Old 11-17-2010, 08:35 PM   #106
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
Just got the cable. Thanks Powercell!
I'm reading the Akropovic map from my ECU right now. It was loaded on my '07 Adventure around 9/09. It is map KM601AK0704501.
I am anxious to compare the different maps.
Edit: I have the bike plugged in to my trickle charger, which is probably a good idea if you are going to have the ignition (and headlight) switched on with the engine off.
'07 KTM 990 Adventure Long Road to Dug Bar
Nut Clutch is offline   Reply With Quote
Old 11-17-2010, 09:43 PM   #107
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,322
Hey steve I got the newer stock map. How did you like the akro map?
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 11-17-2010, 09:48 PM   #108
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,164
You going to CB's tomorrow? Interested to hear about it. My Powecell cable is in transit...
cyborg is offline   Reply With Quote
Old 11-17-2010, 09:58 PM   #109
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,313
Now that inmates are starting to get their cables, you need to know how to adjust the computer port settings. Before you do this, install the TuneECU software and driver as described here:
http://www.tuneecu.com/TuneECU_En/install1.html
You need to set the port settings for the USB/ODB-II adaptor.
For Windows XP:
1 - Right click on My Computer
2 - Select Properties
3 - Choose the Hardware tab
4 - Locate the USB Serial Port and double-click
5 - Choose the Port Settings tab
6 - Change the Port Speed setting to 921600
7 - Change the Flow Control setting to Xon/Xoff
8 - Choose OK to save the settings and you're all set
For Windows 7:
3 - Choose Device Manager
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 11-17-2010, 10:01 PM   #110
RoundOz
Plenty of seasoning
Oddometer: 995
For Powercell
PM sent for cable
...and thanks for all your help!
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 11-17-2010, 10:02 PM   #111
Dusty
Dusty's Avatar
Oddometer: 1,272
Got my cable today also, thanks Ken.
Great to see the guys with the 07s getting onboard.
Steve thanks for posting your map #... It's going to make it easyer to identify on the TuneECU site.
I will hook mine up tomorrow and read the map and send it to Tom to add to there collection. He has posted on the Duke site that he has had a couple maps sent to him without a bike description, so if anyone has sent one from here he was looking for the bike it was downloaded from.
It will be nice to see what changes KTM made to the map updates..
Also while reading thru the Duke forum one member has seen dramatic improvements with the throttle on-off snatch with getting his TPS set spot on.
Scott
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty screwed with this post 11-17-2010 at 10:30 PM
Dusty is offline   Reply With Quote
Old 11-17-2010, 10:03 PM   #112
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,322
You can borrow mine when ever you want. Yes, I am going. I need to get out of work somehow this week. It's been nutty with back to back releases.
It's running amazingly smooth, but I still have a hesitation from 4-5k. It is driving me insane.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
Old 11-17-2010, 10:03 PM   #113
Dusty
Dusty's Avatar
Oddometer: 1,272
Thumb
Thanks for the English version Ken...
Old 11-17-2010, 10:51 PM   #114
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
I had the stock map, newer stock map, and then the newer akropovic map. Seemed like there is a little more top end and a little less snatch with the Akropovic map. It is definitely thirstier.
I'll be sending my Akropovic map. I'm sure this has been discussed before, but it looks like this map has the EPC and O2 sensor disabled. It does show that the SAI and 2nd throttle are enabled.
EDIT: MY tps reads from 0% to 94%. Too bad some of the test and adjust functions currently do not work.
Old 11-17-2010, 10:55 PM   #115
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
Thank you. Definitely speeds up the map reading.
Old 11-18-2010, 11:04 AM   #116
nevermind
sLOW Rider
nevermind's Avatar
Oddometer: 2,972
I'm running the 2010 990R map in my 2010 990A. Changes using tuneECU are:
Idle setting: 40c and 65c boxes set at 1650 rpms
F-L setting: 1000 rpms to 12, 1300 to 5 and the rest are set to 0.
***Note: I read you don't want to zero out these settings at too low an rpm. See: http://www.triumphrat.net/ecm-and-fi...ml#post1451505
I started at 1000, 1300 and 1450 set to stock and 2000 set to 5. I still had some unwanted jerkiness, so I moved the 5 and zero's to lower RPM's. I rode it between each setting and I like where I have it now until I can run it on a dyno with a gas analyzer.
SAI checkbox: Disabled
O2 Sensor checkbox: Enabled
2nd Throttle checkbox: Enabled
I just ran some slow speed stuff around my neighborhood using small throttle openings only and I have to say it is pretty doggone smooth. I can still make the bike lurch in some closed to open throttle transitions, but overall these settings are quite acceptable for me.
Just a note - I run the G2-400 throttle cam and the football shaped secondary butterflies from the guy over at superduke.net.
nevermind screwed with this post 11-23-2010 at 05:32 AM
nevermind is offline   Reply With Quote
Old 11-18-2010, 11:56 AM   #117
chrish4ku
chrish4ku's Avatar
Oddometer: 769
PM and $ sent
Thanks man,
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku is offline   Reply With Quote
Old 11-18-2010, 12:23 PM   #118
chrish4ku
chrish4ku's Avatar
Oddometer: 769
Fuel Mileage?
Hi - just curious what mileage you got with the Ack mapping? On my 2008, I had the dealer swap to the "open" map which I assume is this one. Now I get around 29 MPG, average.. Yikes.
Chris
Chris' Sat Tracker
Old 11-18-2010, 01:48 PM   #119
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
Yeah, mileage is crap. Somewhere around 30 MPG + or -. I did get the advtank this last summer, so that helps range quite a bit.
I really didn't want the Akropovic map loaded, but that is what they ended up doing since I brought it in for a software update and it already had the FMF pipes on it. I decided to live with it, and did enjoy how the engine ran.
Since I now have the 2 to 1, I plan to remap the bike sometime this winter.
After looking at the TuneECU software, it appears that there are quite a few layers underneath that aren't accessible. I was hoping to see some kind of configuration for the low octane switch. Does it just do an across the board ignition retard by x number of degrees, or is it more involved than that? Also, if the O2 sensor is switched on, at what rpm and throttle range is it active, and what A/F ratio is it looking for? Finally, does the ambient map sensor do some kind of trim adjustment on the fueling based on atmospheric pressure in all throttle and rpm ranges?
Old 11-18-2010, 02:41 PM   #120
Spark01
V-Twin
Spark01's Avatar
Oddometer: 304
Which program you used to look deeper in the software??.
or how did you look deeper in the software??.
'10 990SMT
Spark01 is offline   Reply With Quote
Times are GMT -7.   It's 04:19 AM.
