Old 10-04-2012, 09:11 AM   #136
Fire Escape
Fire Escape's Avatar
Oddometer: 1,633
Thumb Quick Service
At the beginning of the week, I hadn't heard of these Power Ports. Today two of them and a Tapp Capp were already in my mail box. They look well made and especially well thought out. The proof will of course be in how well they work but for the first time since learning that DeLorme no longer offered mobile power cords, I have some confidence that my PN-60 may become more than a 'desk ornament'.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 10-04-2012, 11:08 AM   #137
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 296
Bruce
Thanks for the bump. If you have a chance we would love to see pics of your install.
-D
Shov3BR is offline   Reply With Quote
Old 10-13-2012, 01:37 PM   #138
satur9
angry black guy
satur9's Avatar
Oddometer: 540
i had them custom make me one that plugs into my coax/barrel/baryl or whatever most people call them heated gear battery harnesses i have on my bikes. works great.adn thier version of the heated gear plugs are covered so with a tapp capped cable youre weatherproof
I drank the koolaid again.
Well, it took a lot of work to be the ass that I am
And I'm real damn sure that anyone can, equally easily f*ck you over ...(modest mouse).
satur9 is offline   Reply With Quote
Old 10-14-2012, 09:57 PM   #139
killowatt
killowatt's Avatar
Oddometer: 73
USB to SAE
Originally Posted by Shov3BR View Post
Ta Dah!
Thanks Low594 - I was wondering if I should have left the pins out of the housing and have MP punch them in. I now feel confident that it's correct.
Hey - MP send me a message with your shipping address and we'll get this thing to you.
How about one of these with a SAE two pole connector. Say 12" long. This could connect to the plug I have already installed for my battery tender mounted near the head set. I already have an SAE to cigar lighter with a 12" whip that works well in the tank bag. It seems that going straight to USB would help eliminate a problematic loose connection point.
You can't be drinking all day if you don't start in the morning
killowatt is offline   Reply With Quote
Old 12-28-2012, 10:45 AM   #140
CA Stu
CA Stu's Avatar
Oddometer: 47,783
Do the TAPP lite USB power ports use any power when wired directly to an always hot auxiliary power wire on the wiring harness?
Any parasitic loss?
CA Stu
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 12-29-2012, 08:30 AM   #141
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 296
TAPP & TAPP Lite Quiescent Power
Yes, contrary to what you might read in other ADVRider threads, all switching requlators have some quiescent (no load) power drain.
TAPP Lite draws 8mA (.008A) which isn't much so unless your bike sits for a long time, it won't drain the battery.
TAPP 2.1A with its MOSFET switcher draws a whopping 35mA and will kick the snot out of all but the biggest touring bike batteries in a few days. We recommend connecting the TAPP 2.1A family of USB power ports to a switched circuit like an accessory or taillight circuit. We provide one of those triple-trick PosiTaps to make the connection very easy.
Hope this helps.
-Shov
WWW.3BRPOWERSPORTS.COM Putting the POWER in powersports
'11 KTM 990 ADV Dakar, '08 KTM 690 Enduro, '09 H-D Road King, '82 H-D FXRS (Shovelhead)
Old 12-29-2012, 12:26 PM   #142
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,193
Hope this helps.
-Shov
I have my TAPP Lite hooked up to a fuzeblock FZ1 on a switched only circuit. Great products!!
The race is long and, in the end, it's only with yourself...
bikyto screwed with this post 12-30-2012 at 09:35 PM
bikyto is offline   Reply With Quote
Old 12-30-2012, 08:53 PM   #143
CA Stu
CA Stu's Avatar
Oddometer: 47,783
Hope this helps.
-Shov
Sure does, thanks!
Great product, I own 4 of them, but I had 2 dead batteries and had to ask...
Will re-wire them to switched hot wires, much grass!
CA Stu
Old 05-18-2013, 08:06 PM   #144
Kainic
Almost there
Kainic's Avatar
Oddometer: 390
Not sure what I did wrong. I hooked up my TAPP to my fuzeblock and it doesn't seem to work?
Kainic is offline   Reply With Quote
Old 05-18-2013, 09:12 PM   #145
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 296
The most common problem is reversed polarity. TAPP is protected against reversed polarity. It won't hurt the TAPP it just won't work. Is it located where you can temporarily connect it directly to the battery to see if it works? If that doesn't help send us an email (address on "support" tab of webpage) & we'll see what we can sort out.
Old 05-19-2013, 02:46 PM   #146
dwrads
Right Wristed
dwrads's Avatar
Oddometer: 488
Hope this helps.
-Shov
Hi in the interest of keeping it simple, and avoiding the inherent power drain with the TAPP 2.1, would it make sense to put a small water proof switch right behind the USB head?
I need to put one of these on my 500 exc.
DW
The hell with the long way around, take the hard way across.
dwrads is offline   Reply With Quote
Old 05-19-2013, 04:24 PM   #147
Kainic
Almost there
Kainic's Avatar
Oddometer: 390
I am sure I screwed it up. I cut off the terminals and using red to switched (+) and black to (-).
Old 05-19-2013, 07:39 PM   #148
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 296
Switched TAPP USB Power
DW
Tapping (no pun inteneded) into a switched circuit like the taillight circuit is easier. We now supply one of those cool PosiTaps in each kit to make it easy. If you have an older kit that doesn't have a PosiTap let me know & we'll get one in the mail to you.
That said, I did put a switch on the TAPP that powers my SPOT tracker on my 990 so it wouldn't turn off when shut down for fueling. I only shut it off at night or when the bike is going to sit for a while.
I have a second TAPP (I get them for free) that is wired into ACC2 so it turns off with the ignitiion.
Old 05-19-2013, 07:42 PM   #149
Shov3BR OP
Tinkerer
Shov3BR's Avatar
Oddometer: 296
That's all good. Something else is going on here. Have you checked your source circuit to be sure it has power? If so, check on the far side of the fuse (TAPP side) to be sure you have power there.
Old 05-20-2013, 08:15 PM   #150
dwrads
Right Wristed
dwrads's Avatar
Oddometer: 488
Hi Shov, yes I would want to have a way to charge device's when the bike is off. It seemed like an easy way to switch off the power drain when the bike is sitting for days or a couple of weeks would be cool.
At this point I don't have anything, but I will need to get some sort of USB charging point set up on my bike. I'll probably just get a low voltage TAPP, but would prefer to have the TAPP 2, just want some way to deal with the power drain issue on my small single cylinder moto's battery. So I was just curious what you thought about a switch.
Thanks for your response.
DW
Times are GMT -7.   It's 02:26 PM.
