Old 09-16-2011, 11:51 AM   #1216
bouboule
Oddometer: 52
Yes but I've a 08' and some mechanical component are different.
Do you think that I can try this map? Someone has try it?!
bouboule is offline   Reply With Quote
Old 09-16-2011, 01:29 PM   #1217
Swedemarine
Oddometer: 9
I think you have a point bouboule.
I have an Euro 06, comparable to US 07:s. Why would the map for 11 work good for us? Our engines donīt have the same mechanical specifications as 09-11.
I am pretty sure the cams are quite different. From 09 the standard bikes have the same engines as the R models, except mapping. That is why 09-11 can produce the same horsepower as an R by utilizing the R-map, which has no restrictions in the top end of itīs secondary throttle map.
That is what I think I have learned from following this thread from the start.
Swedemarine is offline   Reply With Quote
Old 09-16-2011, 03:02 PM   #1218
Suncruiser
and Adventurer
Suncruiser's Avatar
Oddometer: 233
Tuned!
Hi,
I've been following this thread since a while in hope to find the magic bullet to more power, more torque and less fuel consumption. After changing from stock to FMF pipes and Akra mapping fuel economy went down from 6.5 lt/100km to 8 lt/100km( 37 mpg to 29 mpg). The ride got much smoother though.
Yesterday I had a session with the local Dyno guru and TuneECU. Very insightful. The bike was:
a tad lean at idle, very lean at mid range revs(3k-6k) and very rich at high revs(6k-9k). The most change was needed at high revs, -10%. Here's the graph:
In my opinion there's no other way to max performance and economy than to put the bike on a dyno with someone who knows how to tune a EFI bike. Unfortunately the bike went from the dyno straight into a crate to get shipped to SF/USA to start my way down south to the tip of SA.
Ciao, Helly
Good to be out there riding.
Peru to San Francisco 2011/2012 http://allthoseroads.wordpress.com/
Oz 2010 http://helmutgottschalk.wordpress.com/
2010 Adventure 990 R
Suncruiser is offline   Reply With Quote
Old 09-17-2011, 10:23 AM   #1219
DirtJack
DirtJack's Avatar
Oddometer: 1,464
Originally Posted by mousitsas View Post
We are talking about engine braking when throttle is fully closed, right?
In that case why do the secondaries have any effect?
Isn't the issue that even though you have twisted the grip closed, the ECU is actually in control of the primary and secondary butterflies?
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 09-17-2011, 02:25 PM   #1220
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Update on the Power-tripp Akra Map:
Highway cruising/ spirited twisties, about evenly split: 36.4 mpg.
Disclaimer-it's a small sample, not a ton of miles...
I'm not terribly surprised by this; I'm running Q4s rather than the Akras, and 16/45 gearing...
Still really happy with the map, driveability-wise. I'm tempted to knock down some of the fueling slightly to accommodate the more-restrictive exhaust, but it just runs so well that I'm sure not gonna do it before my 1200 mile trip next weekend.
Dirt was more interesting; fireroads to moderately technical running, 24.3 mpg. Not sure this one is real; that's a really big difference. Jury's still out, and don't let this result keep you from trying the map--like I said, I'm not sure I didn't do something wrong on this one-tank sample...
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 09-18-2011, 01:20 AM   #1221
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,885
A question for you.
Yours is a '08 model. You bought it used? Since you seem to have the most troubles in here, I wander what CDI you are wearing on your bike. There have been some changes through the years. Could be you have a less efficient one? I was told they upgraded to a quicker unit, collecting more samples from the sensors. So what #part number is your bike's unit? Better read it on your CDI and not on your part's catalog. Cheers.
gefr screwed with this post 09-19-2011 at 03:10 PM
Old 09-19-2011, 12:58 PM   #1222
bouboule
Oddometer: 52
Yes, I'm the second proprietary. I think that the problem about I'm talking is the cause of an bad ecu mapping...
That are data which are note on the unit:
630E-1941-0B02
7Z11-326618
I think that is the KTM reference: 610.41.031.001
What d you think about this?
Old 09-21-2011, 07:48 PM   #1223
mgib
Oddometer: 124
I've got a small problem...
I got my cable, loaded the programs, downloaded a couple of maps and plugged it in and it all worked as advertised.
Thanks Tom and Alain.
Ran diagnostics and found out my tps is way off at .73 with 0 throttle. Gotta fix this this weekend first before trying any new maps.
It appears I have the 06 Akra map for my 08 with dual FMFs. Snatchy as all get out. So I want to try the newer Akra map and the stock map to see if that helps.
My problem is that though I downloaded the maps I want to try, opened them with tuneecu and extracted them, but I can't find them when tuneecu is opened. They don't appear to be in the program. What did I do wrong?
Mark
500 EXC
500 XC-W
F800GS
mgib is offline   Reply With Quote
Old 09-22-2011, 12:29 AM   #1224
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,885
I have the same ECU
630E-1941-0B02
7Z11-326618
I think that is the KTM reference: 610.41.031.001 610.41.031.100 more likely
I see this item was superceded by 610.41.031.200 so I wonder if there was a good reason for that.
Cheers.
Old 09-22-2011, 12:48 AM   #1225
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 761
Start Tuneecu.exe then click File -> Open File Map and browse to the map you want to see in Tuneecu.exe
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Old 09-23-2011, 04:56 PM   #1226
bouboule
Oddometer: 52
Cheers.
Do you think that this difference can cause my problem?! How can i be sure?
This model is the newest like 09'? How many does he cost?
Old 09-23-2011, 06:54 PM   #1227
mgib
Oddometer: 124
Thanks dotbond, I just couldn't seem to get there. That said, I'm not 100% sure it's actually in tuneecu ready to flash the ecu. I'll find out tomorrow...
Mark
500 EXC
500 XC-W
F800GS
Old 09-23-2011, 09:54 PM   #1228
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,323
Just wanted to note, my bike is way smoother running with CJ racer sparkarrestor/silencer in akros and filter skin for some reason. Akro map still.
It definatly has more power with out, but it still has way more than you need.
35-40 offroad and 40-45 pavement.
It dropped below 35 I think on the rubicon trail though...
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 09-23-2011, 10:33 PM   #1229
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,161
mine too. Way below. What's wrong with it?
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 09-25-2011, 01:21 AM   #1230
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,885
This is the problem. You can't
It costs 480euros in Versand deutsland unless you find it on ebay or elsewere. On the other hand mine is the same and is not so bad.
Times are GMT -7.   It's 02:11 AM.
