
Oddometer: 4,394
http://www.advrider.com/forums/showthread.php?t=328809 how I hooked it up http://www.advrider.com/forums/showp...&postcount=180 I took the Tach right off the ECU and it was a Frequency Modulated signal that the Innovate data cable special Tach input was able to sync on. Worked great. Tach signal looks like this on a scope, cycling the key and the tach going through it's diagnostics sweep on startup. <iframe frameborder="0" scrolling="no" width="425" height="318" src="http://api.smugmug.com/services/embed/726367194_Kuu4u?width=425&height=318"></iframe> |
05-14-2011, 04:54 AM
#784 |
Major Medical
Oddometer: 3,188
Thats dynamite stuff cyborg, thanks
Mike Reinheitsgebot '07 990ADV '08 530EXCR '04 XR650L Bonsai Elephant - "Life without a 990 is no life at all!" |
05-14-2011, 05:25 PM
#785 |
Muchacho mui loco
Oddometer: 2,294
TuneECU quick update for y'all:
Bike: 2010 990A Tune: KM601US0902002.hex for 2010 990R Mods: Football secondary butterflies, 2 into 1 w/Wings NOS can+large baffle, Rekluse and throttle tamer. TuneECU Options: no SAI, no 02 sensors Gearing 16/45 Temp: 74* F Application: 15 min idle trick Very smooth partial throttle openings, smooth from closed to open and very easy to do 1st gear left turn/right turn tight circles. No lean stuttering at steady state throttle in 1st or 2nd gear at 4k rpms. Nice gurgle, no exhaust pops when chopping the throttle on decel. I just got done burping the coolant system AGAIN after some motor fiddling with the clutch basket and my rekluse. The motor was running nice and cool and I think it's partially due to our low temps and the WW I have in the rad. I've tried the latest Akro map I can find and it's not smooth off idle or very small throttle openings, so I backed it off and applied the 2010 990R map that got me 40+ mpg last time I ran it. EDIT: Forgot to add the throttle tamer and Rekluse clutch and the 2 into 1 from CJ and the Wings can...
nevermind screwed with this post 05-16-2011 at 04:14 PM |
05-16-2011, 08:57 AM
#786 |
Oddometer: 82
Update TuneECU 1.9.4
05-15-11 TuneECUv1.9.4 now released
* Fixed a bug Sagem ECU. * Limit value F KTM tables corrected. BR, Tom |
05-16-2011, 12:52 PM
#787 |
especie en extincion ®
test and tests
1 990 R 7600KM 2Nd 990R 7200km 1st map akra R, leo vince 2 1 2nd original map, then map akra, then map Otto (pp. tuneecu) in all the accelerations a plus of difference for the 1st bike, started at 3000 rpm in 2,3,4,5,6 the moto 1 takes advantage of 30 meters or more After loading the maps the reset of 15 minutes. both with Removed O2 Removed SAS 2 removed Accelerator same weight of rider where this difference? ------------------------------------------------------------ ensayo y pruebas 1º 990 R 7600KM 2º 990R 7200km 1º mapa akra R, leo vince 2 1 2º mapa original, luego mapa akra, luego mapa Otto (pag. tuneecu) en todas las aceleraciones un plus de diferencia para la moto 1º, arrancamos a 3000 rpm en 2,3,4,5,6 la moto 1 saca ventaja de 30 mts o mas luego de cargar los mapas el reseteo de 15 min. ambas con O2 eliminado SAS eliminado 2 acelerador eliminado mismo peso de jinete donde esta la diferencia ? |
05-16-2011, 12:57 PM
#788 | |
Muchacho mui loco
Oddometer: 2,294
05-16-2011, 02:19 PM
#789 |
05-16-2011, 02:22 PM
#790 |
Muchacho mui loco
Oddometer: 2,294
05-16-2011, 02:28 PM
#791 |
05-18-2011, 05:59 AM
#792 |
Major Medical
Oddometer: 3,188
Starting to hardwire the LM-2....
![]() TPS is in the main harness thats gonna be harder to tap... ![]() Tach signal was pretty easy to get to....
05-21-2011, 11:13 AM
#793 |
Life is a trip
Oddometer: 3,101
I checked differences between Akra maps.
KM601AK0704501 is AKRA US 2007-8 is identical with
KM601AK0702S01 is AKRA EU 2007-8 Also KM601AK0704501 which is AKRA 2007-8 (see above) at TPS5% seems to be close to 5% richer than the KM601EU0704501 EU normal exausts.
There is always a reason!! gefr screwed with this post 05-23-2011 at 10:29 AM |
05-22-2011, 03:40 AM
#794 |
Oddometer: 490
I am going to attempt to mod my 2007 990's mapping. I m not the best on computers but can't live with my bike current mapping. I had the Akro map loaded and it runs slight bit better but is getting 25 to 30 mpg and stalled 3 times yesterday around idle with the wife on back. I was looking for someone in the Cleveland, Ohio area that has experience with loading maps and tweaking that could help? Anyone out there?
Current Bikes: 2012 Yamaha Tenere, 2010 Vespa 300 Super scooter ( hers), 2011 Blur 220i (his) |
05-22-2011, 02:10 PM
#795 |
Major Medical
Oddometer: 3,188
Out with the old sensor...
![]() In with the new... ![]() ![]() Uh oh....notice any difference between the two...new Bosch is fatter and it won't screw into the factory bung ...and I see why, factory didn't quite lineup the bung and welded it off center ![]() ![]() Dremel to the rescue a few short minutes later all better...I didn't want a bunch of metal particles in the exhaust so I used a magnet to get as much I could... ![]() Route the cable...kinda tricky as it has a large connector on the end... ![]() Glove box wiring complete ready to log some wide band data, Tach & TPS ![]() ![]() Here's to using TuneECU to make my own custom map
