Old 05-31-2011, 01:11 PM   #841
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,870
Originally Posted by Dotbond View Post
Which LM2 kit did get? LM-2 "Basic", LM-2 Kit (Single Wideband O2) or Duo Kit (Dual Wideband O2)
Did you buy any other bits?
I've been out of town...LM-2 kit less then $300 USD NIB shipped Ebay...I opened the unit up to see how hard it would be to add another sensor on the cheap...no go....its an additional circuit card soldered to the main....
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 05-31-2011, 02:35 PM   #842
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
So just to make sure I've got this right:
F=open loop, used above the F-L switch point
L=closed loop, used below the F-L switch point
O2 sensor eliminators=O2 unchecked in TuneEcu=F-L switch 0,0,0,0,0,0,0,0=open loop only operation, so ignores L map?
These are all equivalent means to a single end, correct?
Just trying to get my head around some of the smaller things in the program.
FWIW, I installed the akro R map and turned the O2 sensors off and almost all of my small-throttle issues went away. The remainder is irrelevant. Since I only have the Q4s, I'm going to switch back to the stock R map and try the settings in a prior post for the F-L switch instead of turning the O2s off altogether: 12,12,12,10,5,5,5,5
This is SO much better than pulling carbs over and over and over and over....
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 05-31-2011, 03:46 PM   #843
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 498
It could be just me but I can't seem to even open the home page to look at the program. It asks me for a password to even get to the overview. Am I missing something?
2009 KTM 990
Honeymoon Ride Report
Crazy Europeans Tour Utah
Bronco3738 is offline   Reply With Quote
Old 05-31-2011, 04:07 PM   #844
Uller
Uller's Avatar
Oddometer: 1,681
I'm getting the same thing. Guess the site is down????
Uller is offline   Reply With Quote
Old 05-31-2011, 04:13 PM   #845
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 498
Bummer was looking to order a cable but not until I can get on the program site.
2009 KTM 990
Old 05-31-2011, 04:35 PM   #846
Alleycatdad
Oddometer: 1,439
Go ahead and order it. I'd be happy to email you the file...
Steve
Old 05-31-2011, 04:51 PM   #847
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 498
Steve
Thanks, sent you a PM.
Mike
2009 KTM 990
Old 05-31-2011, 05:17 PM   #848
Alleycatdad
Oddometer: 1,439
ps-this is coming down when the real site comes back up...and it is...
Alleycatdad screwed with this post 06-01-2011 at 06:44 AM Reason: site back up.
Old 05-31-2011, 05:44 PM   #849
Sapling
Sapling's Avatar
Oddometer: 413
Originally Posted by tahoeacr View Post
$300 for the cams and 8 WHP. I think the stock Adventure(at least the older ones) has a boring powerband. Needed something to make it more fun to ride on the street. The cams have a nice hit at 6,500rpm. And lets all face it. At 4 or 5k in the dirt your having a hard time getting it to hook up so why not build a bunch more hp at 7k so your friends can't even get close or get roosted by small trees. In 08 the only difference between a SD and Adventure was the cams, exhaust and ECU map. Pretty easy to get SD power out of an Adv.
SD cams are in my future.....
2008 990 ADV AK map Ti Q4 pipes
Woods setup Yz 450F
http://www.youtube.com/user/saplingthrasher
Sapling is offline   Reply With Quote
Old 05-31-2011, 05:46 PM   #850
Bronco3738
Mike
Bronco3738's Avatar
Oddometer: 498
Can't email the file to Gmail. Try this:
http://www.alleycatdad.com/tuneecuv194.html
You realize that the site's probably down for them to release a new version, right? Since we're going to all this effort....
Anyway, theres no tunes on my site but this'll get you started. I gotta get outta work here for the day.
Steve
Got it thanks.
Mike
2009 KTM 990
Old 05-31-2011, 06:21 PM   #851
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 3,026
Thank you for putting that out there!
nevermind is offline   Reply With Quote
Old 05-31-2011, 07:07 PM   #852
Alleycatdad
Oddometer: 1,439
Looks like tunes and software are still available here: http://www.box.net/shared/pusg6v7nyd
Steve
Alleycatdad screwed with this post 05-31-2011 at 07:25 PM
Old 05-31-2011, 10:08 PM   #853
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
Here is some reading for you guys.
If you have no clue about Fuel Injection start here. This looks like it is from some DSM turbo car guys but covers all the basics.
http://www.enginebasics.com/EFI%20Tuning.html
Reading gets better with these two.
http://www.bikeboy.org/fuelinjection.html
http://www.bikeboy.org/open_closed_loop_efi.html
tahoeacr is offline   Reply With Quote
Old 05-31-2011, 11:50 PM   #854
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,002
Steve
According to your thoughts, eliminating O2 means running on the F maps continuously? so Akra maps that ignore O2 sensors work only on F maps?
Old 06-01-2011, 02:41 AM   #855
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 771
They were certainly worth the reading time. The points I took from this is that the closed loop operation in conjunction with the O2 sensors - narrow band - is designed to cycle between rich and lean, thereby creating a surging sensation.
Would fitting wideband O2 sensors eliminate this surging in the 990? Or would you have to remove the O2 sensors and use the F map as suggested by Alleycatdad, and tune the F map accordingly?
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Times are GMT -7.   It's 05:20 AM.
