Old 11-18-2010, 02:09 PM   #121
Sheep Shagger
Show me your fleece
Sheep Shagger's Avatar
Oddometer: 2,178
Originally Posted by Steve Lavigne
I had the stock map, newer stock map, and then the newer akropovic map. Seemed like there is a little more top end and a little less snatch with the Akropovic map. It is definitely thirstier.
I'll be sending my Akropovic map. I'm sure this has been discussed before, but it looks like this map has the EPC and O2 sensor disabled. It does show that the SAI and 2nd throttle are enabled.
EDIT: MY tps reads from 0% to 94%. Too bad some of the test and adjust functions currently do not work.
Funny, I uploaded the same map as you, and personally I thought that was the absolute worst map by a log way that I had tried, and you thought it was the best.
On the TPS, reading the SD forum, is seems you should sync the TB's, then set the TPS fully open position so it's just under 100 (~95) when cold or ~100 (99) when warm, that will give you a high TPS of 5~10% at closed. Run the 15min idle trick and that will re-set the TPS to 0%. That way you can get very close to the full range of 0-100% TPS and the map works as listed in the tables.
Sheep Shagger is online now   Reply With Quote
Old 11-18-2010, 02:32 PM   #122
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 437
Originally Posted by Spark01
Which program you used to look deeper in the software??.
or how did you look deeper in the software??.
I may have mispoken a bit. What I meant was that parts of the calibration that I would expect to be in the ECU are not accesible from within the TuneECU software.
'07 KTM 990 Adventure Long Road to Dug Bar
Nut Clutch is offline   Reply With Quote
Old 11-18-2010, 02:39 PM   #123
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 437
Every once in a while it acts up, but doing the 15 minute idle trick seems to clear it up. Of course, this is all after removing the charcoal cannister, plugging the SAI, FMF cans, 16 tooth front sprocket, removing the secondary butterflies, and a G2 throttle cam. I initially used the 400 cam, changed it quickly to the 200 cam, and just recently changed it to the 100 cam.
I did notice a little more top end and it seemed to have a little healthier sound to it.
Thanks for the tip on this. I hadn't thought about the TPS reading changing with temperature.
Nut Clutch screwed with this post 11-18-2010 at 02:47 PM
Old 11-18-2010, 04:53 PM   #124
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,199
Thanks Ken, got my cable. downloading the map as I type this!
I will send Alain/TuneECU my map with the ref of the bike. Awesome!
Then start tweaking.......
EDIT:
ouch...
already 3 error codes.....
po122 - Throttle position sensor low voltage (short to ground or open circuit)
po201 - Injection 1 circuit malfunction
po202 - Injection 2 circuit malfunction
hum... the bike runs ok though... are you guys getting these? (getting these codes whether the bike is off or engine started)
RE EDIT:
well I erased them and they don't seem to be coming back... any clue why they would be there in the first place?
bikyto screwed with this post 11-18-2010 at 05:11 PM
bikyto is offline   Reply With Quote
Old 11-18-2010, 05:13 PM   #125
Sheep Shagger
Show me your fleece
Oddometer: 2,178
EDIT:
ouch...
RE EDIT:
At some point in it's life the bike was probably started with a bad ground. If they clear and don't come back, don't worry.
Old 11-18-2010, 09:05 PM   #126
twodollardoug
the calimesa kid
twodollardoug's Avatar
Oddometer: 337
does anyone know if i make changes to the f-l switch, will it make changes to my a/f ratios? will i run the risk of a lean or rich condition?
"I don't give it a name, but I always speak with it. I don't know if other riders do the same. This is not only a piece of metal - there is a soul" -Valentino Rossi
twodollardoug is offline   Reply With Quote
Old 11-18-2010, 09:10 PM   #127
a$$hole
a$$hole's Avatar
Oddometer: 997
Got my cable! Now Im waiting to see about a cheap laptop from my wifes coworker. If that doesnt pan out then Im just going to get a long (active repeating) usb cable. Cant wait!
a$$hole is offline   Reply With Quote
Old 11-18-2010, 09:15 PM   #128
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,263
Got my Powercell cable! Thanks Ken. Now I can play more with the maps, not that I'm all that unhappy with my #29 custom map. I'll convert that one to TuneECU when I git round' to it...
cyborg is offline   Reply With Quote
Old 11-18-2010, 09:21 PM   #129
bikyto
bikyto's Avatar
Oddometer: 2,199
I'm still but oh well..they are gone..
bikyto screwed with this post 11-18-2010 at 10:12 PM
Old 11-18-2010, 10:06 PM   #130
twodollardoug
the calimesa kid
Oddometer: 337
EDIT:
ouch...
RE EDIT:
i had a few too chris. never had a FI error light. i erased them and never looked back.
Old 11-19-2010, 04:07 AM   #131
teti
especie en extincion
teti's Avatar
Oddometer: 143
new version 1.7.8
saludos
teti is offline   Reply With Quote
Old 11-19-2010, 08:13 AM   #132
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,046
Powercell Cable
Ordered a Cable
Thanks for the work Ken !
Twist it, MAX
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 11-19-2010, 08:33 AM   #133
chrish4ku
chrish4ku's Avatar
Oddometer: 874
Map References and Notes
Maps are here:
http://www.box.net/shared/pusg6v7nyd...nyd/1/56746962
For KTM 990A, has anyone been able to ID what maps these are? Is there a table or cheat sheet for these somewhere? Maybe I missed something, but just trying to figure out what is what....
Chris
[IMG]file:///C:/Documents%20and%20Settings/ch2f5df/Desktop/Maps.jpg[/IMG]
_______________________
Chris
I don't normally ride on the street,,,but when I do,,I prefer lane splitting.
2011 KTM 990 Adventure / KTM 500 EXC
Chris' Sat Tracker
chrish4ku screwed with this post 11-19-2010 at 10:58 AM
chrish4ku is offline   Reply With Quote
Old 11-19-2010, 09:49 AM   #134
Jim Colombotos
Jim Colombotos's Avatar
Oddometer: 321
Box website
Guess this is where we will be uploading our bike maps from here on out?
Regarding the previous post ....on each map there is a downward facing (pulldown) arrow or next to that a block with a number in it press either to see or add remarks. Ive taken the info from tune ecu website and added remarks to the box website describing what year each map is for. If you see a mistake please revise my description right on the box website as I am no expert on this!!!!
2013 KTM 500 EXC
2009 KTM 990 Standard
2014 1190 R
2015 350 EXC
Jim Colombotos screwed with this post 11-19-2010 at 09:57 AM
Jim Colombotos is offline   Reply With Quote
Old 11-19-2010, 10:00 AM   #135
bikyto
bikyto's Avatar
Oddometer: 2,199
You're correct about KM601US0704501
I sent it to Alain last night. He put it up fast!
Times are GMT -7.   It's 05:14 PM.
